Drives: 2013 Whiteout FR-S AT
AT holding 2nd gear to high revs during a long left turn
Hey guys, I haven't seen this mentioned anywhere and I wanted to see if this was normal. With the car in lazy full auto mode (sport mode off), during a long left turn, the car will not shift out of second until after the car straightens out for a bit after the turn. I'm not mashing on the accelerator or anything and the engine will rev up to 4k+ rpm which is definitely high when not using sport mode. Could it be when the car senses the weight shift during a turn (limited slip differential kicking in) the AT will instinctively hold the current gear?
#2 |
Drives: 2013 BRZ - Sterling Silver Metallic
IIRC, It's a feature. Shifting mid-turn unsettles the chassis, which could result in a spin if you're driving at the limit, so the transmission tries to avoid this.
I could be wrong here, but I think I remember reading about this. I drive an MT, so I can't test this. |
| The Following 3 Users Say Thank You to edward For This Useful Post: |
#3 |
Drives: Supercharged Golf Cart
#4 | |
#5 |
Drives: 2013 whiteout FRS 6mt
The car is telling you to power out and kick the tail out
#6 |
Drives: gts 86
I don't think it is an issue. Just tap the paddle shifter and upshift
| The Following User Says Thank You to trinitron For This Useful Post: | EK_Golfer (03-01-2013) |
#7 |
Automatic Hooligan
Yes, normal behavior. Even in "lazy" mode it's more aggressive than your average autobox.
| The Following User Says Thank You to MVJ1975 For This Useful Post: | EK_Golfer (03-01-2013) |
#8 |
Drives: 2013 Scion FR-S AT Asphalt
All FRS's are equipped with accelerometers that are tied into the ECU. This is how the VCS Sport function gets its attitude adjustment data to let you get a "little" sideways before the TCS and VCS kicks in.
Because of this, in an auto, the ECU may hold a shift for the same reasons stated above. Its even more exaggerated when the transmission is in "Sport" mode. Scott
| The Following User Says Thank You to naikaidriver For This Useful Post: | EK_Golfer (03-01-2013) |
#9 | |
Drives: Asphalt AT
| The Following User Says Thank You to Asphalt~86 For This Useful Post: | EK_Golfer (03-01-2013) |
| Voice Commands with new turn by turn in IOS6? | jadewbj | Electronics | Audio | NAV | Infotainment | 0 | 09-21-2012 10:11 AM |
| Anyone still holding out for BeSpoke? | MrFRsLa | Electronics | Audio | NAV | Infotainment | 23 | 07-20-2012 04:24 AM |
| AC cuts out at high revs. Cool feature? | Superhatch | BRZ First-Gen (2012+) — General Topics | 9 | 06-28-2012 02:13 PM |
| Moto Miwa: First batch of BRZ's and FRS left Japan for Long Beach, CA | feedbag | BRZ First-Gen (2012+) — General Topics | 442 | 06-03-2012 02:54 PM |
