Old 02-25-2013, 10:15 AM   #15
MSTiFK8R
MSTiFK8R's Avatar
Drives: BRZ WRB
Originally Posted by JRitt View Post
I think our engineers have the car in the air right now, but I'll see I can get this done later today or tomorrow. Thanks for your patience.
impossible IMHO
this is what I see put 2 slick tyres in the backseat ...
~245 nominal width
MSTiFK8R is offline   Reply With Quote
Old 02-25-2013, 12:25 PM   #16
JRitt
JRitt's Avatar
Drives: 2012 BRZ Premium WRB 6MT
You're probably right, but we'll look anyway!
Originally Posted by MSTiFK8R View Post
impossible IMHO
~245 nominal width
Essex Parts Services- AP Racing / Ferodo / Spiegler / Versodeck
Jeff Ritter|Mgr.- High Performance Division
www.essexparts.com
JRitt is offline   Reply With Quote
Old 02-28-2013, 10:38 AM   #17
JRitt
JRitt's Avatar
With our harness bar installed in the highest position, our 245 Hankook RS3's slide under the bar with about 4-5 inches to spare. The other two fit in the cargo area without issue if the spare tire is removed. Also, there's still a substantial amount of space on either side, and on top of the tires for other gear. Don't forget the passenger seat, the floor behind the front seats, etc. In summary, you shouldn't have any trouble hauling everything you need to the track or autoX with our harness bar installed. FYI...you'd probably be able to get down to the lowest, or second to lowest setting on the bar before you ran into any interference issues.
MSTiFK8R, you owe me a beer.:happy0180:
www.essexparts.com
The Following 3 Users Say Thank You to JRitt For This Useful Post:
cobrabyte (02-28-2013), CSG Mike (02-28-2013), MSTiFK8R (02-28-2013)
Old 02-28-2013, 10:44 AM   #18
CSG Mike
CSG Mike's Avatar
I see you took the spare tire out... although you technically now have 4 spares lol.
GTM_Challenge (02-28-2013)
Old 02-28-2013, 11:50 AM   #19
MSTiFK8R
MSTiFK8R's Avatar
Drives: BRZ WRB
Jeff, I own you even more anyways for your Endurance brakes kit , just notify me when you're in Russia and I'll get you through this )
Being skeptical on if you could fit a set of 4 tyres in with your harness bar I was thinking if that's possible to fit ALL 4 in the backseat together
It turned out you CAN NOT now, due to the new height limitations
putting 2 tyres in the trunk is a wise choice though, I always put 2+2 when I need extra set - it's easier than folding all 4 in the saloon.
BTW - I put EIGHT 245's PLUS a FILLSIZE spare inside BRZ and driven for quite a while in the city and didnt have major visibility issues
(total 4+8+1 = 13 wheels rolling )
believe it or not )
Old 02-28-2013, 12:56 PM   #20
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
HAHA love it!
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 02-28-2013, 02:29 PM   #21
CSG Mike
CSG Mike's Avatar
believe it or not )[/IMG]
I don't doubt it... I've done 4 rims + loose tires + full set of track tools + everything I need for a weekend + a BNIB set of coilovers (personal delivery for a client!)
I've also done 8 mounted 255/40/17
MSTiFK8R (03-01-2013)
Old 03-02-2013, 01:13 PM   #22
Z-PDX
Z-PDX's Avatar
Drives: 3 series
Nice bar.
So the bar has nut plates welded on the inside and is bolted to the aluminum plates?
Sorry for asking if this has been already. SCCA legal?
Z-PDX is offline   Reply With Quote
Old 03-04-2013, 09:17 AM   #23
GC GTS Aero Kit
Australian and Proud !!!!
GC GTS Aero Kit's Avatar
Drives: 2012 Toyota 86 GTS Aero Kit
any chance of the plastic trim around the harness bar being trimmed to fit?
BONKRS for life
GC GTS Aero Kit is offline   Reply With Quote
Old 03-04-2013, 01:36 PM   #24
JRitt
JRitt's Avatar
Originally Posted by Z-PDX View Post
Nice bar.
Thanks! No nut plates. You actually bolt through the back of the end plates into the bar, before installing it. Then you just take it as one unit with the end plates attached, and push it up into the proper location...then bolt the end plates into the car. You can see the installation instructions here, which should clear up any construction or install questions.
Sure. If you just measure properly, you could use a hole saw and do a simple cutout for the bar. Then it would just extend right into the factory plastic. Heck, you could probably do it with a utility knife.
www.essexparts.com
Last edited by JRitt; 03-05-2013 at 01:02 PM. Reason: added install instruction link
autox, bar, essex, harness
FRS/BRZ in the essex county (windsor/lasalle/tecumseh) area? Minhtyfresh CANADA 26 08-07-2015 09:17 AM
Help Gmookher decide AP racing Vs Stoptech BBK vs Essex SPRINT KIT gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 141 01-18-2013 08:39 PM
New Product: Essex Harness Bar JRitt Tracking / Autocross / HPDE / Drifting 22 12-06-2012 02:01 AM
Essex Sprint brake kit--Strano Performance will be carrying them... Sam Strano Brakes, Suspension, Chassis 13 10-08-2012 02:47 PM
Essex/AP Racing Competition Brake System in Development JRitt Brakes, Suspension, Chassis 1 06-14-2012 02:32 PM
