JonMotoring
Old 02-27-2013, 04:33 PM   #5405
SMOKETREES
Lowered Lifestyle
SMOKETREES's Avatar
Drives: Scion Fr-S
Originally Posted by Sivtec View Post
This is the sexiest front end of an FRS I have ever seen.... EPIC... Just thought I would share
Yeah do boys build is pretty nice! I wanna do his jdm push start in the scion!
SMOKETREES is offline   Reply With Quote
Old 02-27-2013, 04:34 PM   #5406
SMOKETREES
Lowered Lifestyle
SMOKETREES's Avatar
Drives: Scion Fr-S
Just ordered my XXR 527's in 18x8.75 35mm offset and in flat black. Should be here by Friday from what @JoeBoxer has told me ! Tomorrow going to vivid to order intake and maybe some Siebon peices!
Old 02-27-2013, 04:38 PM   #5407
SMOKETREES
Lowered Lifestyle
SMOKETREES's Avatar
Drives: Scion Fr-S
@Yruyur still interested with the spacers? Give me a text or pm and we can talk about price
Old 02-27-2013, 04:38 PM   #5408
Sivtec
Sivtec's Avatar
I agree very sexy build, I don't care for his Rota's tho.
I envy you... mmm Seibon
Old 02-27-2013, 05:49 PM   #5409
SMOKETREES
Lowered Lifestyle
SMOKETREES's Avatar
Drives: Scion Fr-S
Yeah not a fan of the 5 spoke Rotas either....
Old 02-27-2013, 09:35 PM   #5410
kos
Drives: 04 UCF30 / 05 GDA-E / 06 GDA-F
JDL looking forward to seeing you at the Modified Shootout in a few weeks!
2005 RS Impreza Airlift Bagged
2006 WRX Street AWD Time Attack
kos is offline   Reply With Quote
Old 02-27-2013, 09:36 PM   #5411
Sivtec
Sivtec's Avatar
So my car stalled again after work.... I do not understand... I rechecked the Intake, everything looks good, filter looks good, hosing looks good... I then thought of something, when you reflash an ECU, do you have to reset the battery to recycle the ECU? When I got my car back they said they reflashed it but my time was set, my stations were all the same, I do not think they pulled the battery cable.. Does it work like a windows update where you have to restart the computer or does it work like lets say a browser update where you don't have to turn off the PC?
Old 02-27-2013, 09:49 PM   #5412
Accurate Race Shop
Accurate Race Shop's Avatar
Drives: Scion FR-S
The radio presets are in the radio not the ecu and they should reset your clock for you. Sounds like they just reset it instead of flashed it. When they flash it they wipe it and reinstall the software
Sent from my SGH-T989 using Tapatalk 2
Old 02-27-2013, 09:57 PM   #5413
Sivtec
Sivtec's Avatar
Well on the paperwork it says they reflashed it. More specifically ZA1J700C to ZA1JA00C. And I know the radio presets are on the radio but if you pull the battery terminal you lose your presets, at least I do. So I don't think they pulled the battery terminal after the reflash. I'm just curious if you NEED to pull the battery terminal afterwards.
Old 02-27-2013, 10:11 PM   #5414
Accurate Race Shop
Drives: Scion FR-S
I didn't on mine but they might have done it for me. Can always try it and see what happens
The Following User Says Thank You to Accurate Race Shop For This Useful Post:
Sivtec (02-27-2013)
Old 02-27-2013, 10:21 PM   #5415
Pscylo
Pscylo's Avatar
Drives: Raven FR-S
Shouldn't need to...
After a reflash, turning the ignition off, waiting 10-15 sec, then turn it on (but not starting the car for 15 sec), to allow the new flash to fully load before the car is actually running - should have been the normal sequence...if they did it right, but if they flashed it and every time since then its just been starting immediately, there might be an issue since it hasn't full loaded after flash before the engine is running...
Could always disconnect the cable to hard reset the ECU, then reconnect, turn the ignition to ACC, and wait 30 sec before starting it and see how it goes.
Pscylo is offline   Reply With Quote
The Following 2 Users Say Thank You to Pscylo For This Useful Post:
Accurate Race Shop (02-27-2013), Sivtec (02-27-2013)
Old 02-27-2013, 10:30 PM   #5416
Sivtec
Sivtec's Avatar
I'll give it a shot... At this point I'm running out of ideas... Which is terrible because I can feel like the intake is being useful and I really don't want to put the stock one in...
Old 02-27-2013, 10:37 PM   #5417
Accurate Race Shop
Drives: Scion FR-S
I have the injen intake and some people had similar problems bogging down and stalling I got lucky and mine works great could be the ecu reacting to your intake in a weird way you could try stock and reset it and see what you get.
Sivtec (02-27-2013)
Old 02-27-2013, 10:44 PM   #5418
Sivtec
Sivtec's Avatar
Ill try this if it still isnt working in the next 50-100 miles.
