Old 02-27-2013, 06:05 PM   #1
Tye300
Tye300's Avatar
Drives: Toyota 86 TRD Version AT
Rear Foglight Enable
I'm not sure if the Scion wiring is really different, but here's what we got in 86es here in the Philippines. Thanks to HRTROB for figuring out the wiring, and Booch for showing me his car as an example. Thank you to AUTOKOZMETIX in Home Depot, Ortigas where we did the install.
This is a DIY on how to enable the rear foglight. The wiring is already in place, and it also has a dedicated relay in the fusebox. Do not hold me liable if things go wrong with your car, I'm only posting this on how we did it. As always, please disconnect your battery first before doing anything with the electrical stuff on your car. Here goes!
Tye300 is offline   Reply With Quote
The Following 17 Users Say Thank You to Tye300 For This Useful Post:
9k (02-27-2013), B-R-Z (06-22-2016), civicdrivr (03-08-2013), DAEMANO (01-21-2015), EndlessAzure (09-29-2022), Fly Guy (04-09-2014), GT86drifter (02-27-2013), LeeMaster (03-01-2013), Mr.Jay (03-04-2013), OmarGC (02-28-2013), pcuerpo (09-04-2013), Sargy (02-28-2013), sato (12-02-2014), SkullWorks (02-27-2013), skye67 (07-20-2014), Sportsguy83 (03-01-2013), Squishy86 (02-27-2013)
Old 02-27-2013, 06:51 PM   #2
g0lden
Drives: 2013 Scion FR-S Argento
Any idea if this works for USD spec FR-S?
I've cant recall seeing those fog light indicators when I turn the key to the second position. If it does work then I will be happy to do this mod for the extra bling it adds to the gauge cluster :-)
g0lden is offline   Reply With Quote
Old 02-27-2013, 07:05 PM   #3
GT86drifter
Drift Specialist
GT86drifter's Avatar
Drives: 180SX,GT86
finally a complete guide!! thank you!
edit: just checked the FR-S theres no wiring leading to this in the fuse box. once again F'd by scion goto make a harness on my own as planned
GT86drifter is offline   Reply With Quote
Old 02-27-2013, 07:19 PM   #4
Pedalincircles
Drives: FRS
I'm gonna wait for a vendor to sell a kit like this with a bright LED bulb. Awesome DIY post
Pedalincircles is offline   Reply With Quote
Old 02-27-2013, 07:20 PM   #5
Tye300
Tye300's Avatar
Thats the problem. I haven't seen an FR-S in person so I can't really tell. Sorry.
Old 02-27-2013, 07:44 PM   #6
Trashed675
Trashed675's Avatar
Drives: 2013 Ultramarine FRS
We also don't have a button or switch to turn them on if we had them installed. We FRS's would have to add that as well i'm guessing.
Trashed675 is offline   Reply With Quote
Old 02-27-2013, 08:36 PM   #7
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
Could be added using the same stalk that adds the fog lights switch, I believe.
kmbkk is offline   Reply With Quote
Old 02-27-2013, 10:05 PM   #8
Retro86
Retro86's Avatar
Drives: Awesome
it does have the fog light indicators if you look closely. it just doesnt activate because its not connected
Retro86 is offline   Reply With Quote
Old 02-27-2013, 10:08 PM   #9
Retro86
Retro86's Avatar
Drives: Awesome
thanks for the write up pare! astig!
The Following User Says Thank You to Retro86 For This Useful Post:
Tye300 (02-28-2013)
Old 02-27-2013, 10:11 PM   #10
Retro86
Retro86's Avatar
Drives: Awesome
only problem we have (frs) is that we dont have the proper stalk switch
Old 02-28-2013, 01:33 AM   #11
HRTROB
HRTROB's Avatar
Drives: Toyota 86
Good job Tye!
You can use the BRZ stalk however, Pin 2 (yellow wire) in the stalk connector is absent from the US spec cars. This wire goes to the BCU to trigger the rear fog relay and light up the rear fog indicator in the cluster. The white wire is for the front fogs; grounding this wire triggers the front fog indicators. You guys in the US will have to wire in a separate relay and figure out which pin in the BCU the yellow wire is supposed to go if you want the yellow rear fog indicator to light up in the cluster. I studied the US BRZ wiring diagram, the rear fog circuitry is completely absent
HRTROB is offline   Reply With Quote
The Following 5 Users Say Thank You to HRTROB For This Useful Post:
civicdrivr (03-08-2013), DAEMANO (01-21-2015), Plumbus (10-13-2020), Trap63 (03-19-2015), Tye300 (02-28-2013)
Old 02-28-2013, 01:42 AM   #12
HRTROB
HRTROB's Avatar
Drives: Toyota 86
Also forgot to mention that if you will be using the Euro stalk with the front and rear fog light switch, there is no need to splice or jump together pins 2 and 4 (yellow and white wires) in step 5. Everything will be plug and play. Jumping the 2 wires is only required if you have the stalk with the front fog light switch only, so you can turn the rear fog on and off along with the front fogs
The Following 4 Users Say Thank You to HRTROB For This Useful Post:
DAEMANO (01-21-2015), Fly Guy (04-09-2014), Retro86 (02-28-2013), Tye300 (02-28-2013)
Old 02-28-2013, 12:39 PM   #13
Lverasky
RedBunny w/ Wing
Lverasky's Avatar
great job..thanks you
The Following User Says Thank You to Lverasky For This Useful Post:
Tye300 (02-28-2013)
Old 03-01-2013, 03:10 AM   #14
DAFRS88
Drives: Hot Lava Scion FR-S
thanks for the amazing post =)
DAFRS88 is offline   Reply With Quote
The Following User Says Thank You to DAFRS88 For This Useful Post:
Tye300 (05-09-2013)
DIY Rear foglight Silverdub DIY (Do-It-Yourself) Guides 159 04-09-2018 12:14 PM
Is foglight wiring in the car? FastLap Scion FR-S / Toyota 86 GT86 General Forum 7 08-26-2012 11:54 PM
Rear Bumper Foglight kanundrum Cosmetic Modification (Interior/Exterior/Lighting) 2 06-08-2012 12:47 AM
