Old 02-26-2013, 12:07 AM   #15
Juurian
Juurian's Avatar
Drives: 2013 Scion FRS WhiteOut
Originally Posted by ParangWala View Post
I believe this was covered already under here...
http://www.ft86club.com/forums/showt...ght=tail+light
I have this same issue and I got the dealer to replace the lights but it came back, so I'm going back to get it fixed again since it's all covered under warranty. If you want you can have your dealer try to fix it via this TSB.
http://www.ft86club.com/forums/showthread.php?t=21868
yeah i heard about that TSB seeing how i dont own the car yet till early next month i did some research, does the tsb actually fix the problem?
Juurian is offline   Reply With Quote
Old 02-26-2013, 04:59 PM   #16
ParangWala
ParangWala's Avatar
Drives: 2013 SCION FR-S
I'm going to get the dealer to perform what is on the TSB and let you know, I wasn't sure if anyone else in that thread had any luck.
Also I am betting on the more of us that actually do complain and have dealerships order these parts to get them "repaired" the more attention it should get to Toyota to have these things fixed.
I mean if a big portion of the north american owners had to get these things replaced in assumption that the dealership has had to replace a set 2x that's four units purchased multiplied by a majority of owners....someone who's doing the books is probably wondering why they've had to produce so many tail lights in the last 3 months....again these are all my assumptions.
ParangWala is offline   Reply With Quote
Old 02-26-2013, 06:44 PM   #17
twincamRob
twincamRob's Avatar
Drives: 2013 FS FR-S
Originally Posted by White64Goat View Post
U
When I pulled my pass taillight out late last summer to drain the pool (about a half inch deep at the bottom) I left the bulbs in and rotated the lights around in all directions to see where it came back out. The only place it came out was around the bulb sockets themselves. No cracks or anything anywhere. Which is why the guy making his own thicker gaskets is having good luck last I saw.
As for the silicone, it will peel off the lights and body plenty easy. I've used the stuff tons in the past. Worst case I'll need to buy new gaskets at $10ea. Besides I really can't see any reason I'll ever want to take the lights back out again if this solves the issue...
Robbie S.
-13 FR-S
-12 H-D 48
Instagram: @twincamrob
twincamRob is offline   Reply With Quote
The Following User Says Thank You to twincamRob For This Useful Post:
Rayme (02-26-2013)
Old 02-26-2013, 07:14 PM   #18
ScionFamily
ScionFamily's Avatar
Drives: Magnetic Gray tC, Silver FR-S
I don't know if I am just lucky or not but I bought my fr-s in October and have yet to have any condensation!
ScionFamily is offline   Reply With Quote
Old 02-26-2013, 08:45 PM   #19
noc
I've had slight condensation in my tail lights and they usually disappear the next day. I took it to the dealership and they said they were going to order gaskets and fasteners per TSB 12-145-13 (SUBARU). I suppose this new TSB is what's overriding the tail light replacement per the TSB that was out last June.
noc is offline   Reply With Quote
Old 02-27-2013, 12:03 AM   #20
Juurian
Juurian's Avatar
and generally this is actually correct , because thats how TSB's are created basically problems that are consistantly showing up on the same vehicle, it basically gets recorded at the dealership and then once toyota sees a pattern they get the engineers to find out why things like this happen.
according to toyota its apparently the bolt torquing sequence that is incorrect that is causing the moisture build up in the tail lights. thats kind of interesting...
Old 03-02-2013, 02:22 PM   #21
ParangWala
ParangWala's Avatar
I read that in another tail light condensation thread too, apparently it causes the plastic to crack where the bolt has been tightened...but we will see as I am getting my lights replaced again for a second time next Saturday as the parts will be in by Wednesday but work is preventing me from getting it done sooner.
Old 03-07-2013, 03:15 PM   #22
DBee
That Guy
Drives: 2013 Scion FRS - Whiteout
I just had my lights replaced for the second time today. They showed me a new TSB (dated January 16th) explaining that they made a new gasket. I suppose time will tell if it works, but glad they at least attempted a permanent solution.
DBee is offline   Reply With Quote
The Following User Says Thank You to DBee For This Useful Post:
ParangWala (03-08-2013)
Old 03-07-2013, 03:35 PM   #23
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
The new TSB also says to flatten out the body (sheet metal) on page 4.
Mine had this done and there is no condensation now.
BRZ Taillights - What do you think about tinting them ? ShoGun Cosmetic Modification (Interior/Exterior/Lighting) 37 09-26-2014 03:26 PM
wtb stock taillights (scion frs) Dispect Exterior Parts (Aero, Lighting, Etc.) 12 01-23-2013 12:55 AM
Taillights idea adprokid Cosmetic Modification (Interior/Exterior/Lighting) 25 09-16-2012 01:40 AM
Moisture in lights Sileighty_guru BRZ First-Gen (2012+) — General Topics 12 08-30-2012 10:22 PM
Red tinted taillights FreedE Cosmetic Modification (Interior/Exterior/Lighting) 16 07-24-2012 04:37 PM
