Old 02-12-2013, 08:34 PM   #43
robispec
Drives: Black frs project
Tire sizes? I'm mostly curious about the RS3 vs NT01 at BRP13CW.
Fixed
for the lazy
Streets CW 1:26.2 RS3's245/40/17
Streets CCW 1:26.5 RS3's245/40/17
Streets CW 1:25.2 A6 Hoosiers 225/40/17
Streets CCW 1:25.3 A6 Hoosiers 225/40/17
WSIR 1:35.1 RS3's245/40/17
BRP #13 CW 2:04.1 RS3's245/40/17
BRP #13 CW 2:03.1 NTO1 225/45/17
MRLS 1:48.3 RS3's245/40/17
robispec is offline   Reply With Quote
The Following User Says Thank You to robispec For This Useful Post:
Anorexic 86 (02-13-2013)
Old 02-12-2013, 09:55 PM   #44
CSG Mike
CSG Mike's Avatar
Originally Posted by robispec View Post
Fixed
for the lazy
I like being lazy
Old 02-13-2013, 05:02 AM   #45
Anorexic 86
Trim the Fat & add Boost
Anorexic 86's Avatar
Drives: sometimes I fly
I noticed the front fenders are higher and farther out than the rest of the car... is the front frame deforming under hard track abuse?
Anorexic 86 is offline   Reply With Quote
Old 02-13-2013, 09:11 AM   #46
robispec
no I didnt roll the fenders and the tire is doing this for me! as the fender streches it goes up and out at the door
Old 02-13-2013, 09:37 AM   #47
Anorexic 86
Ok good... was worried for a minute and started looking for my spot welder.
Thanks again for pushing this thing so hard and documenting your progress.
Please let us know if you are coming back to MRLS which is in our back yard.
Cheers
Old 02-13-2013, 01:15 PM   #48
robispec
This chassis is STRONG! my front sway bar is tracking a bit high even with shorter endlinks and was touching at the pinch weld....standing seam on the lower chassis. So I get our trusty ford tool out and hit it..nothing! 2 lb sledge not doing much 5 lb sledge and some muscle and was finally able to move it ever so much to clear the new sway bar arc! High strength steel is just what they say!
The Following 2 Users Say Thank You to robispec For This Useful Post:
CSG Mike (02-13-2013), NorCalRider (03-30-2013)
Old 02-24-2013, 02:16 AM   #49
robispec
FTD at Speed Ventures 86 challenge and FASTEST TIME BY ANY TRIPLET boosted/swapped/NA at Autocenter Speedway Fontana CA 1:56.8xx
http://www.ft86club.com/forums/showt...717#post753717
The Following 4 Users Say Thank You to robispec For This Useful Post:
03Z33 (02-24-2013), heeltoe86 (02-24-2013), juliog (03-04-2013), NorCalRider (03-30-2013)
Old 02-24-2013, 03:14 AM   #50
mobybrz
Drives: White 2013 BRZ
any thoughts on selling the front arms or whatever roll center correction you are using? (it looks like extended ball joints)
mobybrz is offline   Reply With Quote
Old 02-24-2013, 08:30 AM   #51
robispec
yes soon I test the hell out of parts I like the math this will work with plenty of reserve safety part but then we go out and try to find the weaknesses and change them.
We also work through the range of adjustments to see if they actually provide you with USEABLE adjustments! Ha what a concept lol
CU@ the track! (be sure and ask for a ride) "OH WHAT A FEELING"
The Following 7 Users Say Thank You to robispec For This Useful Post:
Anthonytpt (03-01-2013), CSG Mike (02-27-2013), mobybrz (02-26-2013), NorCalRider (03-30-2013), solidONE (06-27-2013), whataboutbob (02-24-2013), zoomzoomers (05-16-2013)
Old 02-25-2013, 04:18 PM   #52
Crossover Auto
Drives: FR-S, BR-Z, 86
Looks like the Mfactory final drive worked out well for you.
Crossover Auto is offline   Reply With Quote
Old 02-25-2013, 04:34 PM   #53
robispec
Yes car kept accellerating through turn 1&2 in sixth gear wouldent do that before
Full writeup to follow.
ill86 (02-25-2013)
Old 02-26-2013, 11:00 PM   #54
AlvinT@Borla
Drives: vw mk4 r32
Let me know when you drive MRLS Robi. I'll have (2) Borla clamp-on 90-degree elbows to fit over your tips.
Keep in mind your setup with Borla EL Header (PN-17285) + catless Mid-Pipe (PN-60541) + Cat-back (PN-140496) registers a higher dB(A) @MRLS than
Borla UEL Header (PN-17284) + Cat-back (PN-140496).
AlvinT@Borla is offline   Reply With Quote
Old 02-27-2013, 12:42 AM   #55
robispec
yes I could tell that because when I went through in 3rd at 7000 rpm the reading given to me was 98db and later in 4th (shifting right before the meter) listed me as 97. My getto aluminum 90's got me through at 92db but I could not keep them on!
Old 02-27-2013, 05:21 PM   #56
RAWR BRZ
Drives: 2010 BMW M3, 2013 Subaru BRZ
I saw your car today on harbor and adams right by OCC lol. I thought wow someone with a super modded frs at OCC...what?? 777 on the back?? This guy tracks too!! Then while I was turning in I saw the Robispec sticker/logo and it all made sense haha. sick car btw
RAWR BRZ is offline   Reply With Quote
Canu_50's FR-S Time Attack, drift car!! canu_50 Member's Car Journals 28 12-05-2013 02:04 AM
My FR-S In Time Attack Mode!! track_warrior FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 12 09-25-2012 02:13 AM
Ontario Time Attack - TMP July 7th 7thgear CANADA 8 07-07-2012 06:14 PM
Vancouver auto-cross, time attack.. ? EsoBOFH CANADA 4 06-20-2012 03:23 PM
Tsukuba time attack review in the Car Top magazine yajin FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 5 05-18-2012 05:12 PM
