Old 02-10-2013, 05:54 PM   #29
Kuzuri
__(X)__
Kuzuri's Avatar
Drives: '11 Legacy, '89 190E, '78 GS1000
Just ordered a g37 antenna. Thanks for the info! Love the look!
Kuzuri is offline   Reply With Quote
Old 02-12-2013, 05:27 PM   #30
Chaetagnath
Drives: Whiteout FRS
Do you have a link where you ordered yours from?
Chaetagnath is offline   Reply With Quote
Old 02-19-2013, 01:12 AM   #31
stea1thbear
Drives: Scion FR-S Firestorm
Bump.
stea1thbear is offline   Reply With Quote
Old 02-24-2013, 02:43 PM   #32
NemeGuero
Its not as easy as repinning the connector because the wire on the g37antenna doesn't reach the factory connector plug. Its too short. Other then that, I just removed the g37 connector altogether and plugged the pin straight into the OEM connector.
NemeGuero is offline   Reply With Quote
Old 02-24-2013, 06:37 PM   #33
Lonewolf
Lonewolf's Avatar
Drives: Moped
How is the functionality/reception?
Old 02-24-2013, 06:53 PM   #34
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
Been searching... Where can I get one for said price?
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Old 02-24-2013, 07:23 PM   #35
Burrcold
Drives: Subaru BRZ Limited
Originally Posted by xjohnx View Post
The BRZ GPS antenna is in the dash, i believe (at least judging by the TSB info). The reason the BRZ's base is wider is because of the Satellite radio antenna.
This is correct. That's why the Canadian BRZ's antenna base is the same size as the FR-S base (we don't get sat radio with our Navi - different HU).
Old 02-24-2013, 11:48 PM   #36
NemeGuero
Seemed good enough. I don't really listen to the radio much but I skipped around a bit on the stations and decided it would work for me.
The Following User Says Thank You to NemeGuero For This Useful Post:
Lonewolf (02-24-2013)
Old 03-02-2013, 02:01 PM   #37
NemeGuero
I changed my mind, radio sucks ass with the antenna. Seemed okay in the garage but driving around the other day, with a dead battery on my cell phone, it was horrible.
I'm thinking maybe that extra ground wire needs to be connected.
The short one up top is the old G37 wire that was too short.
You can see where I spliced in the factory FRS coax.
That connector is the factory connector.
The skinny little wire (I assume to be a ground) went inside the FR-S antenna and soldered to the circuit board.
I tried to find a ring terminal big enough for me to ground that wire to the main antenna bolt but it didn't fit and I didnt' care enough to find another one.
Lonewolf (03-02-2013)
Old 03-14-2013, 04:47 PM   #38
CrazyWookiee
Drives: Whiteout FR-S
Sorry to bring up an old thread. Really want this flat profle antennae, did you get the reception issue resolved? Has anyone made a similar replacement for the market yet?
"I'm the real Peter Lau" - Peter Lau
CrazyWookiee is offline   Reply With Quote
Old 03-14-2013, 05:24 PM   #39
NemeGuero
I did not, and honestly will probably not get around to it for a while.
Old 03-14-2013, 08:33 PM   #40
Xdragonxb0i
Drives: ex500r
just do the antenna delete, (DIY screw in plug) then put a non fuctional Fin on top of it
Xdragonxb0i is offline   Reply With Quote
Old 04-04-2013, 06:16 AM   #41
markmatley
Shipping to Hawaii?...
markmatley's Avatar
Drives: '13 Asphalt FR-S
Im going to attempt to transfer the frs antenna board and cable into the gtr housing, only if i cant find a grounding wire point for the gtr antenna board. Without a good ground the bluetooth phone reception and radio suffer. Or does BT have an antenna somewhere else?
Will keep you all updated this weekend.
~Matt
Efimia (asphalt FRS)
markmatley is offline   Reply With Quote
Old 04-07-2013, 06:46 PM   #42
markmatley
markmatley's Avatar
This is true! Its much easier to install the FRS antenna electronic module into the G37 case.
So if you take apart the FRS antenna, you get:
If you try to pull the antenna wire after you unscrew the circuit board, you'll notice that a copper sheath (the ground of the antenna coax) is soldered directly to the metal frame of the antenna base: (the metal tab with the purple or red ink is the tab you need to desolder off the board before you can have access to desolder the ground from the antenna base)
Heres a front view after desoldering the tab:
Once this tab is gone, you can desolder the ground copper sheath off the antenna base, pull back prongs that hold the antenna wire to the base, and slip the wiring through.
Next take apart the G37 antenna. The hardest part about disassembly is getting the metal base off the painted shell. I used a small plastic tab remover and worked my way around it prying from the pointed end of the antenna. take your time or you might snap a tab (which I did) and then you'll have to superglue the bad boy back to keep the antenna assembly from rattling.
Heres what it looks like disassembled:
Finally you can save or chuck the G37 antenna module, and then place the FRS one into the slot but you have to screw it down a different angle. But it fits!
Dont forget to solder the ground to the metal base. See the blob of solder near the number 779 in the above photo!
Reassemble and fire up the radio! Enjoy!
Functionality is perfect once you ground the outer copper sheath to the G37 metallic frame.
~Matt
The Following 6 Users Say Thank You to markmatley For This Useful Post:
Assunta (04-23-2014), calis5nest (06-02-2014), civicdrivr (04-08-2013), CrazyWookiee (04-08-2013), Lonewolf (04-07-2013), turbos86 (04-09-2013)
Tom's antenna shark fin Hanzo Cosmetic Modification (Interior/Exterior/Lighting) 15 10-28-2012 12:44 PM
Flat black BRZ BRZranger Cosmetic Modification (Interior/Exterior/Lighting) 6 06-27-2012 03:23 PM
Flat Black BRZ Toods BRZ First-Gen (2012+) — General Topics 4 06-20-2012 12:25 AM
Beat-Sonic USA Shark Fin Antenna for Subaru BRZ, DOES NOT FIT! xcelir8brz Electronics | Audio | NAV | Infotainment 2 06-04-2012 11:44 PM
I'm going to try my hand on a flat 4 4agze Other Vehicles & General Automotive Discussions 2 04-08-2011 07:46 PM
