Old 02-22-2013, 05:43 PM   #169
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
For those of you who installed these, before installing the longer front left and right panels you had to remove 4 plugs along each side closer to the rocker panels. Did these plugs have protective anti-chip/anti-rust sprayed over them? So you had to peel away that paint to remove these plugs, right? Did you leave the metal around those holes exposed when installing the panels?
Old 02-22-2013, 05:45 PM   #170
Ro_Ja
Drives: TOYOTA
Yes. I used an x-acto knife to carefully cut away at the coating just enough to remove the plugs.
Ro_Ja is offline   Reply With Quote
The Following User Says Thank You to Ro_Ja For This Useful Post:
switchlanez (02-22-2013)
Old 02-22-2013, 08:06 PM   #171
ayau
Drives: Some rust bucket
I'd go one step further and paint the exposed metal with some tough up paint.
Old 02-23-2013, 06:13 PM   #172
ayau
How do you pull the side flips off? They seem to be on there pretty tightly.
Old 02-23-2013, 06:25 PM   #173
Ro_Ja
Drives: TOYOTA
Clips*?
You can use a flathead screwdriver and pilers to yank and twist the hell out of them since they won't be going back anyway.
Or you can buy this:
http://www.oreillyauto.com/site/c/de...5260/N1693.oap
which is what I did (after cursing up a storm trying to do the job with pilers [which worked but was taking too long and was uncomfortable for me since I barely squeezed under the car]) and had each clip off in a matter of seconds.
chanomatik (02-23-2013)
Old 02-23-2013, 07:10 PM   #174
ayau
Clips*?
The clips don't snap off. They just bend lol. I have the same metal tool.
Old 02-23-2013, 08:49 PM   #175
ayau
Here are some pics. I still can't get them to come off.
Old 02-23-2013, 11:40 PM   #176
Hanakuso
Using a flat scredriver is a PITA, I only removed one with it and had enough, went and bought the plastic remover tool. You have the same tool Roja linked?
I got a flat screwdriver and removed the foam that was still attached to the plugs on the bottom of them. I found it much easier removing the plugs when they were totally clean of paint/foam. I also wrapped the plastic remover tool with electric tape so it didn't scratch up anything
Hanakuso is offline   Reply With Quote
Old 02-24-2013, 02:08 AM   #177
switchlanez
I scraped off the paint first, then I picked out the foam washer from under the pin, then I'd gently pry the pin just to peak while rotating it little by little til I could see a bit of one of the 2 locking wings (is that the word? see my basic illustration below) were. Once I spotted a wing, I pressed on it with a flathead (which partially "unlocks" it) while pulling down on the pinhead with pliers. With enough wiggling, I'd get most of that wing and center pin out and exposed. Then I'd wiggle violently to make the other wing bend and give way for the rest of the pin to come completely out. This method took me me about a 2-5 minutes per pin.
___
\|/ <-- "Locking wing" on left and right side of pin
The Following User Says Thank You to switchlanez For This Useful Post:
ayau (02-24-2013)
Old 02-24-2013, 02:23 AM   #178
ayau
___
Unfortunately I didn't see these "wings" until i practically shredded off the first clip. I did mar up the surrounding paint pretty good but added some touch up paint. Fortunately the panels cover more than enough of the exposed holes.
Old 02-25-2013, 04:01 AM   #179
phatpanda
phatpanda's Avatar
Drives: Scion FR-S
How much and where to buy?
phatpanda is offline   Reply With Quote
Old 02-25-2013, 06:27 AM   #180
cslntuee
Drives: Subaru BRZ Limited
It sounds like not a easy job.
Did they come with instruction guidance?
Thanks.
cslntuee is offline   Reply With Quote
Old 02-26-2013, 03:12 AM   #181
Hanakuso
Thanks.
No instructions but not needed. Straights forward installation, yet the clips can be a pain.
The Following User Says Thank You to Hanakuso For This Useful Post:
cslntuee (02-26-2013)
Old 04-01-2013, 04:24 PM   #182
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Has anyone weighed the panels on a scale? For $1000 shipped, I think I can fabricate something out of aluminum for much less, but curious of the weight. I'd want to make it lighter if possible, or go a different direction by adding bracing to increase chassis rigidity if it can't be made lighter with metal.
Brz Limited Avalable (currently wait listed, but soon. This is not an add.) Floggin Tires Great Lakes 2 09-25-2012 01:13 AM
Japanparts.com Review Sportsguy83 User/Vendor/Sponsor Reviews, Feedback, Comments 7 08-03-2012 09:23 AM
Cars.com has BRZ's listed??? Rick Boxx BRZ First-Gen (2012+) — General Topics 0 05-13-2012 02:36 PM
Listed on Autotrader (US) cassidy0998 Scion FR-S / Toyota 86 GT86 General Forum 3 02-02-2012 11:16 AM
FR-S Officially Listed on the Scion Site goshamrocks13 Scion FR-S / Toyota 86 GT86 General Forum 32 10-07-2011 11:52 AM
