Old 11-14-2011, 05:47 AM   #491
Nuieve
Drives: Miata
There's NO WAY this car will be under 6 sec 0-60. NO FARKING WAY.
6.2-6.5 best (extreme guys like Motor Trend will probably do it), but most of you will probably get it in 6.8-7.2 range.
I bet most of S2000 sub 6 sec runs were from clutch dump at 9000rpm.
Nuieve is offline   Reply With Quote
Old 11-14-2011, 08:08 AM   #492
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by serialk11r View Post
Isn't rolling start typically faster than launch?
Nope. Launch is faster. 5MPH rolling start = very very little torque compared to a 4500RPM clutch drop.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 11-14-2011, 11:12 AM   #493
tripjammer
tripjammer's Avatar
Drives: WRB BRZ limited 6MT
Whoa dawg calm down...
There are some stock S2000 0 to 60 runs in the mid 5 sec range.
Car and Driver got a 5.4 secs 0 to 60
http://www.caranddriver.com/reviews/...t-specs-page-2
Maybe these are ringer cars...but
We will have to see what kind of gearing the FR-S has. What kind of traction it has and what kind of power it is putting down to the ground.
Here is another one..and you know how crappy the gearing is in the Genesis coupe...
http://en.wikipedia.org/wiki/Hyundai_Genesis_Coupe
2010 Genesis coupe 2.0 Turbo track, 6 speed manual
Weight is 3294 pounds
HP is 223HP Torque is 217 ft/lbs
Power to weight ratio is 14.77 to 1
0–60 mph performance records of 2.0 I4
  • Motor Trend review 0-60 : 6.8 sec [24]
  • Edmunds review 0–60 : 6.9 sec [17]
  • Car and Driver review 0–60 : 6.8 sec [25]
  • Car and Driver road test 0-60 : 7.0 sec [8]
tripjammer is offline   Reply With Quote
Old 11-14-2011, 12:52 PM   #494
Aki
Drives: '96 beater Corolla
Originally Posted by tripjammer View Post
To put speed into perspective...
2012 scion tC stock 6 speed manual..0-60mph in 6.5 secs. Weight is 3060 pounds. Hp is 180 and torque is 173 ft/lbs......power to weight ratio is 17 to 1
2013 FRS 6 speed manual high spec is 200 hp and 151 ft/lbs torque. Weight is 2711 pounds. Power to weight ratio is 13.55 to 1
Unless they screw up the gearing...the FRS could be a mid to upper 5 secs 0-60 mph car.
There's no way the TC could get 6.5 sec 0-60 with that power and weight. That's around the GTI/Civic Si figures, but with less power and more weight.
FR-S will be a 6-second flat 0-60 at best.
Aki is offline   Reply With Quote
Old 11-14-2011, 03:07 PM   #495
tripjammer
tripjammer's Avatar
That is still faster than the 2012 tC...The tC was clocked at 6.5....sure it was probably a ringer car....but 6.0 secs to 60 in a FRS is good enough for me.
Old 11-14-2011, 03:20 PM   #496
Hasjwandje
Drives: Audi A3 2.0 FSI
im pretty sceptical about 0-100 km/h in 6 seconds... If you look for instance at the renault clio it has same power 200hp and 158 ft lb / 215 nm and less weight 2600lbs / 1180 kg it does it in 6.9 according to renault. However you will have to change gear spot on so most do it in 7.2 seconds.
I know it's not only a matter of power and weight but the gearing is pretty good in the renault.
Only thing that's really different is front wheel drive and rear wheel drive,
so does having rear wheel drive benefit that much when it comes to acceleration?
Hasjwandje is offline   Reply With Quote
Old 11-14-2011, 04:20 PM   #497
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
The ITR did it in ~6 with similar power and weight as the FT. With a good driver and sticky street tires I know a few that ran 13.9-14.0s with stock ITRs which is a mid to high 5.x 0-60. Sounds like the Renault's gearing sucks, or just the power under the curve is atrocious.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 11-26-2011, 01:36 PM   #498
NikostC
JDM Enthusiast
NikostC's Avatar
Drives: Scion tC
Originally Posted by Harinjo View Post
in germany minimum octane is 95 (E10) (my s14 got only 100 octane) -
therefore the engine should have around 210hp/220nm here
That is possible... and 151 torque seems about right but i suspect it might have been a typo when they said peak torque is at 6600rpm. it must have been more like 5600rpm
NikostC is offline   Reply With Quote
Old 12-02-2011, 03:23 PM   #499
starbai
starbai's Avatar
Drives: 2011 Mustang 5.0 GT
guys i am a noob on the forum and did some searching, but I dont seem to see any mention of a sunroof for any of the 3 versions of the cars or their trim levels.
has anyone heard anything about one being available? or is it too much weight/not stiff enough for a car of this nature?
starbai is offline   Reply With Quote
Old 12-02-2011, 03:28 PM   #500
Syldrin
Troll Feeder
Syldrin's Avatar
Drives: boosted scion tc.
no sunroof the roof was designed to channel air to the trunk. a sunroof would ruin that design
Syldrin is offline   Reply With Quote
Old 12-02-2011, 03:49 PM   #501
starbai
starbai's Avatar
rats... I've never had car without a sunroof or being convertible... I hate that closed off feeling.
Oh well gotta make concessions I guess and there's always the aftermarket.
Old 12-02-2011, 03:54 PM   #502
Syldrin
Troll Feeder
Syldrin's Avatar
dunno after having an all glass roof i think i will be just fine with a nice solid roof that doesnt let a bunch of heat in during the summers.
Old 12-02-2011, 04:02 PM   #503
starbai
starbai's Avatar
I dunno, I use mine all the time, esp here in South Florida its a really nice feature to have on a nice day.
Being from Cali I'm sure you can relate to an extent.
Its of course not a deal breaker. But a small aftermarket one is definitely in the cards for any future BRZ/FR-S that I may purchase.
Probably gonna hit that antenna... but will have to put a shorty on or something.
Ford doesn't offer a sunroof on the Mustang and I went about 8 months before I gave in and just had one installed. Couldn't deal without having one anymore lol. Aftermarket of course isn't as perfect as factory as its not as big as the ones I've had in the past... but its electric, no leaks at all, looks factory for the most part over all does the job very well for me.
I know I'm in the minority as most of you guys will be buying this car for nothing but sheer performance. For me I love how it looks, like having good power in my daily and want something comfortable too with a few creature comforts. For that reason the Subie version looks like it would be more suited to me.
So I can definitely picture in my head what my goals are for this thing if I picked one up for DD duty.
Old 12-02-2011, 04:08 PM   #504
Snoopyalien24
Mr. Sarcasm
Snoopyalien24's Avatar
^^Ey Ft. Liquordale lol I love our weather, but I prefer windows down IMO
Snoopyalien24 is offline   Reply With Quote
brz forum, brz forums, brz specs, brz sti forum, fr-s review, fr-s specs, frs review, frs reviews, ft-86 review, ft-86 specs, ft86 forum, ft86 forums, ft86 specs, scion fr-s, scion fr-s forum, scion fr-s horsepower, scion fr-s hp, scion fr-s review, scion fr-s reviews, scion fr-s specs, scion fr-s weigh, scion fr-s weight, scion frs, scion frs forum, scion frs review, scion frs specs, subaru brz, subaru brz forum, subaru brz forums, subaru brz horsepower, subaru brz hp, subaru brz specs, subaru brz sti, subaru brz sti forum, toyota ft-86, toyota ft-86 forum, toyota ft-86 horsepower, toyota ft-86 hp, toyota ft-86 review, toyota ft-86 specs
AutoBild gives specs of the Subaru BRZ Ice_Man BRZ First-Gen (2012+) — General Topics 43 10-30-2011 06:43 PM
Guessing Scion FR-S specs?? dClutch Scion FR-S / Toyota 86 GT86 General Forum 58 04-28-2011 11:07 PM
If there is no Toyota will you go with Scion or Subaru tranzformer Scion FR-S / Toyota 86 GT86 General Forum 91 04-25-2011 11:53 PM
200hp / 2700lbs - Really? Rickster Scion FR-S / Toyota 86 GT86 General Forum 385 04-18-2011 02:47 PM
TRD options and Badging? BanningFT Scion FR-S / Toyota 86 GT86 General Forum 43 11-08-2009 03:53 AM
