Old 02-20-2013, 10:49 PM   #15
Coastermikey
Drives: BRZ DGM
im interested, dumb question tho, do they normally come without markings?
Coastermikey is offline   Reply With Quote
Old 02-20-2013, 11:04 PM   #16
Ryephile
Hot Dog
Ryephile's Avatar
Drives: quicker than arghx7
Nice looking plates.
*How much caster is added?
*Other spring perches for typical spring sizes [2.25", 2.5", etc.] available?
*no graduations for camber change? Are the cars too variable to bother with graduations?
*Spherical bearing; impress me with sweet words. Will it survive a rust-belt winter like Vorshlag's do?
"Wisdom is a not a function of age, but a function of experience."
Just Say No to unqualified aftermarket products.
Ryephile is offline   Reply With Quote
Old 02-20-2013, 11:07 PM   #17
Phaedrus29
Phaedrus29's Avatar
Drives: 2013 Subaru BRZ
Just to clarify...will these work with the stock struts?
Phaedrus29 is offline   Reply With Quote
Old 02-21-2013, 10:32 AM   #18
Racecomp Engineering
Originally Posted by jamal View Post
I hope @Racecomp Engineering doesn't find out about these.
While the overall shape is very similar to our RCE camber plates that we've had for a couple years, there are enough differences that it's okay.
Our RCE plates do lower the car without sacrificing bump travel, whereas these just don't raise the car.
In the end it's good to see another option and these do look like a high quality camber plate.
- Andrew
SkullWorks (03-19-2013)
Old 02-21-2013, 10:45 AM   #19
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
These make me wish I hadn't gotten the Whiteline Com-C's. Going on 6 months STILL waiting on warranty replacement on those. Rattling from bad geometry without conical upper spring perch washers and deforming rubber from bad bearings....
Old 02-21-2013, 02:47 PM   #20
wparsons
wparsons's Avatar
- Andrew
Do you have upper perches for stock springs, or just for coilovers?
flickr
Old 02-21-2013, 02:50 PM   #21
Ours use the stock springs perches for springs and for coilovers you use the perches that the coilovers come with.
/threadjack.
- Andrew
Old 02-21-2013, 03:32 PM   #22
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
so these dont raise-is that the only way how are these different than what Whiteline/Vorschlag-are we to understand this meaning that those designs raise the car?
please clarify
How about the GC or the Hotchkis plates, do those raise the car too?
had no clue one needed to be aware of this! thank you
Huehuecoyotl is offline   Reply With Quote
Old 02-21-2013, 03:48 PM   #23
jamal
jamal's Avatar
Drives: Legacy GT
The whiteline offset top mounts do not raise the car. I don't believe the Ground control camber plates will either. It's the standard camber plate design like this:
The plate sits under the shock tower, and then the bearing housing is below that so everything is farther down. This also results in less bump travel, which, in the case of a coilover setup is generally compensated for with more spring rate.
Regardless of the suspension setup you are using it is better to use a plate like TIC's or RCE's or Ground Control, especially if the car is low.
jamal is offline   Reply With Quote
The Following User Says Thank You to jamal For This Useful Post:
GC_Adam (02-21-2013)
Old 02-21-2013, 05:02 PM   #24
Phaedrus29
Phaedrus29's Avatar
I think the Whiteline top mounts don't allow for camber adjustment. I have the RCE Yellows on stock struts, and I'm currently adjusting camber up front with the crash bolts. But with my current setup, I really don't have much clearance at all between my Volks and tires and the stock bottom spring perch.
If the crash bolt slips on one side it would probably be BAD. So I've been looking for some way to adjust camber up front that would allow me to use the fixed (non-camber) strut bolts...to gain a little clearance and stability. I don't think there was any option available that could be used with the stock struts and that didn't increase ride height. So it looks like these TIC plates are exactly what I've been looking for!
Old 02-21-2013, 06:36 PM   #25
GC_Adam
GC_Adam's Avatar
Drives: '08 Impreza, 03 SV1000S
please clarify
No, Our camberplates do not raise the car. They actually give back some of the bump travel lost when you lower these cars.
In the pic the green line represents the fender...Now see how we've moved the upper spring seat and strut mounting point further up effectively giving back bump travel lost when lowering your car.
With other mass-produced off shore camberplates that mount flat from the bottom you end up losing valuable stack height and bump travel.
GC_Adam is offline   Reply With Quote
The Following 6 Users Say Thank You to GC_Adam For This Useful Post:
Black Tire (03-01-2013), DAEMANO (01-26-2014), Huehuecoyotl (02-22-2013), nix (09-05-2013), ranisron (02-22-2013), Spaceywilly (03-01-2013)
Old 02-21-2013, 11:07 PM   #26
Phaedrus29
Phaedrus29's Avatar
It doesn't appear that you can use these camberplates with stock sized springs or RCE yellows though, right?
Old 02-22-2013, 01:11 AM   #27
sw20kosh
Drives: 2013 Black FR-S
I'd really like to know which camber plates besides the Hotchkis and AST work with stock suspension. @Racecomp Engineering
AST: http://86tech.com/forums/showthread.php?t=93
Old 02-22-2013, 01:30 AM   #28
Nitro22
Nitro22's Avatar
Drives: Scion FR-S (Hot Lava)
please clarify
Hi Huehuecoyotl,
Hotchkis Camber Plates do not raise the car. You do not lose any bump travel. This was a major consideration when they designed them. The bearing bucket resides above the strut top surface, but the plate portion is mounted underneath the strut tower. This will allow the customer to use any strut brace as well. Everything made in the USA btw. =)
Cheers,
-Aaron
Nitro22 is offline   Reply With Quote
Which camber plates are you running? Coastermikey Suspension | Chassis | Brakes -- Sponsored by 949 Racing 43 02-15-2014 10:26 AM
MSI Camber plates wootwoot Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 11-29-2012 07:16 AM
Camber Plates delusional Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 10-30-2012 08:17 PM
Camber plates Captain Snooze AUSTRALIA 7 07-02-2012 06:51 PM
