Old 02-21-2013, 08:53 AM   #15
mikeg7827
mikeg7827's Avatar
Drives: 1995 Ford Probe
you shouldnt have tried to fix it before contacting the company that sold you the exhaust or hks customer service.
imo i would have just returned it back to the company you bought it from asked for a full refund and bought a different brand exhaust especially if the company is an authorized retailer they should stand behind their product.
mikeg7827 is offline   Reply With Quote
Old 02-21-2013, 09:29 AM   #16
armythug
armythug's Avatar
Drives: Pegasus White 86GTS
Wow
Pegasus White 6MT got it. :happy0180:
armythug is offline   Reply With Quote
Old 02-21-2013, 09:35 AM   #17
Cheddar
Saving them pennies...
Everything is this world has a failure rate. Noting is always 100%, companies can try but it will never be 100%. For this reason is why products have warranty.
Cheddar is offline   Reply With Quote
Old 02-21-2013, 10:09 AM   #18
norsamerican
norsamerican's Avatar
Drives: WRB BRZ
Should have put the stock exhaust back on shipped it to whoever sold it and let them fix it for you. Now your out 150 bux on top of the cost of the exhaust and all thats going to happen is its going to crack again in a different and/or same location.
Old 02-21-2013, 10:33 AM   #19
JETRED
JETRED's Avatar
Drives: Unicorn
OUCH!! Is Toronto road salt that corrosive?!
You probably shouldn't of fixed it yourself cause it looks like poor quality control on HKS; just putting a bandaid on a broken leg... :c
JETRED is offline   Reply With Quote
Old 02-21-2013, 10:50 AM   #20
Ingen
Drives: Ultramarine FR-S 6MT
Salt won't crack stainless all by itself.
The middle-of-weld cracks in the first pic are probably due to residual stress, not filling the weld enough, or using the wrong filler metal for the application. It's a localized stress problem.
Judging by how the weld metal is all piled up in one spot and the other piece is completely disconnected (the resonator in the 2nd to last pic) I would say that one is a lack of fusion. It's not like it broke, it just never really fused and stuck. So it came apart on that seam.
What's even more exciting is that *everyone else who has this exhaust* will probably have this problem, as well. it's not like they had one rogue welder grab some half-assed filler metal to do the welds on JUST YOUR EXHAUST.
Other people who own this thing should be checking theirs.
edit: Gotta say, as big as some of those cracks are... I can't believe they aren't leaking. I mean that 2nd to last pic it's COMPLETELY UNCOUPLED. What the hell.
Car Received: 10/18. Break in ended: 10/28
Goal: Openflash UEL headers, Stage II 93 oct, TRD intake, arm rest :P
Ingen is offline   Reply With Quote
Old 02-21-2013, 02:08 PM   #21
jumbaco
jumbaco's Avatar
Drives: FD
Sucks to hear man. HKS doesn't have a US office anymore right? At least you're back on the road.
jumbaco is offline   Reply With Quote
Old 02-21-2013, 02:33 PM   #22
bigjake
Drives: 2013 Scion FR-S, Firestorm
So glad I have a Perrin.
bigjake is offline   Reply With Quote
Old 02-21-2013, 04:27 PM   #23
GregV
Drives: Kia Stinger GT2
Going to have to check mine, haven't heard any leaks but this is disconcerting.
GregV is offline   Reply With Quote
Old 02-21-2013, 05:29 PM   #24
Skurj
Drives: SOLD...
Hmm... well at least I didn't have HKS on my short list for an exhaust system! Now its completely off all lists..
Send HKS a link to this thread.
WRB MT BRZ Sport Tech Delivered March 21 2013 Its mine now!!
Paid for Mar 2018
and its gone... Sept '18 tho I am sure I will miss it
Replaced with 18 50th edition ND
Skurj is offline   Reply With Quote
Old 02-21-2013, 07:29 PM   #25
driver01
Drives: brz 13
Let us know if you find anything wrong, hopefully you will be in the clear.
Which exhaust do you have?
can anybody source the information for hks, or who to contact?
I would appreciate the help, thanks
driver01 is offline   Reply With Quote
Old 02-21-2013, 07:31 PM   #26
GregV
Same as yours - Hi Power Spec L with the carbon tips installed in September. I've noticed the oxidation on the screws on the tips but haven't looked under the car since putting the snow tires on.
I'll give it a look this weekend.
Old 02-21-2013, 07:56 PM   #27
wu_dot_com
Drives: accord
the leak seems like a result of poor workmanship. The wield beads are uneven and intermittent. In addition, they also grind down the wield in the sounding joint area which you should never do.
The interesting thing is where the crack is. From the looks of it, the crack is away from the wielded zone. However, the crack location is at the high stress header area. From the looks of it, it seems like a fatigue vibration induce crack.
Typically, those exhaust headers are either made by draw or spun from a disc of sheet metal. Therefore anytime where you have aggressive geometry change, without proper manufacturing technique, the profile change area would become too thin to carry the vibration load which will later become a stress concentrator.
if you have cracks on the wield, then its most likely due to the fact that they grind off the wield beads.
This could either be a manufacturing issue or a design issue. But judging from the quality of this finished part, I would think this is more of a workmanship and quality issue.
wu_dot_com is offline   Reply With Quote
Old 02-26-2013, 03:30 PM   #28
Tradewind
Drives: 2006 Subaru Liberty EZ30 S/charged
That is an amazing design - extremely interested in that and would certainly choose it if I was buying. However, there is a real problem there with the metal quality and/or welding, that situation is likely to keep reoccurring. The system needs a fraction more flex in it to the metal is not so stressed
Toyota 86 test driver
Tradewind is offline   Reply With Quote
Paint Cracking? Heero Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 46 01-29-2014 12:53 PM
HKS Catback Exhaust Group Buy - Legamax Premium Exhaust & Hi-Power Spec L Catback FT-86 SpeedFactory Groupbuys 11 10-21-2012 08:59 PM
HKS hi-power spec L exhaust prest1ge Engine, Exhaust, Transmission 15 10-12-2012 12:16 PM
T1R 70R Power exhaust Prototypes ! AJ PwR Engine, Exhaust, Transmission 43 09-19-2012 02:57 PM
Agency Power Exhaust vividracing Engine, Exhaust, Bolt-Ons 17 07-23-2012 02:40 PM
