Old 10-30-2012, 03:29 AM   #29
OrbitalEllipses
Drives: Attitude
FWIW I had speed bleeders on my WRX. They're nice, but become useless if you use a pressured bleeder like the Motive tool. The tool pressurizes (positive, not vacuum) the brake system and pushes fresh fluid through so all you have to do is crack the bleeders open; they won't ingest air since the circuit's are pressurized. Just another way of doing a one-man brake job that I thought I'd share.
Old 01-19-2013, 10:29 PM   #30
eckoflyte
Drives: Toyota 86 GTS
Hey mate, what is the part number for the front and rear speed bleeders for this car?
Would appreciate the info as i want to get myself a set.
eckoflyte is offline   Reply With Quote
Old 01-21-2013, 07:36 AM   #31
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
SB1010-SS for front and rear.
Fits like a charm.
I am 95% sure this same speed bleeder will work for the clutch too
F1point4 is offline   Reply With Quote
The Following User Says Thank You to F1point4 For This Useful Post:
BAOVAN (12-27-2016)
Old 01-28-2013, 10:36 AM   #32
Amadeus
Amadeus's Avatar
Drives: White MT FR-S
There are two lengths offered - 31.35 and 34.44. Which length did you use or does it not matter?
Thank you for all of your great DIY write ups!
I figured it out - it's the longer threaded version with the part # you gave.
I looked at the part numbers closer and the short 31.35 is SB1010S-SS
My eyes skipped the extra "S" and I thought they both had the same #.
Amadeus is offline   Reply With Quote
Old 01-28-2013, 05:22 PM   #33
Lverasky
RedBunny w/ Wing
Lverasky's Avatar
looks great.!
Old 02-02-2013, 01:26 PM   #34
MyRx
MyRx's Avatar
To the OP or anyone else using the speed bleeders, any issues thus far? Does it actually make solo bleeding a breeze. I bring this up b/c my local track enthusiasts shop are adamant that years of trying to work with speed bleeders have failed, just ending up using the OEM bleeders and a 2 man crew. Something about letting air in as it closes.
SS lines are in route and picked a pump that will feed/keep the reservoir under pressure.
The Following User Says Thank You to MyRx For This Useful Post:
amram (04-09-2014)
Old 02-14-2013, 12:10 PM   #35
MyRx
MyRx's Avatar
Thanks for this write up. It helped. Flare wrench helped since standard wrench rounds the nut if it's on too tight. Thanks for lookout
The Following 3 Users Say Thank You to MyRx For This Useful Post:
amram (03-21-2014), MrTranxD (02-14-2013), normancw (03-16-2014)
Old 02-14-2013, 01:17 PM   #36
MrTranxD
MrTranxD's Avatar
Drives: Scion FR-S
rounded every the nut every time i tried using standard wrenches. gave up and used pliers.
2013 Ultramarine FR-S 6MT
MrTranxD is offline   Reply With Quote
Old 02-14-2013, 08:23 PM   #37
MyRx
MyRx's Avatar
That's right . Warning, flare wrench grips - standard wrench rounds. Have PB blaster handy - brake cleaner evaps too fast sometimes.
MrTranxD (02-15-2013)
Old 02-16-2013, 06:23 PM   #38
Alabang 86
Alabang 86's Avatar
Drives: GT86
Nice write up.
Spent a few hours at the track last week with my stock 86. Got settled, then into an aggressive groove. I found the brake feel /performance the most noticeable "low performance" part of the ride.
The SS lines is a great idea, mine are on order.
Alabang 86 is offline   Reply With Quote
The Following User Says Thank You to Alabang 86 For This Useful Post:
amram (03-21-2014)
Old 02-19-2013, 08:29 PM   #39
superpilun
Drives: 1986 MR2
When I first purchased speed bleeders about a decade ago, they warned not to over-tighten them because they are hollow and could break. Having half a bleeder stuck in the caliper would suck.
Also, I'm wondering where the warning to not pump the brake pedal all the way for fear of rupturing the master cylinder comes from. Any source for this?
superpilun is offline   Reply With Quote
Old 02-20-2013, 11:33 AM   #40
wheelhaus
wheelhaus's Avatar
It's a valid concern, but I'm not sure if it applies to this car. Typically, the brake pedal mechanism/levers/vacuum booster pushes a rod into the back of the master cylinder. So it's possible it may get damaged, but I'd only think it's possible if the rod is smaehed really hard into the MC. Honestly I wouldn't worry about it.
Old 04-22-2013, 04:22 PM   #41
THEmailman
Drives: Raven 6MT
Thank you for this! Did a line swap last weekend and followed this. Made everything easy and simple. Definitely agree that a flare wrench is the way to go, almost stripped the nut for the hard line/flexible line connection.
Goodridge SS brake lines//ProjectMu 999's//Motul DOT 5.1 brake fluid//GrimmSpeed master cylinder brace//Jackson Racing Oil Cooler//Whiteline camber bolts//Raceseng CamCas plates//Kosei K4R 17x8//BFGoodrich Rivals 225/45
THEmailman is offline   Reply With Quote
Old 04-22-2013, 05:19 PM   #42
CamryDS
Drives: 2003 Camry Blue | 2013 FR-S White
question about "air bubbles" Where exactly do we look for this? I understand the brakeline change as well as the bleeding part, but I'm not sure about looking for bubbles while bleeding the brake lines.
Figured I might attempt to do this on my own, once I get my car on a lift.
CamryDS is offline   Reply With Quote
brakes, fluid, motul, speed bleeders, stoptech
BC Racing Coilovers with Free Stainless Steel Brake Lines!!! Dustin@Dynosty Brakes, Suspension, Chassis 21 01-08-2013 10:34 AM
Dynosty Stainless Steel Brake Lines $99 Shipped Dustin@Dynosty Brakes, Suspension, Chassis 9 12-29-2012 09:56 AM
Stoptech stainless brake lines + Motul RBF600 fluid combo No Limit Motorsport Brakes, Suspension, Chassis 9 10-31-2012 07:36 PM
Stoptech Front Stainless Steel Brake Lines Pekingduck Brakes, Suspension, Chassis 1 10-21-2012 10:29 PM
Stainless steel brake lines taosracer Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 09-20-2012 04:09 AM
