Old 02-18-2013, 06:14 PM   #1
kimchangil424
kimchangil424's Avatar
Drives: Raven FRS
Wheel Directory: Work Emotion CR Ultimate "Kiwami" 18x9.5 +38
Just thought if share photos of my raven on kwv3 with Work Emotion in 18x9.5 +38 offset. It's at factory set height from kw and rides like stock. Tires are Yokohama s-drive in a 245/35/18 squared setup. I'm considering putting on rpf1 instead if anyone is interested in the works. Thanks.
kimchangil424 is offline   Reply With Quote
The Following User Says Thank You to kimchangil424 For This Useful Post:
Clipdat (02-20-2013)
Old 02-19-2013, 01:10 AM   #2
Z3D
More pics this is a clean setup.
Z3D is offline   Reply With Quote
Old 02-19-2013, 08:08 AM   #3
Skurj
Drives: SOLD...
I have these wheels on order in staggered fitment..
How much lower is the car from stock?
WRB MT BRZ Sport Tech Delivered March 21 2013 Its mine now!!
Paid for Mar 2018
and its gone... Sept '18 tho I am sure I will miss it
Replaced with 18 50th edition ND
Skurj is offline   Reply With Quote
Old 02-19-2013, 12:14 PM   #4
Brandon86
Most dope
Drives: Raven Scion FR-S
Looks great! any more pics?
Brandon86 is offline   Reply With Quote
Old 02-19-2013, 01:45 PM   #5
thatWESguy
Power Ranger
thatWESguy's Avatar
Drives: 86
let me know if you decide to sell 'em, looks good man
Autofashion | FIVEaxis | Enkei
thatWESguy is offline   Reply With Quote
Old 02-20-2013, 01:47 AM   #6
kimchangil424
Drives: Raven FRS
joshontilt (05-29-2013)
Old 02-20-2013, 01:48 AM   #7
kimchangil424
Drives: Raven FRS
Old 02-20-2013, 01:49 AM   #8
kimchangil424
Drives: Raven FRS
Old 02-20-2013, 01:49 AM   #9
kimchangil424
Drives: Raven FRS
Old 02-20-2013, 01:50 AM   #10
kimchangil424
Drives: Raven FRS
Old 02-20-2013, 01:51 AM   #11
kimchangil424
Drives: Raven FRS
Old 02-20-2013, 01:53 AM   #12
kimchangil424
Drives: Raven FRS
The car is probably 1.3 inches lower then stock. It rides pretty close to factory except a tad bit firmer. I have no problems clearing driveways at that height and no rubbing at full lock.
Old 02-20-2013, 11:35 AM   #13
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
any issues with that tire size up front? i'm trying to run a 255 all around and wondering how much room there is up front.
alignment specs if you dont mind?
Jive Turkey is offline   Reply With Quote
Old 02-20-2013, 01:17 PM   #14
kimchangil424
Drives: Raven FRS
There is no clearance issues at full lock either way with the 245/35/18. Alignment spec is set up for daily driving as I will be changing out the rims for track purposes and realigning the car. Toe is within factory specs and camber is just outside of factory specs ( not by much). I had evasive do the alignment. I think some members are running 255 but on a 17 inch rim. I think it's pretty tight to fit a 255 depending on which tire manufacturer you go with and your suspension setup. Maybe some other members could provide input on this.
Wheel Directory: Work Emotion CR-Kiwami 18x8.5 +38 Jeff Lange Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 31 03-21-2018 05:18 PM
Wheel Directory: Work Emotion CR Ultimate "Kiwami" 19x9.5 +38 Killerbee Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 20 03-08-2014 04:49 PM
Wheel Directory: Work Emotion CR Ultimate "Kiwami" 19x10.5 +32 RavSpec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 02-25-2014 06:00 AM
WTB: Work Emotion Ultimate Kiwami Wheels Center Caps hanabie Want-To-Buy Requests 0 10-25-2013 06:34 PM
WORK Emotion CR Ultimate (Kiwami) - 17x9 +38mm 5x100 IN STOCK NOW RavSpec Wheels and Tires 14 12-01-2012 12:26 AM
