Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > ASIA
Old 02-18-2013, 12:21 PM   #477
jdmasfcuk
jdmasfcuk's Avatar
Drives: Toyota 86 ZN6
because tofu
jdmasfcuk is offline   Reply With Quote
Old 02-19-2013, 05:46 AM   #478
Booch
Booch's Avatar
Drives: Red 86
Does your 86 too does not have auto lock door features? (it automatically locks the doors on a certain speed) first time to own a car like this, my ignorance.
Booch is offline   Reply With Quote
Old 02-19-2013, 05:56 AM   #479
lonelydriverZN6
lonelydriverZN6's Avatar
Drives: Toyota 86
Yes. I don't know if it could be programmed but it would be nice to have that feature. It doesn't bother me as it is a habit of mine to lock the doors before setting off
lonelydriverZN6 is offline   Reply With Quote
Old 02-19-2013, 05:57 AM   #480
jdmasfcuk
jdmasfcuk's Avatar
yup... wala po papa booch.. pero ganda rin sana kung meron
Old 02-19-2013, 05:58 AM   #481
lonelydriverZN6
Drives: Toyota 86
Originally Posted by jdmasfcuk View Post
because tofu
Takumi's key chain?
The Following User Says Thank You to lonelydriverZN6 For This Useful Post:
jdmasfcuk (02-19-2013)
Old 02-19-2013, 06:12 AM   #482
jdmasfcuk
jdmasfcuk's Avatar
Originally Posted by lonelydriverZN6 View Post
Takumi's key chain?
higante keychain hahahaha... unan yan paps bigay nung ex ng katropa ko... nag break na kase cla kaya hiningi ko nlang.. sama ko noh...
sencya na if dami pics...
old 86
new 86
Old 02-19-2013, 07:38 AM   #483
HRTROB
HRTROB's Avatar
Drives: Toyota 86
No autolock function for the 86 even with techstream. Hassle nga eh. Our 2008 Camry had autolocking door locks when you reach a certain speed. Pero our LC200 doesn't have it also
HRTROB is offline   Reply With Quote
Old 02-19-2013, 07:45 AM   #484
jdmasfcuk
jdmasfcuk's Avatar
papa HRTROB.. dun sa fuse/relay box sa engine.. ano kaya meaning nung DIM na relay? kase i saw ur "how to" dun sa DRL, just wondering if alam mo ano meaning nung DIM...
chineck ko kase manual natin hindi ko mahanap ano meaning nung DIM.. baka alam nyo po.. tnx
Old 02-19-2013, 09:00 AM   #485
Booch
Booch's Avatar
Drives: Red 86
thanks sir, kasi nasanay na ako na may auto lock now i dapat tandaan ko lagi na ilock ang pinto.....mahirap na rare ang kotse natin baka masalihan
Old 02-19-2013, 09:28 AM   #486
rockers_kitoy
rockers_kitoy's Avatar
Drives: Toyota T86
where can we place our parking sensor (back)? if there is...
rockers_kitoy is offline   Reply With Quote
Old 02-19-2013, 11:20 AM   #487
HRTROB
HRTROB's Avatar
Drives: Toyota 86
Papa jdm,
Yung DIM relay is for the bixenon shutter. When I disconnected the DIM relay, di na gumana yung high beam mode ng projector.
Bixenon kasi yung projectors ng 86, meaning there is a solenoid that controls the shield/shutter. When you switch to high beam, bumababa yung shield to allow all light to pass through
The Following User Says Thank You to HRTROB For This Useful Post:
Old 02-19-2013, 11:22 AM   #488
HRTROB
HRTROB's Avatar
Drives: Toyota 86
You will have to drill holes in the bumper. Check the Dubai versions at sulit.com.ph, they come with front and rear parking sensors
Old 02-19-2013, 01:34 PM   #489
jdmasfcuk
jdmasfcuk's Avatar
Originally Posted by HRTROB View Post
Papa jdm,
ah para dun pala yun. kase i used the DIM relay to try the DRL trick. kala ko yung DIM para sa dim sa lights ng gauges hahahaha .. eh dini~dim ko pero gumagana pa yung dim sa gauge.. now i know.. tnx papa HRTROB
pumunta ako sa Subaru dealer dito samen to check if they have the relay pero wala pa raw.. will just try checking my nearest auto supply
Old 02-19-2013, 06:24 PM   #490
Margovincent_22x
Margovincent_22x's Avatar
Drives: Lightning Red BRZ MT Limited
HRTROB I have a USA version BRZ, alam mo ba kung pano gawing independent from the headlights ung fog lamp?
I can't turn the fog lamp ON when the Headlights' Low beam is turned off
Ung PH version kc need lang park light na naka ON tapos pwede na mag ON ung FOG lamps.
Margovincent_22x is offline   Reply With Quote
