Old 02-16-2013, 02:31 AM   #15
Dezoris
Dezoris's Avatar
Originally Posted by Sam Strano View Post
10 sets rolled in the door today. All 10 sets are, and have been sold. 3 more sets are due soon... and I have an order for at least one of those sitting on my desk as I type this.
Teaser:
Have you gotten a chance to run on them yet?
Also how did you dial them in on your past cars that were RWD?
Soft in front medium in rear?
Old 02-17-2013, 11:07 AM   #16
SVThis
SVThis's Avatar
Drives: Scion FRS
I was wondering if someone can post the installation instuctions for the inserts. I was wondering if using a pipe cutter was the easiest way to cut off the top.
We're not happy till you're not happy
2013 Scion FRS Whiteout 6MT
SCCA RTR/Konis/RPF1's/Dunlop Z2's/Strano front bar/CG Lock/Crash camber bolts/JPM shift boot and Instrument panel cover.
SVThis is offline   Reply With Quote
Old 02-17-2013, 03:01 PM   #17
xwd
Pipe cutter is probably the best way. Here is a good install guide:
http://forums.nasioc.com/forums/show....php?t=1219607
The Following User Says Thank You to xwd For This Useful Post:
jdrxb9 (02-23-2013)
Old 02-17-2013, 09:18 PM   #18
SVThis
SVThis's Avatar
Drives: Scion FRS
I don't have the Konis yet. How far down do you make the cut and from what point do you measure down?
Old 02-20-2013, 01:02 PM   #19
Sam Strano
Sam Strano's Avatar
Drives: 2013 FR-S Asphalt
Ok, all the first 10 sets are outta here. And today, 4 more complete sets showed up!!!!!
So if you are in the market....... I'm going to keep the $770/shipped price on for these 4 sets as well. Don't wait if you want them, who knows how long until more show up.
Sam Strano is offline   Reply With Quote
Old 02-20-2013, 06:16 PM   #20
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
Mine are in. Cant install until next week but Im excited
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Old 02-20-2013, 09:09 PM   #21
Ninjin
Ninjin's Avatar
Drives: SWP BRZ 6MT
I'm excited, but the wait is killing me!
Old 02-22-2013, 02:54 PM   #22
Sam Strano
Sam Strano's Avatar
3 sets left....... When they are gone the free shipping goes away too.
Old 02-23-2013, 08:14 PM   #23
jdrxb9
jdrxb9's Avatar
Drives: ND2, formerly BRZ (MT/CBS)
Well, since Sam posted a 'before' shot, I figured I'd post an 'after' shot - converted and ready to install:
(clickable thumb)
thanks for the link - lots of good stuff in there
Just to add a couple points:
  • with the struts inverted I got zero fluid spray from the first and just a small mist (just enough to dampen the drill chuck) from the second - pumping out the fluid through the initial hole worked great
  • I could not believe how tight the fit was between the insert and the ID of the strut - I scraped off a lot of yellow paint pounding them in
  • the second one was so tight, I had to go pick up some 1" pipe to better drive it down to the retaining bumps - totally destroyed the plastic impact/protection ring
  • you will definitely want an 8mm hex drive socket and torque wrench for the bottom bolt - 55 ft-lb is pretty tight and I would not have wanted to try it with a hex key
  • and I will definitely take the smell of fork oil over used manual transmission fluid any day! (maybe I'm just used to it from tearing apart forks?)
I measured the bumps as ~46mm down and the instruction chart gives the cut point for that measurement as 40mm. I measured from the very top of the strut and cut with the HF #2 pipe cutter (only ~$15) and it worked great.
cheers!
jdrxb9 is offline   Reply With Quote
The Following User Says Thank You to jdrxb9 For This Useful Post:
SVThis (02-24-2013)
Old 02-24-2013, 01:52 PM   #24
SVThis
SVThis's Avatar
Drives: Scion FRS
I'm wondering if initially using a longer bolt on the bottom of the strut to pull the insert down into the strut would work better than pounding. Might be worth a try.
Old 02-24-2013, 04:46 PM   #25
jdrxb9
jdrxb9's Avatar
That was my thought as well. Unfortunately, the longest M12x1.5 my local hardware store had was 100mm, which was not long enough to reach the insert at the point where it initially got difficult. I bought the 100mm and a big stack of washers, but with the more even loading of the pipe, it went in without too much difficulty and I ended up not using the bolt.
Old 02-25-2013, 05:03 PM   #26
Sam Strano
Sam Strano's Avatar
They made the inserts as large as possible so they could use the biggest piston and have the greatest oil volume possible in this type of damper. Funny that one was tighter than the other, I'm guessing it had thicker paint.
What I'm looking forward to is the report when you guys get them on the cars.
BTW.... Down to one set. More are coming in, but I have one set left in the shop available for purchase.
Old 03-01-2013, 01:30 PM   #27
enjoyminutemaid
enjoyminutemaid's Avatar
Drives: Subaru BRZ Limited WRB Manual
(clickable thumb)
cheers!
Can you give an estimate on install time?
enjoyminutemaid is offline   Reply With Quote
Old 03-01-2013, 04:19 PM   #28
jdrxb9
jdrxb9's Avatar
Well, I'm waiting on a front swaybar to do the actual install, so I can't give you any first hand info on installation. (The struts above are take-offs I purchased ahead of time so I could do the conversion at my leisure and also to be able to go back to my stock struts if I want to later.) For just the conversion, assuming no hardware store runs to interrupt you, I'd say under an hour. For the overall installation, see the DIY lowering spring installation link here - the OP says two hours, but that sounds a bit optimistic to me. I'd budget at least 4 for the whole process including converting the fronts.
enjoyminutemaid (03-01-2013)
Koni Suspension Components dale.m Suspension | Chassis | Brakes -- Sponsored by 949 Racing 76 06-20-2013 09:00 PM
Adjustion compression on a Koni 8612 insert? Evil86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 03-05-2013 05:01 PM
Tein Street Basis coilover, Koni struts and shocks JoeBoxer Brakes, Suspension, Chassis 6 12-25-2012 09:43 AM
GTS owners... difference between 'sports' abd 'vsc sports' button? UnLeasHer AUSTRALIA 5 07-26-2012 03:22 AM
