Old 02-16-2013, 10:04 AM   #1
Skippman
Skippman's Avatar
Drives: GBS BRZ Limited
Lets Talk Component Speakers
I haven't found a thread on here dedicated to the discussion of component speaker systems. I figured I'd start one. I'd like this thread to be a discussion of speaker systems and installs.
In looking for speaker systems for my BRZ I've discovered that St. Louis has a lack of quality audio shops so the internet is really the only place I can go to get an information on component speaker systems.
I know 2forme is running a set of Hertz Hi-Energy HSK-163's. That's what I was planning to install as well, but I'm open to other suggestions.
What are you guys running? How do you like them?
Skippman is offline   Reply With Quote
Old 02-16-2013, 12:05 PM   #2
FreshFRS
KCCO From Canada
Drives: Asphalt FRS
really depends on your budget. focal makes some really nice stuff. Dynaudio makes arguably the best 3.5" mid money can buy. (Esotar2 E430) Scan Speak and peerless make excellent woofers (6.5 illuminator or 8" relevator) and (SLS or HDS) respectively For tweeters it really depends on your preferences. i'm going to run Dynaudio Ecotar E110s
not to thread jack but does anybody know if an 8" mid/woofer with 4.1" mounting depth will fit in the doors? i want to avoid running a sub and the scan speaks (8" relevators) can play down to 20hz efficiently.
FreshFRS is offline   Reply With Quote
Old 02-16-2013, 12:25 PM   #3
mashal
DADA
mashal's Avatar
Drives: 2013
8" on the fronts ? I could see then in the back , loads of space there .
mashal is offline   Reply With Quote
Old 02-16-2013, 12:33 PM   #4
tripjammer
tripjammer's Avatar
Drives: WRB BRZ limited 6MT
Yeah those 8 inches would fit in the back. I guess your could dynomat the whole area behind the rear speakers and put in that 8 inch woofer. Or build some kind if smallish subwoofer box back there.
tripjammer is offline   Reply With Quote
Old 02-16-2013, 02:57 PM   #5
cruzinbill
Drives: Argento 6spd FR-S
Im running Hertz Mille 3ways. It sounds ok.
Id say unless you want to go active and all that jazzzz to pass on the HSK163's. Granted they sound excellent, they are wayyyyy better active with a good amount of power. Also their passives are pretty damn big that come with them.
I would say just get a set of JBL MS-62C's. They are a great set of components that work well with a varied amount of power.
Aside from super custom setups.... thats really the only 2 choices I think people need for comps on this car lol.
Active with ~75ws/6ch= HSK163
Passive with 75-150ws/2ch = JBL MS-62C
Now... for either... pick up a roll of your fav deadner and do your doors and door panels. Make some quality MDF adapters or plastic whatever your crazy brain prefers, and do the install right. Shit will sound legit and you will be happy at either price range.
cruzinbill is offline   Reply With Quote
The Following User Says Thank You to cruzinbill For This Useful Post:
TofuJoe (08-05-2017)
Old 02-16-2013, 03:54 PM   #6
Flat Black VW
Flat Black VW's Avatar
Drives: 2013 Subaru BRZ
im running focal 100 KRS on the dash with a Hertz mille 6.5 component sub (didnt use the Hertz tweeter, used the focal tweeter from the 100 KRS). All off of factory amps and HU. Sounds perfectly clear and I can turn the volume all the way up to full on the Fujistsu-Ten with no distortion. Also has plenty of volume and the Hertz give me enough bass, although adding a sub would add more, id prefer to just stick with what I have than add more weight.
Also did a similar set up in a customers car as described here:
http://hurleysautoaudio.blogspot.com...r-speaker.html
Flat Black VW is offline   Reply With Quote
The Following 3 Users Say Thank You to Flat Black VW For This Useful Post:
DAEMANO (04-18-2015), RYU (02-18-2013), TofuJoe (08-05-2017)
Old 02-16-2013, 06:31 PM   #7
FreshFRS
KCCO From Canada
Drives: Asphalt FRS
dont want to put them back there. I'm running 3 way active so i would like to keep everything in the front. i think it should be fairly easy to do will require cutting of the door panel though.
im going to build a 2 piece mount about 1.5" tall might have to trim the metal a little bit but hopefully not much. sound deadening and CCF will be slightly excessive to help them with fidelity. i'm running Dynaudio Esotar E430 mids and i really haven't decided on tweeters yet.
Old 02-16-2013, 06:39 PM   #8
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
I'm installing a custom 3-way active setup when I get back. It's a 6.5", 4" & 1" comp set. I have a JBL MS-8 to help process everything, using a 160.2 amp for the doors & a 100.4 amp for the dash. I had them briefly installed in my tC and they sounded great & got really loud.
kmbkk is offline   Reply With Quote
Old 02-16-2013, 07:49 PM   #9
Chewie4299
Spaceman
Chewie4299's Avatar
Drives: 2013 Firestorm Scion FR-S
Not yet sure how much I want to invest at this point but I spent some time at one point in the past working for a company that sold, among other things, Focal (pronounced Foe-Kal for anyone curious) speakers and they are absolutely amazing.
Chewie4299 is offline   Reply With Quote
Old 02-16-2013, 09:12 PM   #10
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
I think youre looking in the wrong forum for decent audio advice. www.diymobileaudio.com would be more suited for this.
supramkivtt2jz is offline   Reply With Quote
Old 02-16-2013, 10:47 PM   #11
cruzinbill
There are a few FR-S threads already there with good contribution.
Old 02-16-2013, 10:52 PM   #12
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
There are a few of us here that are on there also, there is a lot of questionable advice going around no doubt though.
The Following User Says Thank You to JoeBoxer For This Useful Post:
cruzinbill (02-16-2013)
Old 02-16-2013, 10:59 PM   #13
JoeBoxer
JoeBoxer's Avatar
I was wanting to go with a 3 way set but there aren't a lot of options out there so there is nothing wrong with sticking with a 2 way component set.
It's hard to recommend anything without knowing the budget, planned amp setup, listening preferences, etc.
Old 02-16-2013, 11:05 PM   #14
cruzinbill
it really is like 95% budget 4% being able to get it installed correctly 5% taste, 5% speaker preference and 1% other stuff.
Dash Top Speakers / Rear seat speakers Laurie Electronics | Audio | NAV | Infotainment 9 03-01-2013 06:31 PM
Lets talk about FRS lacking fog lights, why does everyone want them? post_break Scion FR-S / Toyota 86 GT86 General Forum 35 12-13-2012 10:39 AM
Lets talk exclusivity whitejdm BRZ First-Gen (2012+) — General Topics 33 02-15-2012 01:17 PM
Lets talk weight KaliKev Scion FR-S / Toyota 86 GT86 General Forum 63 09-12-2011 12:05 AM
Lets talk suspension Midship Runabout Scion FR-S / Toyota 86 GT86 General Forum 42 05-20-2010 12:51 AM
