Old 02-15-2013, 09:25 PM   #1219
xjohnx
Grip>Slip
xjohnx's Avatar
Originally Posted by sierra View Post
I think it's more likely to be the ECU adjusting to the changes.
My car certainly improved steadily over the first 1000km and then I decided to re-set it to see what would happen. It felt flat again, with some hesitation to the throttle and is gradually improving. I read somewhere it learns and adjusts to changes without being re-set and that it takes some time to optimise those changes.
That same process might slowly eat away at some of the changes that were flashed into it?
nothing really slow about this though, these runs are back to back from what i understand.
Old 02-15-2013, 09:30 PM   #1220
johnbradley
Drives: Turbocharged
Originally Posted by Calum View Post
AVO posted a while ago about having trouble with the cam phasing sticking. Any chance this could be the cause?
It logs correctly but if thats what it is I can take the advance out at that spot rather than add it in.
No expert here, but have read a lot that after a flash, the car needs to adjust and "learn" the new flash. Some have talked about flashing, then letting the car idle 5 minutes before driving away and that after driving, some miles need to be put in the car for the ECU to adjust. May be possible that while the ECU is learning something happens with cam phasing? (this is assuming you guys are flashing and right away running first dyno run then second dyno run, no idle time between flashing and dyno run).
I dont want it to learn if its losing where I want it to gain. Thats more or less what I am asking is what its learning and what I need to alter.
It seems to learn in 30 seconds and/or one dyno pull.
These were back to back, with all the fans on (we have a wind tunnel), all temps were back down to the green for the pull. I am a big fan of oil temp and water temp being a consistent part of tuning.
johnbradley is offline   Reply With Quote
Old 02-15-2013, 09:33 PM   #1221
sierra
Drives: Skoda Yeti DSG diesel 4x4
But are they re-setting the ECU before each run?
I'm wondering if the ECU starts at a baseline and over 1000km optimises whatever settings are self optimising? Maybe that gets quicker with some memory being used to speed it up, memory that wasn't there before?
sierra is offline   Reply With Quote
Old 02-15-2013, 09:36 PM   #1222
johnbradley
[ame="http://www.youtube.com/watch?v=eNxN3HMnZqE"]Namless Performance's 2013 Scion FR-S 188hp/159tq - English Racing - YouTube[/ame]
Old 02-15-2013, 09:36 PM   #1223
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I believe it has to do with Cam phasing. Also, Bob at Drift Office or Visconti can help you out for sure on that one.
One last thing, Perrin in their blog wrote once that Oil temperatures seemed to be the culprit of inconsistent Dyno runs.
Old 02-15-2013, 09:38 PM   #1224
Jason@Nameless
Jason@Nameless's Avatar
Drives: '88 BMW 535is Turbo
Here's another graph to show vs. stock. We're losing power somewhere here, but I'll tell you this much: I've driven both. Like I stole the car. And they are both f-all fast compared to even our other header setup w/ the full exhaust.
We will keep playing with various items on this and see what we can shake out. I'm curious if the stock midpipe is impacting any of this and we just have to figure out what to test next. Bottom line - this header is wicked.
Dyno Graph:
I can't wait to go drive it again. If you want to check the car out, it'll be at Cascade Cars & Coffee Portland with it tomorrow AM.
Jason
Jason@Nameless is offline   Reply With Quote
Old 02-15-2013, 09:39 PM   #1225
johnbradley
Yes I was re-setting. You can tell if you do the run too soon before it has learned and adequate amount before you make the pull. I have had a chance to tune the car, then put it back on the dyno with months in between and it doesnt take any longer than what I have observed.
1 pull 30 seconds after intial restart - XXX
2nd pull 1.5 minutes after that, identical numbers with torque dip
3rd pull days apart and miles put on the car, identical to the 2nd pull
Old 02-15-2013, 09:51 PM   #1226
sierra
I'm assuming the tuning is with Ecutek.
Do you think that should lock out the ECU self learn process but it's still managing to interfere?
Old 02-15-2013, 09:51 PM   #1227
Calum
That Guy
Drives: 2013 asphalt FRS MT
Could the dip be caused by the injectors switching from port to DI or vice versa? Another long shot I know but there are no stupid questions right?
Sent from mission control
Old 02-15-2013, 09:59 PM   #1228
sierra
The direct injection runs all the time but the port injection cuts out from about 3,000rpm to 5,000rpm
http://www.ft86club.com/forums/showp...84&postcount=1
Could it be that with the high torque and fuel demand, the direct injection alone at that rpm range, is close to it's limits and the ECU is bringing it back to safer levels?
Old 02-15-2013, 10:04 PM   #1229
Simmons
Simmons's Avatar
Drives: 2024 GR86/ 2015 FRS
Was this in 5th gear?
Simmons
2024 GR86 71 STR/ 2015 FRS 71 STX
Sponsors Xero-Limit//Karcepts
Simmons is offline   Reply With Quote
Old 02-15-2013, 10:24 PM   #1230
FR-S Matt
Dyno Graph:
Jason
I was thinking that 2.1" midpipe is choking the system but I could be completely wrong. Was the 3" system tested with the stock midpipe as well? Just throwing out ideas. I'm baffled the dip returned.
Old 02-15-2013, 10:36 PM   #1231
Dimman
Kuruma Otaku
Dimman's Avatar
Dyno Graph:
Jason
Do you have this graph with AFRs?
Is there a corresponding slight richening in the 'regression' area?
Because titanium.
Old 02-15-2013, 10:44 PM   #1232
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
If that were the case wouldn't it show up top rather than in the middle? Other than the great gains just about everywhere, there is some weird stuff going on in the dip area.
industrial is offline   Reply With Quote
21 months no dyno, 22 months no vendor dyno, 22months4rattles&leakssmh, amazing warped qualiy, y u no tag
Nameless Performance BRZ Axleback Exhaust ESBjiujitsu Engine, Exhaust, Transmission 1377 04-21-2020 02:23 AM
Nameless Performance Axleback is available for pre-order. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 114 07-23-2012 10:38 PM
Nameless Performance Downpipe is available for pre-order. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 4 07-12-2012 04:57 PM
We are Nameless Performance. John@Nameless Announcements, Contests, Giveaways 22 06-18-2012 11:32 PM
Nameless Performance is here. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 16 06-06-2012 04:32 AM
