Old 02-08-2013, 06:17 PM   #85
Lverasky
RedBunny w/ Wing
Lverasky's Avatar
Originally Posted by ir1064 View Post
just order the flip key housing and transponder key from ebay
http://www.ebay.com/itm/TOYOTA-REMOT...5b435d&vxp=mtr
and will try to following this instruction to see if it works or not, really don't want to rip the original key apart...
http://www.ehow.com/how_5054034_prog...-chip-key.html
can you make a video?
Old 02-08-2013, 09:15 PM   #86
ir1064
Drives: 6MT, C7P
i'll try once i received the flip key housing.
ir1064 is offline   Reply With Quote
Old 02-14-2013, 01:38 AM   #87
Lverasky
RedBunny w/ Wing
Lverasky's Avatar
How is the process?
Old 02-14-2013, 01:41 AM   #88
EBMCS03
Drives: Argento FR-S
Originally Posted by mottor View Post
I tried for half an hour to cut it out using an xacto knife and had no luck. Looks like you're better off pulling the one out of the valet key.
I gave in... I destroyed the original key and pulled the chip out. luckily it works... Phew!
I guess if i ever want to replace it back into a "stock" key I'll just buy a new stock type key blank off ebay and move the chip back into the new key blank.
EBMCS03 is offline   Reply With Quote
The Following User Says Thank You to EBMCS03 For This Useful Post:
86_ZN6 (07-30-2013)
Old 02-14-2013, 02:22 AM   #89
EBMCS03
or should it be this process?
http://www.ehow.com/how_5752878_prog...-scion-tc.html
have you actually tried?
Old 02-14-2013, 10:48 PM   #90
ir1064
Drives: 6MT, C7P
How is the process?
still waiting for the housing, i'm guessing because of the chinese new year and the shipping got delay...
Old 02-15-2013, 01:20 AM   #91
Lverasky
RedBunny w/ Wing
Lverasky's Avatar
I see. Well, please keep us post on ur key conversion project. Thanks!
Old 02-15-2013, 11:29 AM   #92
MmmDieselFumes
MmmDieselFumes's Avatar
Drives: .
Same here...
MmmDieselFumes is offline   Reply With Quote
Old 02-27-2013, 01:26 AM   #93
MmmDieselFumes
Drives: .
Got mine, had to destroy the $#!& out of one of my clicker-keys to get the transponder chip out, then just used some gel super-glue to put it in the housing. Took the blank portion of the new key to a locksmith, and they copied my key's grooves into the blank (took all of 30seconds and cost $4.00). Works like a charm in the doors and ignition. Here's some pictures.
Old 02-27-2013, 02:06 AM   #94
MemphisR
Memphis
MemphisR's Avatar
Drives: 1989 MR2 S/C, 2014 Scion FR-S
So how do the other two buttons work? the look and panic?
"It's ok... It's not structural."- Mikey
MemphisR is offline   Reply With Quote
Old 02-27-2013, 02:40 AM   #95
MmmDieselFumes
Drives: .
They're hidden under the leather part. The truck unlock is towards the "top" (towards the key), the panic is towards the "bottom" (towards the key-ring). Button layout is still the same, just hidden under the leather. Tested it, and all the buttons work beautifully.
Old 02-27-2013, 02:57 AM   #96
MmmDieselFumes
Drives: .
Here's some more pictures.
The Following User Says Thank You to MmmDieselFumes For This Useful Post:
draggin_az (03-13-2013)
Old 03-17-2013, 12:56 AM   #97
Bruce125
Bruce125's Avatar
Drives: '13 FR-S Whiteout M/T
Received my leather flip key today. Has anyone been able to remove the transponder without ruining the original key?
Originally Posted by EBMCS03 View Post
I want to know this too... any able to get the transponder out with out destroying the original key? Is there a plastic casing on top of the transponder chip or is that the actual chip that you see when you're looking inside the key?
I just received mine today and did the conversion. It took exactly 11 days to arrive from when I ordered it which isn't to bad since it came from China. I wanted to preserve my original key in case I ever had a problem with the new fob or wanted to convert back. In response to the one question, you can see the top of the transponder and it has a plastic frame all around the sides.
I used an exacto type of knife to shave the plastic frame on the back side and corner of the transponder. Then I would tear away the plastic pieces with needle nose pliers as I went. Once I got about down to the bottom of the frame on the back corner I used a hair dryer to heat the plastic a bit, got under the transponder with an eyeglass screwdriver and slowly worked it up till it popped loose. I was careful and took my time since I didn't want to risk chipping or cracking the transponder. There is enough of the frame left so I can push the transponder back into it if I choose to use the key again later. I used some paper to hold the buttons in place and snapped the key back together. It looks perfect on the outside and ready to use if I ever want to put the parts back in.
The new fob went together very easily and looks great, I really like it! I included a picture of the original key all apart with the transponder out. Then a couple pictures of the new key fob and the original key put back together after the project was done. Now I just have to get the new key cut and it's good to go.
Bruce125 is offline   Reply With Quote
Old 03-17-2013, 01:20 AM   #98
EBMCS03
Thanks... but I ended up destroying mine... its ok... I found that ebay also sells the original key shells... so i can buy one of those and move the chip back if i ever wanted.
plus if i sold the car... its not like the flip key wont work. so I got over wanting to revert back...
Scion FR-S Concept First Official Pics/Videos + NYIAS Pics and Press Conference Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 856 06-14-2018 02:53 PM
HID Conversion DIY loong DIY (Do-It-Yourself) Guides 55 06-27-2014 06:27 PM
BRZ HIDs vs FR-S HID Conversion DarrenDriven Cosmetic Modification (Interior/Exterior/Lighting) 37 06-28-2012 05:20 PM
jdm conversion here it is jdmboss86 Cosmetic Modification (Interior/Exterior/Lighting) 2 06-28-2012 02:26 AM
LED Conversion [M] Cosmetic Modification (Interior/Exterior/Lighting) 38 06-18-2012 08:44 PM
