#15 |
Drives: 2013 Scion FR-S Argento
I was hoping some useful info would be here instead of jokes. I had a rock put a crack in my windshield and I am interested in prices to replace it.
#16 | |
Drives: Whiteout Scion FR-S
If there is a small crack you can have it filled with clear plastic stuff. Much cheaper, but definitely not as good as a new windshield. Most insurance/glass companies will not do the crack filling if the rock chip is in the line of sight because it is not optically transparent. If you have a small crack and suspect it may grow, thump on it a couple of times with the fleshy part of the palm of your hand. Hit quite firmly. If the crack grows, you definitely need a new windshield. On my old car, cost for paying for it myself started around $300. Try to get a reputable installer that will use OEM glass. The windshield is a SAFETY item as mentioned above.
My cars always dress formally. They all wear black tires.
#17 |
Drives: '14 Hot Lava FR-S w/Flappy Paddles
I was contemplating this for a while and did a little research on it. There is a copolymer extrusion that can be used for windshield replacement that is UV and scratch resistant. I forgot the name for it, but I'm sure if you did some Googling, you'd eventually find the same information I did. That said, I talked to Robispec about it, and he said at best, you'd save 15lbs if you swapped all the glass for polycarbonate. Granted you'd be removing the weight from above the stock center of gravity, but there is a lot of "lower hanging fruit" to go after in the quest for making the car lighter. Also, a poly windshield would put you into an unlimited class in racing where you would get your ass handed to you if you didn't already have $40k+ in the car.
#18 | |||
Hail Magnet
![]() Quote:
#19 | |
Drives: FR-S MT
#20 |
Drives: 2013 Raven Black FRS
I have scratches in my windshield from a squeegy I used at a gas station... and I've tried all sorts of glass scratch remover.... nothing works.
Raven FR-S, Magnaflow Axel Back Exhaust, Airaid Intake.... Pending Dynojet for performance gains... Big wish list... just need money to do it!
#21 |
Drives: blue brz, silver R8 5.2, orange s2K
I have a crack extending halfway across the middle of the windshield on the passenger side caused by a rock hitting it on the highway. Looked into replacement and found out that there is no aftermarket support YET. Factory windshield is $495 + install. My insurance does not replace glass outside of standard deductable, so I wait for adtermarket glass to become available. Anyone find something new, I'd love to hear about it.
#22 | |
Thats the reason why I asked this question, but quickly got every Saskatchewan-ian comedian this side of the northern USA border talking about saran wrap and translucent aluminum... too busy making jokes to really answer the question with foresight that someone could be having a problem and looking toward peers for help/advice.
#23 |
Drives: Asphalt FR-S
Stop trolling him guys. Everyone knows weight reduction is the way to go.
My car runs a 8 second 1/4 mile.
#24 |
Speed glass works better than most other Lexan and polycarbonate materials. Having used it in the past none of that stuff would hold up in a daily driven car. It will pit and scratch, water adheres to it worse than glass, etc. It's not meant to be continuously used in extreme temperatures, etc. Use real DOT glass unless you have a full cage and trailer your car around everywhere.
I wish I could eliminate "because racecar" from the Intrnet vocabulary. |
#25 |
Drives: 13 BRZ - 90 Miata - 07 FXT -05 Mini
I've considered replacing the glass in the past in other cars for weight reduction, but the windshield is the last one I'd do. Side windows and rear window would be more doable in a street driven car. I wouldn't do the windshield in anything other than a trailered track-only car. Some very popular cars have pre-cut lexan panels made for them that are easier to install. For the BRZ/FRS it would have to be custom at this point.
17x7 Kosei K1-TS w/ 215/45-17 Dunlop Star Specs
Nameless Track Pipe - Strano front sway bar |
#26 |
Drives: Fr-s 2013 white out
I removed my car for more weight reduction.
#27 | |
Ridge Racerrrrrrrrr
You didn't ask the problem because you had a "problem," you never stated as such so don't be so serious about this. Some people had some good jokes. if you wanted to talk about making your car lighter than you probably could have asked the people on the Tracking sub-forum because those people would actually know about it. This is a cosmetic modification forum, we are talking about LED's, carbon fibre interiors, adding scoops and heaven forbid, scissor door kits. Know when I used lexan last to solve a "problem"? when someone kept breaking into my brother's car. My father replaced his side windows with lexan - the s*** got scratched up and gouged when people tried to break it but it held up. Made it impossible to see out when the sun hit it though.
#28 |
Scratches in your windshield aren't cosmetic? I don't care so much about weight reduction as i do a $400+ windshield.... many assumed it was about weight reduction. If a poly replaced windshield was tough and scratch resistant and lighter... the lighter part would just be a byproduct of and an added bonus. But main concern is keeping cracks and pits out of my glass... not saving weight... where shall I discuss and post that? Mr. Forum post director guy...
| Front windshield replacement cost | RAWR BRZ | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 87 | 04-18-2019 10:16 AM |
| Windshield Decal | Cameronghanson | Cosmetic Modification (Interior/Exterior/Lighting) | 37 | 05-25-2014 08:47 PM |
| Windshield | IloveBaldEagles | Mid-Atlantic | 3 | 12-05-2012 01:19 AM |
| Windshield appear to be dirty. | trueno86power | Issues | Warranty | Recalls / TSB | 17 | 08-03-2012 02:20 PM |
| Windshield Protection? | TeaBuoy | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 12 | 07-16-2012 05:16 AM |
