Because compromise ®
Drives: Red Herring
CP8350 (Sprint) Caliper Volume/Capacity
When it comes time to replacing brake fluid how much should I run through the caliper to insure that all the fluid has been replaced? Plus a little in the line as well.
Also, can anyone recommend a (smallish) pressure/vacuum bleeder? Ta. |
#2 |
Site Moderator
Drives: Stuff
I've used a Vacula before, but now I just do the old-school bleed or gravity bleed if I have time to spare.
To flush the system I think I went through about 2 bottles last time (flushed entire system) but it may have been 3. That's 500ML bottles.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#3 |
Drives: Attitude
Motive Products pressure bleeder. It's not a vacuum system, but builds positive pressure to push fluid out. Fill the pump with your favorite fluid and it becomes a one man job. If the old fluid's dirty it should be reasonably easy to tell when there's fully fresh fluid throughout the system. Personally, I liked alternating between ATE Type 200 (amber) and ATE Super Blue (...blue obviously) so that you could really tell when the old fluid was out.
#4 | |
Site Moderator
Drives: Stuff
-Dave
#5 |
We had no issue flushing out the whole system, front and rear, with 1 500mL bottle of fluid, but we've also bled brakes... way too many times. If you want to play it safe, use 2 500mL bottles or 1 1L bottle (depending on the fluid of your choice).
If you have a buddy (or wife, or gf, or kid) that can pump the pedal for you, it's a great way to save some coin. |
#6 | |
Site Moderator
Drives: Stuff
-Dave
#7 |
Drives: TOYOTA
#8 |
Drives: Nevermorange FRS
I had the Griots Vacuum bleeder and thought it was a very good piece but it never quite did the job well enough. One might say, "it didn't suck enough." What I do like vacuum bleeders for (if you have the right adapters) is bench bleeding a new M/C. As far as replacing fluid, depending on how old or heated it was, you may be able to see the color difference. But I'd say about 1 cup is plenty if the fluid in the rest of the system is the type of fluid you're planning on running: aka; you're not completely changing fluids.
If I have nobody to help me then I use speed bleeders, otherwise I just stick the g/f in the driver seat and have her push on the pedal. BTW: the stainless steel speed bleeders are worth the $$ but if you bleed your brakes a lot(like I do: 20 times a year) then you need to remove the bleeder occasionally, clean off the threads and bake new sealant on it and it will work perfectly again. So the trick is keep good ones as spares ready to go and just freshen up the ones coming out and put them back in rotation.
PRO86 | WTCC | STL
#9 |
Site Moderator
Drives: Stuff
Initial batch of Spiegler lines. Essex replaced them all. I installed mine and then got the email the next morning
-Dave
| towing capacity? | CyberFormula | Scion FR-S / Toyota 86 GT86 General Forum | 24 | 11-30-2019 11:34 AM |
| Brake fluid volume | celica73 | Tracking / Autocross / HPDE / Drifting | 1 | 08-20-2012 02:05 PM |
| Fluctuating volume | so26 | Issues | Warranty | Recalls / TSB | 9 | 08-16-2012 12:26 AM |
| Hauling capacity, will they fit?! | CoRi J | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 3 | 06-24-2012 10:49 PM |
| Volume of spare tire well? | djliquidsteele | Electronics | Audio | NAV | Infotainment | 1 | 06-18-2012 12:22 AM |
