Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > Marketplace > Commercial Classifieds > Exterior Parts - Lighting
Old 01-11-2013, 10:43 PM   #43
PhastekSport
PhastekSport's Avatar
Send a message via AIM to PhastekSport Send a message via Yahoo to PhastekSport
https://www.facebook.com/video/video...02700610566650
This is what I'm working on. Changing to ColorSHIFT. More patterns, more colors....
PhastekSport is offline   Reply With Quote
Old 01-17-2013, 06:19 PM   #44
PhastekSport
ColorSHIFT w/ painted headlights and HID bi xenon retrofit kit.
Old 02-14-2013, 07:34 AM   #45
LeviathanDC5
LeviathanDC5's Avatar
Drives: Scion FRS, 97 rb25det 240sx
Originally Posted by Chris@Phastek View Post
Will do...
Houston tonight...
Attachment 22057
Sent from my HTC6435LVW using Tapatalk 2
Is this the blue or white? And are the headlights on as well?
Definitely picking up one of the dual-color halo kits before spring break!
I have another question though... on your website about the pic of the blue halos it says "pictured with blue LED strip in high beam area" is this a separate LED you have hidden to light up your headlight housing??
thanks!
LeviathanDC5 is offline   Reply With Quote
Old 02-14-2013, 10:15 AM   #46
PhastekSport
That was blue. In general it's hard to get a good picture of colored halos. Only the parking lights were on. I think the extended exposure turned the center into a hot spot. The exposure was blown out there.
There was a strip of blue in the housing over the high beam area. Once we get some Spyder Smoked Tail Lights in, we'll probably change the color of the housings once again and stick a strip of RGB in there.
Old 02-25-2013, 02:49 AM   #47
Minovsky
Minovsky's Avatar
Drives: Fr-s 2013 white out
Here's a quick rundown.
CCFL
  • Looks more factory (similar to BMW angel eyes)
  • Comes with inverter boxes
  • Dimmer vs LED
  • Single color only
LED
  • Mounted on printed circuit board (can be painted on the sides to match vehicle)
  • Does not require additional hardware to light up (one positive, one ground wire)
  • Brighter vs CCFL
  • Available in single, dual, and RGB. To create multiple colors and patterns with the RGB, it requires a control box.
Could you do a diy of the wiring needed for the ccfl?
Minovsky is offline   Reply With Quote
halo, halos, headlight, install, kit
**PHASTEK** Rear Fog Light/Brake Light Kit for the Scion FR-S and Subaru BRZ PhastekSport Exterior Parts - Lighting 57 07-10-2017 08:14 PM
PHASTEK Footwell Lighting Kit for the Scion FR-S / Subaru BRZ PhastekSport Interior Parts (Incl. Lighting) 104 04-23-2014 04:31 AM
PHASTEK Trunk Lighting Kit for the Scion FR-S and Subaru BRZ PhastekSport Exterior Parts - Lighting 34 12-11-2013 01:41 PM
Feeler : Flat Black headlight housing with Mormimoto LED Halos MrTranxD Exterior Parts (Aero, Lighting, Etc.) 11 03-13-2013 09:54 PM
**PHASTEK** Reverse HID Kit for the Scion FR-S and Subaru BRZ PhastekSport Exterior Parts - Lighting 10 01-18-2013 11:04 AM
