#10305 |
Kuruma Otaku
The black hatchback?
Because titanium. |
#10306 |
Drives: Some rust bucket
#10307 |
Drives: Attitude
#10308 |
Wayward Member
Drives: Hot Lava 86
So, the Porsche 'build your car' thing has a dizzying amount of options. I don't think I've ever successfully finished building a car on their site.
#10309 | |
Drives: N/A
That's doesn't sound bad at all, even with that mileage. It'll probably go 250k-300k if you take care of it. You might not be as impressed with the fuel economy of the LX. The DX is the most efficient trim if my memory serves me right. Not really into Honda's but I recall some hypermiling discussions about the lean burn era Hondas. |
#10311 | |
The 96-00 DX and LX models have the same motor. The DX is just slightly lighter due to fewer options. The EX and SI models have less efficient motors. So far I purchased some Energy Suspension transmission bushings since the OEM ones feel destroyed. The shifter is very loose even when it's in gear. |
| The Following User Says Thank You to ayau For This Useful Post: | Allch Chcar (02-14-2013) |
#10312 |
Site Moderator
Drives: ichi 86 Project
Ranma 1/2... so classy~
#10313 |
Pedals over Paddles.
Drives: Celica GT-S | 89 Supra | 07' Accent
Toyota is pushing out 3 sports cars; the 86, the Supra and something else. The Supra is coming out in 2017, so i wonder when the other car is coming out(?)
![]() 2002 Celica GT-S Track Car | 1989 Supra Track Car | 2007 Hyundai Accent AutoX | 2003 Cadillac CTS Daily |
#10314 |
Member of the year - 2016
Drives: Scion FRS
Blerghhhh.
Was going to buy a Porsche 942 N/A project car. Found out shipping it here will make it un-worth it. Also partner in crime doesn't show enough interest. Maybe will just get a used Saab...
#10315 |
Señor Member
Drives: 2013 Raven, Drifty things
Besides the shift bushing any other add-ons to make it more driveable? If I wanted to build a daily driver I'd put in the nicest stereo possible, sound-deaden every panel, and replace the brakes. This besides normal older car maintenance, like new spark plugs, new wires, new air filter if needed, possibly new oil. At this point I feel like every honda from that age and before has been in the hands of at least one high schooler and knowing how I drive....hehe
T O U G E - C U L T U R E
Follow me on instagram! :@tougeculture_chris '13 FR-S, SBD Turbo kit, Tein Flex Z coils, other stuff. Drifting and autocross. |
| The Following User Says Thank You to 6-Shift For This Useful Post: | M-17 (02-14-2013) |
#10316 | |
Señor Member
#10317 | |||
Drives: 2013 BRZ Ltd. MT
This is utter nonsense. ![]() Is there a big difference between your Schwinn Cruiser bicycle and a $9000 pro racing bike? Not really. They’re both bicycles, they’re both subject to the same laws of physics, essentially handle the same, ride on rubber tires gripping the road, and basically they both “ride like bicycles.” If you can ride the Schwinn bicycle, you can ride the pro racing bike. FWD vs. RWD? They have the same rubber wheels and they both “drive like cars.” Put your grandma in a RWD car and it’s unlikely she’d ever notice the difference. In fact, she probably grew up with RWD, and until her later years had never heard of FWD, not in the USA. The only real difference of any consequence between the two is what happens when you apply too much power, use too much throttle. You need only remember a few simple things: Your throttle is not a binary device, not an ON/OFF switch. Perhaps think of it as the control on a stereo amplifier; it’s a rheostat, smoothly turning up and down over a wide range of movement affecting the sound output. Your throttle is like that. Unless you’re charging into turns way too fast, and flooring the throttle mid-corner, you’re unlikely to notice a lot of difference between your FWD vs. a RWD car. You’re not going to “shoot your eye out.” ![]() If RWD cars actually posed the threat to life and limb that today’s young folks imagine, then you guys would never have been born -- your ancestors would all have died in horrible, fiery, automobile crashes. Back then RWD was basically the only thing around. ![]() Consider this: Take a front engine, FWD Honda Prelude, and a front engine, RWD FR-S, and zoom them both down into a corner at a speed that is too fast to negotiate the corner. Now, put them each into neutral (no power to the drive wheels), and try to drive each of them through the corner. They'll probably both behave the same and fly off the road the same. See? Now isn't that reassuring? ![]() Think: Throttle Control. You want to be smooth, gentle, and progressive. Use TOO much throttle while cornering in your FWD car and the front end slides out from under you. Do the same in a RWD and the rear end slides out from under you. It’s nothing to fear. It certainly is to be respected, though. It’s a challenge to master driving well, FWD or RWD, and it’s immensely rewarding to get it right. Quote:
Almost every crash I read about on the ‘Net, usually youngsters at the wheel, was the result of “inappropriate” throttle application, and often in the wet or other slippery conditions. Poor judgment was the root cause of the crash, not RWD. RWD can bite, yes, but it won’t if you do not do anything unskilled and foolish. Yet, the same holds true of FWD, too, don’t you think? ... So, you still have to learn to drive a manual gearbox car, then? ... I went back and read some of your previous posts and I see that your purchase involves more than, involves bigger issues than, merely which car to buy. Quote:
| The Following User Says Thank You to Porsche For This Useful Post: | Giccin (02-14-2013) |
#10318 |
Gundam Meister
Drives: A Gundam
I've seen the XV Crosstek in the wild in 3 different colors and I like it a lot. I wonder what people on the forum think about it so far.
| h6 swapouts? any thoughts or advice? | f1ver | BRZ First-Gen (2012+) — General Topics | 53 | 11-21-2014 11:46 PM |
| Aspera's thoughts on AWD/RWD... | aspera | Scion FR-S / Toyota 86 GT86 General Forum | 89 | 11-16-2013 02:55 PM |
| random casual discussion on dynamic brakes | serialk11r | Other Vehicles & General Automotive Discussions | 4 | 07-16-2012 09:34 PM |
| The "if you wanna kiss the backside of white musicians make a thread about it" Thread | aliphian | Off-Topic Lounge [WARNING: NO POLITICS] | 8 | 12-19-2011 07:59 PM |
