Old 02-12-2013, 08:01 PM   #211
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
@Dave-ROR that looks amazing. Hopefully some pictures during the day too?
Tansey86 is offline   Reply With Quote
Old 02-12-2013, 08:50 PM   #212
ayau
Drives: Some rust bucket
I finally mounted the defi's in an MSA 2 gauge pod. The quality of the pod is very good I still hate A pillar locations for gauges I hooked illumination up to the fog logs so I could annoy myself less at night by turning the foglights off which turns illumination off also.
Illumination on:
Foglights/illumination off:
Vision blocked by the a pillar pod (which is why they aren't my favorite setup):
That looks great. The blocked view does suck. Where else could you mount them?
Old 02-12-2013, 10:47 PM   #213
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
That second gauge does block quite a bit more visability.
Old 02-12-2013, 10:49 PM   #214
OrbitalEllipses
Drives: Attitude
A-Pillar gauges need to DIAF. Least favorite spot.
The Following 3 Users Say Thank You to OrbitalEllipses For This Useful Post:
civicdrivr (02-13-2013), Dave-ROR (02-13-2013), Jive Turkey (02-13-2013)
Old 02-13-2013, 12:50 PM   #215
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Yes
I would like to have someone mold gauge pods into the top of the OEM gauge cluster cover/whatever you want to call it. The rounded bit above the gauges. That part is plastic, cheapish to buy and easy to wire stuff into. Also keeps gauges very close to each other and would be a little less annoying.. here's a post I made in this thread with ideas: http://www.ft86club.com/forums/showp...&postcount=159
I might have one on my phone. I'll check.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 02-13-2013, 01:38 PM   #216
Xdragonxb0i
Drives: ex500r
Originally Posted by doggy View Post
Its already in the process of scaning / milling out the mold Will be availible pretty soon 52mm gauges, full replacment for the center vents.
I would make holes larger. So they can fit the stock vents. Then insert a 60mm gauge in it . keeps air flow and look oem
I really llike diy, devi gauge setup in the vent
Xdragonxb0i is offline   Reply With Quote
Old 02-13-2013, 01:50 PM   #217
Zeeberto0
Zeeberto0's Avatar
Drives: Whiteout 2013 FR-S
Originally Posted by PrimeMotoring View Post
Heres my solution to relocating the buttons from the cluster
I really like this set up its nice & clean
New White out FRS owner
Double R Photography
Zeeberto0 is offline   Reply With Quote
Old 02-13-2013, 02:20 PM   #218
King Tut
NASA SpecE30 Racer
King Tut's Avatar
People complain when gauges are located in a spot that is nearly impossible to see while driving then say gauges located at eye level easily viewable while driving need to DIAF. I guess it is a lose lose situation.
Old 02-13-2013, 02:30 PM   #219
OrbitalEllipses
Drives: Attitude
I do not like gauges on the A-pillar. On top of/near the gauge cluster hood is my more preferred location. I didn't tell ya how to mount your gauges, so do what you prefer.
Old 02-13-2013, 02:41 PM   #220
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Thank you for letting me do what I prefer.
Old 02-13-2013, 02:45 PM   #221
OrbitalEllipses
Drives: Attitude
You have my blessing good sir.
Old 02-13-2013, 02:58 PM   #222
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Being able to see them and having them somewhere that's not the A pillar are not mutually exclusive...
Above the gauge hood is easy to see with the other gauges
The MSA is a well done piece, I just don't like losing that much visibility while having that gauges that visible to others around the car. Theft concerns, making it obvious the car likely has some bling parts, etc are all cons to me.
However, until someone comes up with a better solution for two gauges, it's what I'll be using. After seeing MSA's work I'd love to see them come up with a gauge hood solution, then I'll send it to JPM and have it covered in alcantara.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 02-13-2013, 03:00 PM   #223
King Tut
NASA SpecE30 Racer
King Tut's Avatar
That sounds like a winner to me. I would probably add a second oil pressure/temp gauge at that point. I only have the JPM cluster hood so far, but I want it all.
Old 02-13-2013, 06:35 PM   #224
Supermassive
Supermassive's Avatar
I gotta say that the PrimeMotoring solution is actually really good. I have no visibility issues, in fact I can see the whole gauge for my driving position. It's impossible to take a picture that truly represents the view, but I have had no issues seeing it and have never had to adjust my head to see it. I guess during cornering the wheel can block it, but really the only time I look at my Failsafe is when I'm cruising along to make sure I'm still running nice and perfect under boost. I also plan on doing the vent mounted oil/water temp gauge one of these days as well. I don't like pillar pods in the least.
I'm also considering this as well:
http://www.grdtuned.com/m614/Brockwa...9eik1m3j76pg92
We'll see....
Supermassive is offline   Reply With Quote
The Following User Says Thank You to Supermassive For This Useful Post:
Sportsguy83 (03-03-2013)
oil pressure gauge onemorelap Engine, Exhaust, Transmission 69 03-04-2023 06:46 PM
LHD 3-meter gauge-pod? TuxedoCartman Cosmetic Modification (Interior/Exterior/Lighting) 27 02-11-2015 07:19 PM
Gas Gauge Issue Jruex22 Scion FR-S / Toyota 86 GT86 General Forum 12 04-04-2013 11:28 PM
Temperature Gauge a dummy gauge? bambbrose BRZ First-Gen (2012+) — General Topics 40 08-19-2012 05:29 PM
Gauge Sweep? himbo BRZ First-Gen (2012+) — General Topics 17 12-12-2011 12:39 PM
