Old 02-12-2013, 02:44 PM   #1
FR-S Matt
Torque Wrench Needed For Exhaust Installs?
I'm a noob when it comes to working on exhausts since the only ones I've ever had were welded from the header to the tips. Do I need a Torque Wrench for the bolts on the clamps? If anything I know it would be a low in/lbs or ft/lbs for the bolts with the wrench or should I just go in with a regular ratchet/socket combo? I've got a badass Kobalt ratchet that has the gears in it which you just twist, kind of like the Kobalt screwdriver I have as well. Works awesome in tight areas with no movement.
I'm about to install my Nameless Axleback and just wondered if I should bother with a torque wrench or not. I just want no leaks and the proper tightening to be done.
Old 02-12-2013, 02:54 PM   #2
Books
Books's Avatar
Drives: Ultramarine FR-S (MT)
I'm a noobie so take my advice with a grain of salt. I also installed a Nameless Axleback myself (Check my journal!) and just hand tightened. It's been about 3 months and the bolts aren't going to budge.
I was also worried about torquing the bolt... but the real problem ended being the freakin rubber gaskets!
However, I do recommend getting a torque wrench to install almost everything else! I bought a cheap one off Amazon and it's been working great. (And yes, I have checked it's calibration and it's spot on)
PS You'll love the exhaust!
Books is offline   Reply With Quote
The Following User Says Thank You to Books For This Useful Post:
FR-S Matt (02-12-2013)
Old 02-12-2013, 03:05 PM   #3
FR-S Matt
Yeah, I looked at a few Torque Wrenches. I'd love a Snap-ON, lol, but pricewise and the amount I would use it would not make it worth it. Can't decide on 3/8 or 1/2 because some of them have a huge ft/lbs difference in what they can handle. The Harbor Freight version looks cheap, but the digital Craftsman 3/8 looks pretty nice. I think I would get more use out of a 3/8 because I won't be doing serious engine work that would require greater than 80 ft/lbs.
Can't wait to get the Axleback!
Old 02-12-2013, 03:08 PM   #4
Foobar
SLO NO MO
Foobar's Avatar
I've got a 3/8ths as well as a 1/2 - the 3/8ths mostly because I needed a wrench that could do less than 20 ft-lbs for some of the work I've done (including v-clamps for a catback). But yeah, get a torque wrench if you plan on doing anything with any car.
The Following User Says Thank You to Foobar For This Useful Post:
Old 02-12-2013, 03:25 PM   #5
FR-S Matt
I'll probably end up snagging the Craftsman Dr. Digi 3/8 then to start with and get the 1/2 down the road if I need something for suspension/pulley bolts, etc. Thanks for all the help guys!
Old 02-12-2013, 04:44 PM   #6
Jacob G.
Jacob G.'s Avatar
Drives: '13 Scion FR-S Whiteout
Just to let you know that harbor freight is running a deal on the 3/8 Pittsburg pro for $12.99... I thought it was a great price also jack stands for $14. You just need to print out the online coupon which also comes with a 20% off that I added to the wrench
Jacob G. is offline   Reply With Quote
The Following User Says Thank You to Jacob G. For This Useful Post:
Old 02-12-2013, 04:53 PM   #7
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I have a 1/4", 2 3/8"s and a 1/2". You'll need the 1/2" for some stuff generally (axle nuts, etc) but a 3/8" that goes up to at least 90 ft lbs is a good all around torque wrench if you just want one. I can cover 5 in-lbs up to 250ft-lbs with the ones I have
For exhaust, I'll sometimes torque the header bolts.. that's it.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 02-12-2013, 05:01 PM   #8
FR-S Matt
Yeah, if anything, I would be torquing the header bolts once I get that. I think the 3/8 will be a great starter torque wrench for me, then I'll grab the 1/2 as necessary for bigger projects.
I just wanted to make sure the clamps are secure without overtightening the bolts or stripping them.
Old 02-13-2013, 01:13 PM   #9
Xdragonxb0i
Drives: ex500r
No all you need is a socket wrenches. I just took off my mid pipe and exhaust. I'm not sure about your front pipe and headers
Xdragonxb0i is offline   Reply With Quote
Old 02-13-2013, 01:19 PM   #10
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
Just have to calibrate your elbow. Anything going into the engine block or anything that rotates I'd torque to spec. Anything else is gudentite.
industrial is offline   Reply With Quote
Old 02-13-2013, 01:39 PM   #11
FR-S Matt
I'm snagging the Harbor Freight clicking one for 10 bucks after that coupon... hard to pass up even if it does break, but I won't be using it very often so it may work out best for me.
Old 02-13-2013, 01:45 PM   #12
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
Don't cheap out on a torque wrench. You are buying it so you can do things right, what's the point if you buy one that will be completely out of spec after 1 little drop? Most of those cheapie chinese wrenches are way out of spec right out of the box. Buy a quality wrench (craftsman, snapon, mac) and get it calibrated every few years or after a big drop.
Some background: I used to work in a precision measurement lab and I've calibrated torque wrenches amongst other things.
Old 02-13-2013, 02:39 PM   #13
FR-S Matt
Yeah, I've been considering the Craftsman one for 100 bucks, the digital one. I've got an entire mechanic 255 pc set from Craftsman already and I love it. I have never used a torque wrench before and I have heard many say "Go with the digital" ones due to the accuracy. Quality wise, I can image the Craftsman being up there.
Snap-ons are the best in the world, hands down, but come with a hefty price tag.
Old 02-13-2013, 02:40 PM   #14
MikesFRS
MikesFRS's Avatar
Drives: it like he stole it!!
I don't think Ive bought anything from harbor freight that lasted more than a few months. I use a craftsman torque wrench has not let me down for the past 3 years. I usually recalibrate it every 2 months.
Sent from my SAMSUNG-SGH-I777 using Tapatalk 2
MikesFRS is offline   Reply With Quote
Torque wrench... Vendors welcome Freeman Off-Topic Lounge [WARNING: NO POLITICS] 8 01-23-2013 06:30 AM
Digital Torque Wrench - Holiday Special blmw Exterior Parts - The Rest 6 01-14-2013 09:40 PM
Digital Torque Wrench - Holiday Special blmw Announcements, Contests, Giveaways 12 01-14-2013 01:16 PM
Digital Torque Wrench - Holiday Special blmw Engine, Exhaust, Bolt-Ons 21 01-14-2013 10:31 AM
Which type of torque wrench do you prefer? Hanakuso Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 07-11-2012 05:17 AM
