Old 02-11-2013, 06:21 PM   #71
Frostyman
Drives: 2013 Raven FRS
I wish I could hear the damn thing, but there's too much stupid music.
Frostyman is offline   Reply With Quote
Old 02-11-2013, 06:27 PM   #72
SubieNate
SubieNate's Avatar
Drives: 2013 FR-S Ultramarine
I think those asking about overdriving and using a wastegate are less worried about efficiency and more worried about producing some real down low torque.
I think it'd be awesome to design a CVT drive for a supercharger that would deliver the same response curve as the wastegate design but without any real efficiency loss. It would likely be extremely difficult to make one small enough though.
Here's a question. What kind of cruise MPG loss do you guys generally experience? One of the main draws of a turbo system is that being exhaust driven, at low load the turbo is barely doing anything and you can get as good or better gas mileage as an NA setup. Is there any way to minimize the MPG hit with your systems?
Thanks,
Nathan
SubieNate is offline   Reply With Quote
The Following User Says Thank You to SubieNate For This Useful Post:
Pete (02-12-2013)
Old 02-11-2013, 08:53 PM   #73
Brian@Vortech
Brian@Vortech's Avatar
Drives: Vortech Supercharged M6 FR-S UM
Thanks,
Nathan
Loss? At cruise, you will actually gain MPG due to the better atomization of air/fuel. Of course, when you are in boost you'll be using more fuel. It all just depends on how heavy your foot is.
Brian@Vortech is offline   Reply With Quote
Old 02-11-2013, 09:27 PM   #74
ssteer
Drives: 2008 Legacy GT
Sure Brian, the direct injection part of the fuel mapping will be better atomized by a supercharger. Not. And at cruise, with very low boost pressure, if any at all, that'll rattle the air molecules all right.
Sorry, don't buy the better atomization argument at all. Sounds like someone's been watching too many infomercials for the Tornado fuel saver.
ssteer is offline   Reply With Quote
The Following User Says Thank You to ssteer For This Useful Post:
SkullWorks (04-10-2013)
Old 02-11-2013, 09:43 PM   #75
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
8200rpms?
PRO86 | WTCC | STL
Old 02-11-2013, 11:39 PM   #76
Brian@Vortech
Ooooh burn!
I guess over 23 years of factual data and 80+ years of combined turbomachinery experience hold no weight around here. My bad. I guess you must be right.
In all seriousness, while historically this is more frequently realized in truck applications (likely due to their having lower mpg to begin with), it is not smoke and mirrors, and is absolutely not false. The trick is keeping your foot out of the throttle long enough to realize the benefit. Granted, especially in the first few weeks/months of supercharger ownership the average individual will see a sizable decrease in fuel economy due to their new found boost in horsepower (pun intended). However, once you settle back into normal driving habits, it is not uncommon to see an increase in fuel economy when cruising on the highway and other sustained speed driving.
In my own personal daily driver, I used to have a 35 minute freeway commute where I was seeing around 22 average mpg pre-Supercharger, and saw roughly 24 average mpg after my Vortech install. Now of course, I had to go and throw all that away and then some when I put some taller gears in the car...but hey, that's the price you pay to go fast I guess.
The Following User Says Thank You to Brian@Vortech For This Useful Post:
flippy (02-12-2013)
Old 02-11-2013, 11:40 PM   #77
Tradewind
Drives: 2006 Subaru Liberty EZ30 S/charged
Smile CVT
Thanks,
Nathan
Ever looked up the NuVinci drive for superchargers. If you twist Vortech's arm hard enough they might add it into their kit, then you get full boost from idle everytime!
Toyota 86 test driver
Tradewind is offline   Reply With Quote
The Following User Says Thank You to Tradewind For This Useful Post:
jdzumwalt (02-12-2013)
Old 02-12-2013, 01:36 AM   #78
SubieNate
SubieNate's Avatar
I was actually looking at that today. Procharger has a CVT setup as well but the NuVinci looks much more elegant. I'm curious what kind of drive efficiency it can get and what kind of weight penalty it carries.
@Brian@Vortech - can you speak to the advantages/disadvantages of a gear drive vs a traction drive a la Rotrex?
Nathan
Old 02-12-2013, 10:18 AM   #79
catharsis
Drives: honda civic si 08
Screw all the m0ar torque guys. I love this kit for what it does. Gives the car a nice linear power band and produces power up top. It keeps true the character of the motor and the car.
catharsis is offline   Reply With Quote
Old 02-12-2013, 10:23 AM   #80
jdzumwalt
Motor Sports slut
Drives: 13 FRS, 2011 f150eco boost,
Good find seems way better than wastgating excess boost.
jdzumwalt is offline   Reply With Quote
Old 02-12-2013, 12:07 PM   #81
Brian@Vortech
Nathan
I can Nathan.
I suppose the answer would be efficiency and durability.
A precision gear drive system, as would be found in a Vortech supercharger, is elegant in it's simplicity. It performs efficiently with little heat generation and requires minimum lubrication. The major downside is that high-speed gears of this level of precision are very costly.
Traction drives, other than their lubrication system, are also very simple. They rely on several rolling elements to transmit power through patches of a thin film of specialized oil. A traction drive system requires a great deal of pressure applied at the contact patch, usually between 1.0 and 2.0 GPa (150,000 to 300,000 psi). This means that there is material movement with associated heat generation. The Rotrex unit has twelve such patches and generates a substantial amount of heat that must be dealt with. These extreme pressures are to add drive capacity and minimize creep or slip that can generate even more heat and can cause spalling and failure.
The Following 2 Users Say Thank You to Brian@Vortech For This Useful Post:
djdnz (02-12-2013), Pete (02-12-2013)
Old 02-12-2013, 12:20 PM   #82
congiiee
Drives: WRB Subaru BRZ
Hey Brian can you tell us what the fuel management parts will be that come with the complete kit?
congiiee is offline   Reply With Quote
Old 02-12-2013, 01:33 PM   #83
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
Please tell me that reservoir will be sold separately.
post_break is offline   Reply With Quote
Old 02-12-2013, 02:01 PM   #84
Brian@Vortech
Originally Posted by ATL BRZ View Post
@Brian@Vortech , Is this available for purchase separately from the whole SC kit? Many of us that are n/a want to replace the washer fluid tank to make room for brake ducting, oil cooler lines, etc.
The washer reservoir assembly is (or will be) absolutely available separately guys! I don't have MSRP pricing for you just yet on it, but I can tell you that the Vortech part number for the assembly is 4TF155-021. Since we are scrambling to fulfill kit orders, it might be a couple days before I can tell you what that assembly will cost separately. I'll post it up as soon as I have that information available though.
The complete system will be at a modest 6psi, so the factory fuel pump and injectors will be more than adequate for that level of performance. The included Ecutek cable, license, and Vortech tune will compliment the OEM fuel system and be completely safe and reliable.
djdnz (02-12-2013)
Vortech Supercharger denverizzles Forced Induction 176 10-19-2013 06:48 PM
New Vortech Supercharging System Information... Brian@Vortech Forced Induction 306 11-08-2012 05:49 PM
Supercharging the GT86 Billy2224 Engine, Exhaust, Transmission 13 06-05-2012 03:58 PM
Turbo/Supercharging Your FRS BoostJunkie Engine, Exhaust, Transmission 123 05-18-2012 06:26 PM
Supercharging: the forgotten form of FI madfast Engine, Exhaust, Transmission 76 03-02-2012 05:06 PM
