Old 02-11-2013, 03:15 AM   #29
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
Originally Posted by wgnzlz View Post
This picture definitely makes me lean toward +35 offset.
all depends if you intend to go to coil overs, you'll have plenty of room then..
+35 poke out of the side of the car and are illegal here, if the +45 fits (albeit tightly) so what, they are going to touch unless the bearings flog out.
For me if it fits it fits, long term I will put coilovers in.
86•BRZ is offline   Reply With Quote
Old 02-11-2013, 07:37 AM   #30
wparsons
wparsons's Avatar
Originally Posted by 86•BRZ View Post
For the records. Here is a shot of the 17x9 +45 against the std strut.
Attachment 27893
Any chance you have a shot with a 245/40 on the wheel to see how much room there is? Looks extremely tight to me?
flickr
Old 02-11-2013, 07:44 AM   #31
wgnzlz
wgnzlz's Avatar
Drives: 2013 WRB BRZ Limted
It looks tight to me too. I won't be getting coilovers for at least another year, so if the 245s won't fit, I will have to go with a different set of wheels.
What's weird to me is the pictures that I've seen of the +42 Mach V wheels don't look anywhere near as tight and it's only 3mm difference.
Moto-East Tune, Perrin drop-in, P&L Catless Header and Overpipe, Motiv HFC, Invidia Q300, 17x9+35 Enkei RPF1, 245/40 PSS, RCE & Koni Yellows
wgnzlz is offline   Reply With Quote
Old 02-11-2013, 10:15 AM   #32
kanundrum
Drives: 2013 Whiteout FR-S
245's with a 45 offset fit just fine fyi, had it on my car and someone is currently selling the same setup and wheels who has been running them for 2000 miles. I am probably going to get 35 offset with 255 (stock suspension)
Old 02-11-2013, 03:45 PM   #33
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
No tyres on yet. Will be putting 235s on in the next few weeks.
It is tight. But I can't have it nor do in want it poking at the front. +35 pokes.
Tight isn't an issue. It either touches or it doesn't.
Old 02-11-2013, 04:11 PM   #34
wparsons
wparsons's Avatar
I'm thinking +45 with a 5mm spacer to bring it back to +40, or just staying with 8" wheels and 225 tires with +45.
I don't want any poke, especially up front and it's not a race car so I'm leaning towards the 8"/225 option.
flickr
Old 02-11-2013, 04:12 PM   #35
BAE
BAE's Avatar
Drives: BRZ Ltd WRB
How is the steering with 255's in front?
Enkei RPF1/K&N/Perrin crank pulley/Visconti Stg1/Perrin catback and overpipe/KW V3
BAE is offline   Reply With Quote
Old 02-11-2013, 04:33 PM   #36
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
this is the smart move... BUT the 9 inch looks soooo much nicer I just had to have them, I am not usually into form over function....
Old 02-15-2013, 05:50 AM   #37
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
end result....
Old 02-15-2013, 10:40 AM   #38
djjd42
Drives: Whiteout MT now, Alfas in the past.
Sorry for the late reply, I haven't been receiving notifications of posts at all consistently for a while now.
After adjusting toe and getting pressures right the feel is surely different from stock but with this setup it is either similar enough or at least natural enough that I adjusted quickly enough to not really be able to fairly compare them in my mind any more. I can tell I am turning a bit more rubber, but it sure doesn't feel like 40mm more and the grip is outstanding in comparison to stock.
djjd42 is offline   Reply With Quote
Old 02-17-2013, 10:17 PM   #39
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
I'm glad I found this. I was just wondering if I could fit 255s at et 45! I have coils but I was still a little worried.
Old 03-01-2013, 02:45 PM   #40
mtsui
Drives: 135i
this is +45??? howcome it looks like a +35?
thanks
Nick
mtsui is offline   Reply With Quote
Old 03-01-2013, 05:02 PM   #41
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
thanks
Nick
Ummm because 9 inch is frikken wide up front. There is no way around it!
Old 04-20-2013, 12:50 AM   #42
N_I_N
N_I_N's Avatar
Drives: FR-S [Hot Lava]
Silly question. Would this setup be MORE prone to rubbing without lowering the car? I have no intentions of doing any suspension work on mine but I want to go as wide as possible with a square setup. Do these tires clear only because the car is lowered or would it be ok even if it weren't?
N_I_N is offline   Reply With Quote
Enkei RPF1 17x8 Gold + Dunlop Star Specs 255/40/17 on SWP Premium Mitch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 01-08-2014 10:50 PM
Group Buy: Enkei RPF1 17x9 +35, 17x9.5 +38, 18x9.5 +38 ***In Stock*** LSD Motorsports Groupbuys 246 08-29-2013 01:35 PM
Yokohama ADVAN Neova AD08 vs. DUNLOP DIREZZA Star Spec z1 gmookher Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 09-13-2012 10:18 AM
