#29 |
DEEEERP
sub'd
#30 |
Drives: 2013 Raven FRS
HMMM. I don't like how he said they've done only two builds, yet he was saying "guys" plural are getting near 300 from normally aspirated. The wording of the question and subsequent answer leads me to believe the guy is basically bullshitting his numbers. I mean come on, aftermarket exhaust valves having no trouble at all with 11, 12 lbs of boost? I'm pretty sure the stock valves have been handling that already.
| The Following User Says Thank You to Frostyman For This Useful Post: | stevo_12v (12-17-2013) |
#31 |
Drives: Scion FR-S
So what all is it going to take to get this thing to rev to 9000 reliably?
#32 | |
Drives: SS BRZ LMTD 6MT, 92 Civic hatch RHD
Nice to see another Honda guy here. While i don't expect any other car to come close to Honda as far as HP/liter, i've already fallen in love with this platform for its handling, and even though its got less whp than my RSX-S had, it definitely feels faster sooner than my NA K series. My boosted Honda is whole different story... 500HP in a ~2000lb chassis is just stupid fast. terrifying really. I cant wait for my warranty to be up on my BRZ. |
| The Following 2 Users Say Thank You to eljefe For This Useful Post: | NorCalRider (04-26-2013), TouchMyHonda (12-26-2012) |
#33 |
I know Brian Crower is working on a set of cams currently. And can verify that as of SEMA time, Cosworth's goals were to get some intake and exhaust parts together first for the FA20 platform and cams were not even discussed.
We saw this Ferrea setup in person at SEMA and it looks amazing, we will have a set on the way for our motor build on our shop FR-S. |
| The Following User Says Thank You to Dustin@Dynosty For This Useful Post: | JiB (12-17-2013) |
#34 |
Add lightness!
Drives: 17' WRX
Bump. Any updates or news on these or any other internals being worked on for NA apps?
#35 |
Drives: none yet
the 11 12 lbs of boost they were talking about the new gm crate engine, no the FA20.
the trade off to 300na hp will definitely be low end torque that will suffer quite a bit. as far as how to get 300 hp from the engine, he said they have a new head, it ain't just valves and springs. pretty sure some custom cam was involved to add 100hp but it would still be pretty nice to hear. and for running 9k rpm you'd have to get a bigger water pulley to slow it down for sure cause i read someone here saying over 7400rpm the water pump starts to cavitate. |
#36 | |
Drives: Nevermorange FRS
Or you can clip off the tips of the impellers on the water pump. Common "trick" on production based race cars. Often times it's done for the purpose of cheating (reduce the drag from the water pump) but hey... just sayin'.
PRO86 | WTCC | STL
#37 |
Drives: FRS
bump for updates....
#38 |
As a track day guy and daily driven car, I just want the "valley"to be gone(maybe mild cams) and 230whp( car doesnt weight much). Normally mild cams dont kill bottom end and increase top end in a decent manner with gains in the mid range. Consider with the "valley" gone....this car REALLY has a nice pull to it. Hell most of us just want 200whp with simple bolt ons( not sure how realistic that is but.....).
Maybe a USA company will make some mild cams that arent a tall order to tune and reasonably affordable. Then again when I decided to take the high road and NOT do force induction, I knew then it would cost MORE to get decent power. Oh and that 230whp I want is on pump(93). Maybe if it still made decent power at 7500 then good. Thats all THIS suspension guy wants ! Myles |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | EarlQHan (02-09-2013) |
#39 | |
![]() http://www.ft86club.com/forums/showthread.php?t=28480
PRO86 | WTCC | STL
#40 |
Erected Member
Drives: frs
2yrs later....
Whatever happens to this? Was there any valvetrain kit produced for the frs?
#41 |
Drives: toyota mr2/ Toyota GT86
not that I've seen
only report of someone revving high (9K) is the chap doing the racing and he says all he's done is up the spring pressure its on the thread with the blown engine due to lack of oil |
#42 |
Señor Member
I am pretty sure he said they had to do headwork to get power through to 9K.
1974 TA22 Celica
2013 86 GT |
| Clutch Delay Valve? | ashtray | Engine, Exhaust, Transmission | 72 | 11-18-2015 01:10 PM |
| Knock/valve slap/crick noise under accel | yomny | Issues | Warranty | Recalls / TSB | 47 | 01-07-2013 09:53 PM |
| Valve Train Adjustments | @Art_Mighty | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 4 | 09-24-2012 10:10 PM |
| Valve Timing/Computer | miss paula | Issues | Warranty | Recalls / TSB | 3 | 09-20-2012 04:27 PM |
| Name that valve cover!!!! FA20???? | ESBjiujitsu | Engine, Exhaust, Transmission | 3 | 06-05-2012 10:42 PM |
