go_a_way1, MisterSheep
Old 02-07-2013, 02:14 AM   #855
Yruyur
Yruyur's Avatar
Plasti dipped my billet stub antenna as the anodizing was faded.
Old 02-07-2013, 02:14 AM   #856
FR-anco89
FR-anco89's Avatar
Drives: Asphalt FR-S MT
Paid $3.90 per gallon to fill her up
FR-anco89 is offline   Reply With Quote
Old 02-07-2013, 03:01 AM   #857
Cade01
Cade01's Avatar
Drives: '13 White FR-S, 09 Triumph St.3 R
How much weight did it add.
Just weighed a roll of each,looks like if I round up 20 ish lbs(can't remember how many rolls of Peel and Seal I used) I used 3 rolls of FrostKing duct insulation and I think 4 rolls of Peel and Seal, 3-3.5 lbs for a roll of Peel and Seal an 2ish lbs for a roll of FrostKing. I plan on doing the doors with a roll of FrostKing, and if I get ambitious a roll under the headliner. I think I have about $100 or so into it
I know, I know, everyone's like No! The weight! Because RACECAR! But I don't race, it's a daily driver for me, and Because QUIETCAR! lol. It is definitely worth it to me and if I get off my lazy ass I can lose the weight I added.
I wish I had taken pictures while I was doing it and had the car stripped down, it's kinda a bitch pulling those panels off.
Cade01 is offline   Reply With Quote
The Following 2 Users Say Thank You to Cade01 For This Useful Post:
Lav (11-29-2021), Yruyur (02-07-2013)
Old 02-07-2013, 11:02 AM   #858
Kuzuri
__(X)__
Kuzuri's Avatar
Drives: '11 Legacy, '89 190E, '78 GS1000
Originally Posted by Supermassive View Post
Any possibility that you can show how you mounted the latches, and where you mounted what the latches latch onto?
sure i can! Ill get some photos up today for ya
Kuzuri is offline   Reply With Quote
Old 02-07-2013, 12:30 PM   #859
Kuzuri
__(X)__
Kuzuri's Avatar
here you go man... Excuse the dust.. I haven't gotten around to cleaning it after i did all the cutting.
I mounted the post on the headlight tab hole, so if i ever have to take my headlights out again, ill be mad at myself because ill have to readjust the whole thing. I just had to bore out the hole so it was large enough to allow the post to go through it obviously... I was going to use the larger hole (you can see it a little further back) for the rubber hood stoppers, BUT, i noticed that hole lines up basically right on the hood line so that wouldn't work.
and then to mount the latches on the hood, i cut out a hole on the inside to allow the mounting bracket thing to fit though to bolt it down. (ive been thinking about drilling a hole in the piece i removed to let the post go through but then using some epoxy to hold it back on the hood so there isn't a gaping hole on the inside... and then ill just spray paint it black to blend in..)
The Following User Says Thank You to Kuzuri For This Useful Post:
Supermassive (02-07-2013)
Old 02-07-2013, 12:58 PM   #860
iketiak
iketiak's Avatar
Drives: 2013 Toyota 86/Scion FRS
Swapped my FR-S steering wheel out with the JDM Limited GT wheel
Planning to do a full JDM conversion eventually. still waiting on my airbag .
iketiak is offline   Reply With Quote
The Following 4 Users Say Thank You to iketiak For This Useful Post:
calis5nest (02-08-2013), Fizzle (02-12-2013), tdoggy57 (02-07-2013), Tigranakert (02-20-2013)
Old 02-07-2013, 01:17 PM   #861
eddieEndo
Smokin on Dat Endo
eddieEndo's Avatar
how much did the steering wheel and the airbag set you back???
eddieEndo is offline   Reply With Quote
Old 02-07-2013, 01:27 PM   #862
iketiak
iketiak's Avatar
Let's just say with that kinda of money I could have spent it on a lot better things, but my goal is get it as close to JDM spec as much as possible.
Old 02-07-2013, 02:03 PM   #863
Accurate Race Shop
Accurate Race Shop's Avatar
Drives: Scion FR-S
Looks good my buddy has the gt86 but wanted the FR-S I have talked to him about swapping but he has all the trd stuff on his. He is exporting it to long beach when he comes here for work might try to talk him into a trade so I can have the real thing.
Sent from my SGH-T989 using Tapatalk 2
Old 02-07-2013, 09:13 PM   #864
BbOuLoSs
Drives: Scion FR-S
BBS RCs
Havn't seen too many people put these wheels on their frs, I had them layin around so what the heck
BbOuLoSs is offline   Reply With Quote
Old 02-08-2013, 12:25 AM   #865
Amir4571
Drives: FRS RS1.0 #82
Originally Posted by marky View Post
nice...
anyone know how much to candy red the lights or can buy them like that and send mine in ?
I did mine on my own, wasn't all that difficult if you look up the DIY. All I paid for was the spray and that was only 14 and some change.
Amir4571 is offline   Reply With Quote
Old 02-08-2013, 02:53 AM   #866
Supermassive
Supermassive's Avatar
VW center caps...other than that glaring and horrible exception, those wheels look damn nice.
Supermassive is offline   Reply With Quote
Old 02-08-2013, 11:59 AM   #867
Cade01
Cade01's Avatar
nice...
There were some really nice results with Duplicolor Metalcast red and Spraymax 2k clear coat. They are more expensive than VHT but give better results. I used VHT red and had to do a lot of wet sanding and polishing to get it to look nice. I will be cleaning it off and redoing it with the other two I mentioned.
Old 02-08-2013, 05:12 PM   #868
BbOuLoSs
Drives: Scion FR-S
thanks. yeah i know, ive been trying to figure out what to do. I like those center caps but i want to cover up the VW with a scion emblem. the best thing i could come up with is a custom vinyl sticker. I wish i could buy new center caps that say scion but those center caps are specially made for those wheels. they screw on.
suggestions would be appreciated
