Old 02-05-2013, 11:42 AM   #15
OrbitalEllipses
Drives: Attitude
Originally Posted by WolfpackS2k View Post
I guess the AVCS is similar to Honda's iVTEC? That is used on the Civic Si?
From what I understand, yes. Uses oil pressure to adjust cam retard/advance as you'd see on a K-series Honda. Technically this car has DAVCS like later EJ255 blocks and all EJ257 blocks; so both intake and exhaust cams...like iVTEC.
Someone can correct me if I'm wrong, but that's my understanding of it.
Old 02-05-2013, 08:31 PM   #16
dori.
Señor Member
dori.'s Avatar
Drives: white BRZ 6MT
kchkwan, I left the S2000 because I needed a back seat, wanted a coupe and was tired of replacing the S2000's top. At 60k miles it had already worn a hole through it's second top (original replaced at 19k). The reason is a manufacturing defect that Honda has acknowledged via a technical service bulletin. However they rarely cover the cost to fix it and for this top both Honda and the aftermarket warranty I had denied the cost.
BRZNut, it feels just as strong if not stronger down low than the S2000. I feel like the BRZ's suspension is softer than the S2000's but that it stays flatter through turns than the S2000 (less body roll). I haven't had a non-VTEC equipped car since 1999 so its taking me a bit to get used to the more linear power delivery and lack of surge on the top end. Visibility out of the car seems better, however I'm having a more difficult time locating the front corners of the BRZ as it's hood is higher up than the S2000's. The hood height is really the only styling part of the BRZ that I think they could have done a better job with.
Really? I found it to be the easiest car ever to find the front. Hint: use the huge wheel bulges on either side of the hood.
dori. is offline   Reply With Quote
Old 02-05-2013, 08:49 PM   #17
brzninja
brzninja's Avatar
Drives: 2015 WRB WRX Premium
Glad to have you in the House of Subaru
2013 Subaru BRZ Limited WRB
brzninja is offline   Reply With Quote
Old 02-05-2013, 08:52 PM   #18
Jaylyons1
Jaylyons1's Avatar
Drives: 2022 WRB BRZ; 1993 Skyline GT-R
Looks good, I love Satin White!
Jaylyons1 is offline   Reply With Quote
Old 02-05-2013, 09:11 PM   #19
JustStan
Drives: '00 Eclipse GT
Congrats, but I hate you (j/k)! That's the exact car I'm looking for...assuming it's manual!
JustStan is offline   Reply With Quote
Old 02-06-2013, 12:38 PM   #20
WolfpackS2k
WolfpackS2k's Avatar
Drives: '12 C63 P31, '23 GRC
^Yes indeed it's a manual! Haven't owned an automatic since 1999
Have you driven an S2000? Much better visibility over the hood. And those "huge wheel bulges" are about 1 1/2 feet short of the front of the vehicle! I might try raising the height of my seat - I think it's down pretty far. I'm 6'2" but in the seat's current position have plenty of headroom to spare.
Old 02-06-2013, 12:58 PM   #21
dori.
Señor Member
dori.'s Avatar
a) Yes, actually my best friend used to have an AP1. And I've driven two others as well.
b) I'm 5'7" and have the seat as low as possible and visibility is fine for me.
the bulges are supposed to help you place the car in corners; at least that was the design intent behind them. you probably need to get used to it since you are new to the car.
if you just have a problem with the hood height/length, then I'm sure it'll be only a few days until you scratch the underside of your front bumper (almost everybody has lol)
Old 02-06-2013, 01:05 PM   #22
WolfpackS2k
Nah I'm pretty good at not pulling too far into parking spaces. I've had to be careful about that since 1999 when I got the Integra so its always on my mind!
IMO the bulges aren't close enough to the corners for that purpose but I'm sure I will get used to them, just like I'll get used to the higher hood and higher dashboard...
Old 02-06-2013, 01:12 PM   #23
reeves
Once you break-in the car, I think you'll find it pulls pretty aggressively around 5K RPM.. all the way to redline.
Congrats on your new car!
Old 02-06-2013, 02:02 PM   #24
SLOPPYDRFT26
Drives: 07CivicSI
Thats not entirely correct. i believe the ivtec system is a combination of lobe switching and cam phasing, so you still have the vtec kick if not quite as pronounced as the earlier b-series.
SLOPPYDRFT26 is offline   Reply With Quote
Old 02-06-2013, 02:37 PM   #25
WolfpackS2k
I didn't mention it in my previous post but yes I just meant part of the iVTEC. The part that gives it the "i"
I still have my Integra that loves to zing up to 8000, with the big cam bark at 5700rpm
Old 02-06-2013, 02:45 PM   #26
Marcoscrdo
Marcoscrdo's Avatar
Drives: 13' DGM Built FBM BRZ
I had a mostly stock civic before the brz
Marcoscrdo is offline   Reply With Quote
Old 02-06-2013, 03:40 PM   #27
SLOPPYDRFT26
Drives: 07CivicSI
Ok thats cool. i just didnt want people misinformed. imho ivtec is a far better system than the pansy ass AVCS. no offense to everyone who loves the fa20. i am also a fan of the relatively torquey fa20 engine, I just dont like cam phasing over lobe switching. the K20 engine just feels like it has so much more character. It comes to life once you get into vtec and just begs to be revved forever
Old 02-26-2013, 11:38 AM   #28
iLuveKetchup
My VTEC fluid is full
iLuveKetchup's Avatar
Drives: EFF JAY
Is it broken in yet? Would like to know your thoughts now that you've had the car about a month.
iLuveKetchup is offline   Reply With Quote
The Following User Says Thank You to iLuveKetchup For This Useful Post:
kertong (02-26-2013)
New OEM BRZ Gauge Cluster. Zero Miles! Convert your FR-S bambbrose Interior Parts (Incl. Lighting) 17 03-22-2014 05:23 PM
Any way to convert from 5x100 to a more common size? Matt Andrews Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 08-04-2012 02:59 PM
Tonight: I need a Portland BRZ owner and S2000 owner! DarrenDriven Northwest 2 06-19-2012 03:40 AM
LEDs that convert heat directly into light... serialk11r Off-Topic Lounge [WARNING: NO POLITICS] 12 03-10-2012 01:08 PM
convert drum to disk brakes DIG1992 Other Vehicles & General Automotive Discussions 2 11-09-2011 06:04 PM
