Old 02-05-2013, 11:05 AM   #1
grodenglaive
Drives: asphalt FR-S
car locked me out
It was -20 C this morning, so I started the car to let it warm up a bit. When I came back out of the house, the car was locked, but still running! Fortunately I had the spare key in the house. Cold weather gremlins maybe? Has that happened to anyone else?
Good thing it didn't happen at work - that would have sucked.
grodenglaive is offline   Reply With Quote
Old 02-05-2013, 11:44 AM   #2
Wes
Wes's Avatar
Drives: JRSC'd Asphalt FR-S
Nope, but out of paranoia that might happen, I roll down the windows whenever I start her up and im outside my car
Old 02-05-2013, 12:01 PM   #3
Cheddar
Saving them pennies...
Iv never had my FRS auto lock..... How do you set it up because I read the owners manual and didt see anyhting about that.
Cheddar is offline   Reply With Quote
The Following User Says Thank You to Cheddar For This Useful Post:
strat61caster (02-05-2013)
Old 02-05-2013, 12:32 PM   #4
grodenglaive
I'm pretty sure it doesn't have autolock.
Old 02-05-2013, 12:40 PM   #5
Tylub
Tylub's Avatar
Drives: Raven Black FR-S
that's pretty strange, never had auto lock on me either and i start up and close the door and go back into the house and I can always open up my door
instagram @Tylub
Mods: Tomei UELs, Tomei OP, Perrin Catted FP, ARK DT-S, Perrin LW Crank Pulley, Enkei RPF1, RSR Sporti, Supertek Intake Tube, Perrin CAI, Stoptech SS lines/brakes/slotted rotors, Cusco MCB brace/Strut Bar
Tylub is offline   Reply With Quote
Old 02-05-2013, 12:41 PM   #6
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
I do the same, plus I always have my valet key on me.
Old 02-05-2013, 12:51 PM   #7
edj
edj's Avatar
Drives: 2022 Toyota GR86
i have had my car lock the doors on me.
i would curious to know what causes it.
Eric
2022 Toyota GR86 Steel
edj is offline   Reply With Quote
Old 02-05-2013, 01:32 PM   #8
J-Money
J-Money's Avatar
Drives: GT-86
ive had it once..
J-Money is offline   Reply With Quote
Old 02-05-2013, 01:46 PM   #9
Frostyman
Drives: 2013 Raven FRS
That's odd, because you can't actually lock the doors with the door open unless you push the lock itself. The switch will unlock both doors if the engine is on and a door is open. Maybe malfunction?
Frostyman is offline   Reply With Quote
Old 02-05-2013, 01:52 PM   #10
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
I haven't had it happen that way, but the car does have an auto lock. I was showing it to a relative once and I thought he'd want to look inside so I unlocked it, but then we just kept talking while standing next to it. After a couple of minutes I heard it lock back without me hitting the button.
Nevermore is offline   Reply With Quote
Old 02-05-2013, 02:03 PM   #11
b.e
Drives: 2013 FR-S Hot Lava, 2007 Tundra
The FRS does have an autolock. Unlock it with the key fob, and if you fail to open the door, the locks will re-engage. This prevents accidental unlocks when putting your keys in your pocket accidentally triggers the unlock button.
I tested some things this morning after reading the original post here.
When the engine is running, the key fob buttons are ignored.
When the engine is running, the lock button on the driver arm rest will work, but will automatically unlock if the door is ajar. If you start the engine, then step out, this auto unlock function should guarantee the doors will remain unlocked. As far as I could discover, the only way to lock the door with the engine running to to be in the car and operate the lock manually, or press the door-lock button on the arm rest.
My guess is the low temp stressed some lock actuator. Somehow. In a mysterious and probably non-repeatable way.
b.e is offline   Reply With Quote
The Following 2 Users Say Thank You to b.e For This Useful Post:
Dadhawk (02-07-2013), Laika (02-17-2013)
Old 02-05-2013, 02:04 PM   #12
Wes
Wes's Avatar
Yeah it locks within a minute or two after you unlock if you dont open the door, but it should disengage after the door opens
Old 02-05-2013, 02:48 PM   #13
Cheddar
OP is saying it autolocked with the car on....
Old 02-07-2013, 12:36 PM   #14
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
ghost
When doors are locked manually the car won't start whataboutbob Electronics | Audio | NAV | Infotainment 9 10-14-2012 11:10 AM
Post locked? Trikle BRZ First-Gen (2012+) — General Topics 8 08-15-2012 09:26 PM
