Old 12-20-2012, 01:06 AM   #57
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Gotcha.
The 90 degree 2pc, is that the 3/8" one Radium sells as an option for their can or one you had laying around?
I used the 3/8 option one which worked fine
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 12-20-2012, 01:42 AM   #58
OrbitalEllipses
Drives: Attitude
Rubber, it's awesome!
Old 12-21-2012, 07:07 PM   #59
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
[ame="http://www.youtube.com/watch?v=gYDMkqgw-MA"]Toyota 86 Radium Auto Oil Catch Can Checkup - YouTube[/ame]
Car was still warm. So glad that stuff doesn't get returned to coat the valves, etc.
F1point4 is offline   Reply With Quote
Old 12-31-2012, 04:04 PM   #60
sinigang_guy
sinigang_guy's Avatar
Drives: argento frs; 90 mustang gt
thanks everyone for contributing.. almost ready to mount everything up.
just wondering though.. is there a reason why the bracket wasnt mounted to the bolt adjacent to it? would it even work here?
sinigang_guy is offline   Reply With Quote
Old 01-19-2013, 09:34 AM   #61
Margovincent_22x
Margovincent_22x's Avatar
Drives: Lightning Red BRZ MT Limited
OFF topic question: Can someone with a CUSCO oil catch can give a DIY plz. or just pictures where pipes goes in and out. Thanks
Margovincent_22x is offline   Reply With Quote
Old 01-20-2013, 07:58 PM   #62
wbradley
Sarcastic SOB
wbradley's Avatar
Same places, dude. You need to cut the supplied pipe into half. Pull the rubber PCV pipe off where it goes into the intake (under the toyobaru crab which must be removed). Just use the grey plastic tube to attach the rubber PCV pipe to the Cusco pipe. Then connect the other pipe from can to the intake hookup you previously detached.
I removed the rubber PCV pipe completely and rigged an adaptor from the Cusco pipe to the PCV outlet.
I think you will catch minimal oil without putting stainless steel wool into the can as a baffle.
Old 02-03-2013, 05:33 AM   #63
ahaghshenas
ahaghshenas's Avatar
Drives: Subaru BRZ
Anyone doing a Radium Dual Catch can DIY?????
ahaghshenas is offline   Reply With Quote
Old 02-03-2013, 04:34 PM   #64
zex
zex's Avatar
Drives: Subaru WRB BRZ Limited
What do I choose for the inlet/outlet/drain fittings for this catch can!?
zex is offline   Reply With Quote
Old 02-03-2013, 07:56 PM   #65
Dezoris
Dezoris's Avatar
On first page under parts needed.
Old 02-10-2013, 10:34 PM   #66
sinigang_guy
well, hooked up the catch can over a month ago and i see just a hint of oil in there. glad its not going into the chambers.. thanks again for the write up.
Old 02-12-2013, 06:54 PM   #67
sw20kosh
Drives: 2013 Black FR-S
Any other reports on how much oil is actually being collected by others?
Old 03-05-2013, 03:18 AM   #68
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
Just ordered the Radium catch can and also reinforced racing hose and Oetiker clamps. Plan to try and make a really clean looking install that will use the factory strut brace as the mounting location. Will use Redline fuel system cleaner on the next fill up (tomorrow) to help clean out the residue before I fab up the catch can system.
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
Old 03-05-2013, 09:35 AM   #69
xwd
Got the can, went the route of building a bracket to mount over by the battery, worked great and very clean.
Mine did not come with the metal discs, it came with some confetti looking stainless material. Looking at their website, it's what they show in the pictures for the can now.
Oetiker clamps and reinforced hose are probably a bit overkill and a waste of money... These are PCV lines, not fuel lines.
Old 03-05-2013, 10:15 PM   #70
sinigang_guy
this is how i mounted mine:
2013 FR-S Product Technical Info and Specs (from Las Vegas press event) ichitaka05 Scion FR-S / Toyota 86 GT86 General Forum 53 07-19-2021 05:59 PM
Fifth Gear reviews the GT86 (Full Video) lazyluka Scion FR-S / Toyota 86 GT86 General Forum 20 10-10-2012 06:09 AM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
Full Specs and Info on GREDDY SCION FR-S vh_supra26 Scion FR-S / Toyota 86 GT86 General Forum 109 01-02-2012 11:11 PM
