Old 02-03-2013, 02:40 AM   #4551
Jeong
Drives: pet dragon
Originally Posted by Carwhisperer View Post
How is everyone liking their tunes?
enjoying it. had to reflash my car today cause i went to the dealership in the morning. i spend the afternoon adding a pulley, avo inlet pipe, and k&n drop in filter. took a while because im not mechanically inclined. couldnt test it till i left for dinner... with three other people in my car LOOOOOOOOOOOOOL surprisingly my car was still able to pull decently
Jeong is offline
Old 02-03-2013, 03:17 AM   #4552
Mitch
form follows function
Drives: RIP '13 BRZ
I cant remember are the newest tunes still split with e85 and pump gas maps. I still have seperate pump and e85 tunes. I remember when flex fuel came out something was mentioned about it.
Yeah, with the racerom mapswitching update you can have e85 as one of your switchable maps.
Do we have it where the ecu remembers what map you were on last yet, or do the latest tunes still require you to map switch at every startup?
Mitch is offline
Old 02-03-2013, 06:36 AM   #4553
CircuitJerk
Pull my finger...
CircuitJerk's Avatar
Drives: Silver Scion Slushbox
AFAIK pump gas and E85 tunes will remain separate. The flex fuel kit addresses that.
As for the ability to remember the last map, I think that may be something you'll have to live with for the foreseeable future.
CircuitJerk is offline
Old 02-03-2013, 10:02 AM   #4554
Visconti
Drives: 05 STi
Thanks guys
Maps are still separate and Flex Fuel stuff is still in the works.
It's hard to work on some of this stuff when I dont have a car.
For the past month I've been working on my Flex Fuel kit for the GTR.
The kit is now complete
[ame="http://www.youtube.com/watch?v=TsyypLSZHZo"]Visconti Tuning Flex Fuel Kit - YouTube[/ame]
Now it's time to spend more time on the BRZ
Visconti is offline
The Following 4 Users Say Thank You to Visconti For This Useful Post:
sandman126 (02-03-2013), Sportsguy83 (02-03-2013), tripjammer (02-06-2013), Yruyur (02-03-2013)
Old 02-03-2013, 12:15 PM   #4555
ICEBONEZ
ICEBONEZ's Avatar
Drives: '13 WRB 6MT BRZ Limited
Thanks guys
You need to go car shopping lol
2013 BRZ Limited WRB
ICEBONEZ is offline
The Following User Says Thank You to ICEBONEZ For This Useful Post:
Lonewolf (02-03-2013)
Old 02-04-2013, 06:51 PM   #4556
xjohnx
Grip>Slip
xjohnx's Avatar
how is the cold start working on the latest e85 maps?
xjohnx is offline
Old 02-04-2013, 07:58 PM   #4557
fenton
Dead Pedal means your pedal does not function at all - which means there was a flashing error.
But if your hitting the pedal and the car is reving the pedal is fine.
Just put some miles on it
-John
Hey John. I have had a couple of CEL codes over the last few weeks.
Just today i got P0219A while idling.
P219A: Bank 1 Air-Fuel Ratio Imbalance
As per Fr-S repair manual.
Around Christmas time while it was -20C out i got P119F, after a couple days it went away.
Engine Coolant Temperature Circuit Intermittent
Any idea's? I just flashed your newest ROM so they are obviously cleared now.
Thanks,
fenton is offline
Old 02-05-2013, 12:01 AM   #4558
KamalT
Drives: Pearl 86 GT
whats the latest flash number, I have both.
Also where can I find a breakdown of each map setting???
White GT | Visconti_TUNED
KamalT is offline
Old 02-05-2013, 12:07 AM   #4559
cobrabyte
cobrabyte's Avatar
Drives: 2013 BRZ, 2002 WRX
I'm in Texas and garage my vehicle so the ambient temp has been about 60-65º F when I start-up.
I've found that I have to press the gas pedal a few times immediately after starting or the engine will come to a stumbling stop. It's not a big deal. I let the car warm-up a bit and then turn it off and on again -- just to make sure the cams kick on properly.
It's a hassle but it's worth the hassle.
cobrabyte is offline
The Following User Says Thank You to cobrabyte For This Useful Post:
xjohnx (02-05-2013)
Old 02-05-2013, 06:20 AM   #4560
xjohnx
Grip>Slip
xjohnx's Avatar
Yikes, I'll be starting with ambients as low as 20F. Any chance you can check your coolant temp (via ecutek or torque) before you start the car next time?
xjohnx is offline
Old 02-05-2013, 10:27 AM   #4561
cobrabyte
cobrabyte's Avatar
Sure. I'll look at it today before I start up.
xjohnx (02-05-2013)
Old 02-05-2013, 12:59 PM   #4562
cobrabyte
cobrabyte's Avatar
Ambient is 74F and coolant was 26C.
Old 02-05-2013, 06:12 PM   #4563
xjohnx
Grip>Slip
xjohnx's Avatar
Thanks. I'm trying to decide how lucky i feel. My coolant temp for cold start is generally around 7c. I'll probably try my luck and reflash my e85 rom as soon as this tank dries up. A new station opened up only 20 miles or so from me. Before that I would have to drive 70 miles (one way).
@Visconti - With the flex fuel kit, could one expect to see better cold start results by diluting their E85 fillups with a gallon or two of 93?
xjohnx is offline
civicdrivr (02-05-2013)
Old 02-05-2013, 09:34 PM   #4564
fenton
You guys should install a block heater. That would probably help your problems with cold start a lot.
Cost would make up for it by being able to run e85 all year.
Sent from my Galaxy Nexus using Tapatalk 2
fenton is offline
LED Front Signals with Resistor Flash Correctors DarrenDriven Cosmetic Modification (Interior/Exterior/Lighting) 38 09-20-2012 02:05 PM
How to embed a flash gallery? DarrenDriven Site Announcements / Questions / Issues 2 04-24-2012 07:43 PM
Production Spec Subaru BRZ Previewed at National Conference & Latest Info/Rumors blur BRZ First-Gen (2012+) — General Topics 130 09-01-2011 01:42 PM
