Old 11-02-2011, 12:49 PM   #421
no_name
no_name's Avatar
Drives: 2005 Hyundai Accent
You will be able to run less. The ECU will retard timing. You will lose performance AND fuel economy so it's completely pointless to do so though.
I don't mind being down on performance to save some money but if it's going to lose economy also then yeah, no point at all.
no_name is offline   Reply With Quote
Old 11-02-2011, 12:54 PM   #422
ryridesmotox
Drives: 2010 Chevy Cobalt SS, 59 Ford F100
It's not worth running a lower grade... #1 fuel economy, #2 if you try and get on it, you will have increased knock retard in the timing, and #3 at tip in on the road (when you go to pass someone on the freeway) your car will knock. That will seriously mess with the motor and can cause ring damage. Run what's recommended, or don't be pissed if you are unlucky enough to ruin a piston's rings.
Treadstone Performance Stage 3 kit: CAI, Charge Pipes, TR8 intercooler, Maf Relocate, 52MM Turbosmart BOV, 3 inch catless downpipe, 3 inch catback, borla XR1 muffler, Exedy Hypersingle, TWM short throw shifter, 24PSI HPtuned by Terminator2 on E85/91
ryridesmotox is offline   Reply With Quote
Old 11-02-2011, 02:04 PM   #423
no_name
no_name's Avatar
Not all cars that recommend premium actually require it, but they have better performance if you do put it in. The ECU just compensates and you lose some power. I was hoping for a similar case here.
Also, single folding rear seat? No 50/50? I use that to seat 3 people + stuff all the time in my car. This keeps getting worse as a DD. My old 86 was a great DD.
Old 11-02-2011, 02:33 PM   #424
Dragonitti
Didn't see if anyone posted, not going back, but 1/4 mile calculators based on the 2662lbs @ 200hp should net a 14.5 ET Another calc estimated a 13.6 though.
Old 11-02-2011, 02:47 PM   #425
Sparkplug
Rotard
Sparkplug's Avatar
Drives: 135i M-Sport
14.5 is probably more like it. 13.6 for those stats is WAY too quick. Maybe with some crazy gearing...
Sparkplug is offline   Reply With Quote
Old 11-02-2011, 03:29 PM   #426
Allch Chcar
Drives: N/A
Just read the newest translation of the spec sheet. Premium fuel? Crap. I hope that's optional and only required for maximum performance.
If it makes you feel any better I'm going to be paying the equivalent of $4.06 a gallon to run E85 (based on BTU content) when 93 octane is only $3.55. ;p
^This +1.
I'm surprised no one did that recently. And since you did, no one lambasted you for it yet!
"Get Thee Out, drag racer!"
-Allch Chcar
Daily Driver, occasional weekend drifter.
Allch Chcar is offline   Reply With Quote
Old 11-02-2011, 05:11 PM   #427
Dragonitti
I agree, 13.6 is to quick for the specs. 14.5, I can live with that still. It would be getting quicker over time anyway after the mods.
It's still relevant performance #'s for the track too. Lets you know how quick on the straights you will be.
Old 11-02-2011, 06:31 PM   #428
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
I think this car will do 14.7-8.
SUB-FT86 is offline   Reply With Quote
Old 11-02-2011, 06:51 PM   #429
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
It shouldn't be that slow. An ITR with a good driver stock could do high 13s, so this has a little more weight, but a little more traction for launching.. I'd guess 14.3-14.5.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 11-02-2011, 07:31 PM   #430
NESW20
2.1L 3SGTE
Drives: MR2 Turbo & Tacoma
FWIW i will get better performance out of my truck's engine if i run premium. according to wikipedia i would pick up 3hp and 12lb.ft. of torque if i switched to 91. however, that's with my truck's 10:1CR. also, i don't know how much better my mileage would be. if i ever pull a trailer with my truck, it will get premium.
my FRS/BRZ will ONLY get premium.
1991 MR2 Turbo - 2.1L high compression stroker 3SGTE
2006 Tacoma 4x4 TRD Off Road - All-Pro front bumper, Old Man Emu shocks, Old Man Emu HD front coils, All-Pro leafs
1990 240SX Coupe - sold
2008 Civic Si Sedan
NESW20 is offline   Reply With Quote
Old 11-02-2011, 07:46 PM   #431
GotBoost?
Drives: 2007 OBP STI (SOLD)
I think it could manage 13's, I took a bone stock 07 WRX at 224HP/226TQ weighing 3252lb's and ran a 13.7, the lack of TQ might be the problem though. Just need a really good launch
GotBoost? is offline   Reply With Quote
Old 11-02-2011, 07:55 PM   #432
ryridesmotox
I would always be skeptical of what you read on there... the performance is based on many more things than just engine octane... you have to account for volume of air (density, pressure, temperature), compression ratio, fuel temp, fuel pressure, engine temp, cam and valve operation... and many more things. IT's not just throwing higher grade fuel in and calling it good.
Old 11-02-2011, 08:17 PM   #433
Allch Chcar
Drives: N/A
It's not unusual to gain power just by switching octane in a modern engine designed and built for Regular fuel. Plenty of economy cars have higher than optimal compression ratios to improve FE and are tuned to run rich or retard timing under moderate-heavy loads and will run better on Premium. The honda fit's engine for example, dinky little economy tuned engine, will take advantage of premium up to(I believe) 100 Octane. I'm not 100% if that was RON or not but I read a source material on it. Pretty neat stuff.
-Allch Chcar
Old 11-02-2011, 09:59 PM   #434
serialk11r
Drives: '06 AM V8V Coupe
^This +1.
Hehe but E85's high latent heat of vaporization and higher stoichiometric ratio (about 3% of its heat of combustion) gives you about 2% more free power over gasoline, and then improving ignition timing gives you a tiny bit more, so it closes the gap a tiny bit.
And WHAT 93 octane is only 3.55? In California it's like 4 bucks.
brz forum, brz forums, brz specs, brz sti forum, fr-s review, fr-s specs, frs review, frs reviews, ft-86 review, ft-86 specs, ft86 forum, ft86 forums, ft86 specs, scion fr-s, scion fr-s forum, scion fr-s horsepower, scion fr-s hp, scion fr-s review, scion fr-s reviews, scion fr-s specs, scion fr-s weigh, scion fr-s weight, scion frs, scion frs forum, scion frs review, scion frs specs, subaru brz, subaru brz forum, subaru brz forums, subaru brz horsepower, subaru brz hp, subaru brz specs, subaru brz sti, subaru brz sti forum, toyota ft-86, toyota ft-86 forum, toyota ft-86 horsepower, toyota ft-86 hp, toyota ft-86 review, toyota ft-86 specs
AutoBild gives specs of the Subaru BRZ Ice_Man BRZ First-Gen (2012+) — General Topics 43 10-30-2011 07:43 PM
Guessing Scion FR-S specs?? dClutch Scion FR-S / Toyota 86 GT86 General Forum 58 04-29-2011 12:07 AM
If there is no Toyota will you go with Scion or Subaru tranzformer Scion FR-S / Toyota 86 GT86 General Forum 91 04-26-2011 12:53 AM
200hp / 2700lbs - Really? Rickster Scion FR-S / Toyota 86 GT86 General Forum 385 04-18-2011 03:47 PM
TRD options and Badging? BanningFT Scion FR-S / Toyota 86 GT86 General Forum 43 11-08-2009 04:53 AM
