Old 02-01-2013, 01:23 PM   #29
*KID*
86-er
*KID*'s Avatar
Drives: BRZ tS
Hows the performance with those spacers on there.
2018 Subaru BRZ ts 020/500 - My Daily, work car, and track car
*KID* is offline   Reply With Quote
Old 02-01-2013, 01:28 PM   #30
Calin
VTEC just kicked in, yo!
Calin's Avatar
Drives: World Rally Blue BRZ - 6MT
I haven't noticed a difference, but I also haven't pushed the car very hard since I'm still breaking it in. I'm only at 750 miles so far.
Calin is offline   Reply With Quote
Old 02-05-2013, 07:20 PM   #31
Ungkon
Drives: Scion FRS
looks nice. I will go with the 30mm for the back, thank.
Ungkon is offline   Reply With Quote
Old 02-05-2013, 08:30 PM   #32
Chewie4299
Spaceman
Chewie4299's Avatar
Drives: 2013 Firestorm Scion FR-S
Looks good
Chewie4299 is offline   Reply With Quote
Old 02-06-2013, 11:18 AM   #33
Robmilkshakes
Drives: '94 Miata R Package
I'd like to eventually see this set up with the stock wheels painted silver.
Robmilkshakes is offline   Reply With Quote
Old 02-06-2013, 11:33 AM   #34
Calin
Calin's Avatar
Thanks! Ya I went with the 25mm, but it looks like I still have a slight gap that can be filled a little more. 30mm be fine without rubbing
Old 02-06-2013, 11:48 AM   #35
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
Originally Posted by Calin View Post
I'm not sure, but I'm sure there's a reason why most manufacturers don't make better fitting wheels lol
That would be for aerodynamics. The more wheels stick out, the more they mess with the laminar flow around the car. Also flush wheels will sandblast your fenders. Take a good look at the airflow when it interacts with the wheels. Keep in mind, when the wheels are actually in motion they cause even more turbulence.
[ame="http://www.youtube.com/watch?v=I4jVvySELu8"]Caedium CFD Simulation of a Closed Wheel Race Car - YouTube[/ame]
industrial is offline   Reply With Quote
The Following 2 Users Say Thank You to industrial For This Useful Post:
kothetimeless (04-10-2019), Vic4uf (05-24-2017)
Old 02-06-2013, 12:02 PM   #36
Calin
Calin's Avatar
Ahhh, good point. Thanks! I didn't think of aerodynamics.
Old 02-06-2013, 12:02 PM   #37
6-Shift
Señor Member
6-Shift's Avatar
Drives: 2013 Raven, Drifty things
I wonder how fender flares would affect this...
T O U G E - C U L T U R E
Follow me on instagram! :@tougeculture_chris
'13 FR-S, SBD Turbo kit, Tein Flex Z coils, other stuff. Drifting and autocross.
6-Shift is offline   Reply With Quote
Old 02-16-2013, 01:05 AM   #38
zooplane
Drives: SSM BRZ
Just in case anyone wants to make their stock wheels look a little better, 20mm front and 25mm rear spacers is a pretty good combination. You can actually even do 30mm for the rear.
And some before and after shots
Why did you go with Eibach's pro-line rather than their pro-kit? I know the drop is more but are the stock shocks going to last with that large of a drop you think?
zooplane is offline   Reply With Quote
Old 02-16-2013, 03:48 AM   #39
Calin
Calin's Avatar
I just like the more aggressive drop on the Sportlines. The Pro kit barely drops the car, and that's not enough for me. I know the shocks will wear out faster, but those can be replaced. They shouldn't wear out too fast.
Old 02-16-2013, 10:19 AM   #40
trueno86power
[||•]=(86)=[•||]
trueno86power's Avatar
Drives: 2017 Toyota 86
Wow! Look really great! 30mm in the back would look a little bit better IMO but your car look great!
trueno86power
GR | TOM'S | TRD
2017 Toyota 86
trueno86power is offline   Reply With Quote
Old 02-16-2013, 11:04 AM   #41
ZDan
ZDan's Avatar
Drives: '23 BRZ
I think factory fitments are more "sunk" due to clearance regulations. You have to be able to clear a significantly larger theoretical spec tire which is much larger than tires ever are. Add to that production tolerance stackup and general conservatism, and you end up with HUGE clearance between tire and fender.
FWIW, I'd sooner apply spacer money to wider wheels/tires at closer to stock offsets. Spacers muck with suspension geometry and particularly scrub radius.
Of course a set of 245/40-17s and 17x8.5 wheels aren't cheap, though...
Old 02-16-2013, 11:12 AM   #42
Calin
Calin's Avatar
Thanks! Before I got the spacers, I was actually worried about the 25mm spacers being too much and my tires rubbing. But I was wrong. A 30mm should fit just fine. But I'm ok with the 25mm for now. I'll eventually get different wheels with a good offset
Eibach 20mm spacers just put on! SMOKETREES Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 12-18-2013 10:13 AM
FS: Eibach Sportline Springs in AZ AZ BRZ Brakes, Suspension, Chassis 14 02-05-2013 07:27 PM
STI BBS wheels in gold $600 w/5x100 to 5x114.3 25mm spacers saiyajinimports Great Lakes 9 01-24-2013 10:51 PM
Eibach sportline lowering springs.. frsguy707 Brakes, Suspension, Chassis 24 12-14-2012 01:01 PM
GTA FS: Eibach Sportline springs, BNIB l8apexr Canada Classifieds 14 12-05-2012 02:50 PM
