Old 11-02-2011, 01:34 PM   #43
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Too bad I don't see any brake specs Toyota isn't listening to my requests
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 11-02-2011, 01:35 PM   #44
tranzformer
Delights in pure handling
tranzformer's Avatar
Drives: Zoom Zoom
Originally Posted by SUB-FT86 View Post
When you sit in car like this and the weight dist is 53/47, depending on the weight of the person you can cause some rearward bias to make it closer to 52/48 or 51/49? Also putting the battery in the trunk helps too.
How hard to rewire the battery into the trunk?
tranzformer is offline   Reply With Quote
Old 11-02-2011, 01:35 PM   #45
dilly-o
Drives: 1996 300ZX
Originally Posted by oldskule View Post
And two golf bags too (I think).
or body bags (gotta market to people in new jersey too)
dilly-o is offline   Reply With Quote
Old 11-02-2011, 01:39 PM   #46
Sparkplug
Rotard
Sparkplug's Avatar
Drives: 135i M-Sport
Good info here, but tough to tell what's going on with the torque/hp graph photo. The numbers just don't seem to jive with one another that well.
Sparkplug is offline   Reply With Quote
Old 11-02-2011, 01:39 PM   #47
Slide
Drives: Toyota Aristo
Does it say the front seats have memory of last location...
So when u fold the front seats down it know where to go back to cause good I hope so.
Slide is offline   Reply With Quote
Old 11-02-2011, 01:40 PM   #48
skeeler
skeeler's Avatar
Drives: Miatas of Various Kinds
From the "see-through" drawing, the driver's center of mass appears to be approximately halfway between the axles, so the weight will be added about equally to the two axles. So it's not like, say, and NC Miata that is a percent or two front-heavy empty but 50/50 with a medium-sized driver.
Adding passengers to the back row will certainly put more weight on there rear axle.
DD & STR: 2009 Miata. DD & HPDE: 1995 Miata. Sold: 2004 Mazdaspeed Miata, 1991 CRX, 1977 280Z.
skeeler is offline   Reply With Quote
Old 11-02-2011, 01:41 PM   #49
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
Drives: Swagtron Scooter
If you take a look at the other cars listed under the 460mm..(18.11)
LFA 445mm (17.5)
GTR 495mm (19.48)
360 447mm (17.59
STI 534mm (21.02)
Im pretty sure thats Center of height, which is loosely translated to CoG
CdA lists at 0.27 which is same as the 09 GT-R (.27)
WingsofWar is offline   Reply With Quote
Old 11-02-2011, 01:41 PM   #50
Mari0
Car Enthusiast
Mari0's Avatar
Drives: tC 05 & 07, Rav4
INFORMATION OVERLOAD!
Mari0 is offline   Reply With Quote
Old 11-02-2011, 01:43 PM   #51
madfast
Drives: 2010 Evo X MR-T
Originally Posted by Ryephile View Post
The engine specs look good; 12.5:1 static CR is typical for n/a DI. The problem I see is the torque/power graph; it doesn't jive at all with the 197HP peak @ 7k RPM and 151LbFt peak @ 6600 RPM. There's no numerals for RPM on the graph, however torque and power peak appear to be much further than 400 RPM apart, more like 1400 RPM apart. Also, I'm not a fan of that torque curve; it's too much like an n/a 2ZZ or F20; it won't feel natural, linear, or flexible like the Miata engine.
i expected a much flatter torque curve. is this D-4S related perhaps? in the literature there is talk of the engine using a mix of DI and PI in low and mid rpm, and DI only in high rpm...
madfast is offline   Reply With Quote
Old 11-02-2011, 01:44 PM   #52
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
super easy,
get a kit from summit racing to make life easier
Old 11-02-2011, 01:45 PM   #53
RRnold
2 wheel member
RRnold's Avatar
Drives: JZA80, 997.1, Taco
More info!!! Keep it coming Hachi! :happy0180:
Talk about high compression!
So that is how they expect us to haul a set of 4 wheels, your gear and a full size jack. Gotta do what you gotta do and make it happen!
This car is definitely a home run inside and outside!
Old 11-02-2011, 01:45 PM   #54
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
Never tried it before but love the idea of it. Moving weight is better.
SUB-FT86 is offline   Reply With Quote
Old 11-02-2011, 01:46 PM   #55
Slide
Also noticed that transmission could be dirtictly linked to the gear seeing how Dar back it is looks perfectly inline
Old 11-02-2011, 01:47 PM   #56
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
^ i wonder if its even necessary. the battery is already mid mounted on the firewall
Official FT-86 Specs / Info Thread Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 203 09-09-2019 10:43 PM
FT-86 / FR-S size dimensions compared to Genesis, Civic, Sction tC, etc JDMinc FR-S / BRZ vs.... 559 05-15-2014 07:50 PM
Engine technology thread. Dimman Engine, Exhaust, Transmission 762 04-12-2012 02:18 PM
Ducati 1199 Superquadro engine specs RRnold Other Vehicles & General Automotive Discussions 9 11-21-2011 01:36 AM
86 Drag car?!?! MtnDrvr86 Other Vehicles & General Automotive Discussions 5 01-14-2010 06:35 PM
