Old 12-17-2012, 06:44 PM   #85
mdf4uk
Drives: 13 Firestorm FRS MT & 09 DGM WRX
And the back:
mdf4uk is offline   Reply With Quote
Old 01-31-2013, 03:09 PM   #86
DSMDave25
DSMDave25's Avatar
Drives: ZN6
For those interested I ordered the nameplate emblem off the 2003-2006 camry as I find its the most closest if not the same :P as the nameplate that goes on rear of the toyota gt-86.
Here are the emblems I got from the dealer today! The nameplate emblem was 12$
DSMDave25 is offline   Reply With Quote
The Following User Says Thank You to DSMDave25 For This Useful Post:
GTHachiRoku (07-09-2013)
Old 07-09-2013, 07:28 AM   #87
GTHachiRoku
Big in Japan
GTHachiRoku's Avatar
Drives: turBRZ
Awesome, it looks like the same size as the JDM Toyota badge. Post up some pics of that bad boy on your car!
I'm going to swing by my local Toyota shop to get one of these. Then the only badge I'll need is the JDM GT86 badge... which I should be able to pick up in October.
GTHachiRoku is offline   Reply With Quote
Old 08-14-2013, 02:25 PM   #88
DSMDave25
DSMDave25's Avatar
Drives: ZN6
Sorry for the extremely late reply! I haven't logged on in ages
Sure thing! Again I found this nameplate emblem closest to the GT86 than the others. The matrix nameplate for example...the font was too thick.
The two "T" emblems fit right on perfectly. I managed to pick up a set of the "JDM" red piston badges too
Old 08-14-2013, 03:04 PM   #89
Lverasky
RedBunny w/ Wing
Lverasky's Avatar
The part number
90975-02069
90975-A2003
which is front and rear??? are they fit perfect on the FR-S???
Old 08-15-2013, 03:00 PM   #90
DSMDave25
DSMDave25's Avatar
Drives: ZN6
90975-A2003 is for the front
90975-02069 is for the back
And it is a direct fit, the pins on the emblem line up with the datum holes on the car
**Toyota 86 Fog Light Bezels $34.9, 86 Arm Rest, GT86 Badge, Fog Light Set for $112.9 nigel-jdmparts Exterior Parts - The Rest 524 02-28-2016 10:24 AM
Swap your Scion key emblem for a Toyota Synack Scion FR-S / Toyota 86 GT86 General Forum 6 08-03-2012 05:58 PM
Plastidip emblem??? jarviz Cosmetic Modification (Interior/Exterior/Lighting) 20 08-02-2012 03:21 PM
Toyota Emblem replacement jarviz Cosmetic Modification (Interior/Exterior/Lighting) 3 07-26-2012 11:12 AM
Non USDM BRZ oil weight BMWDavid Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 06-21-2012 02:55 PM
