Old 01-31-2013, 04:11 AM   #1
Mark Slide Squad
Mark Slide Squad's Avatar
Drives: 2013 Whiteout FR-S 6MT, S14 Kouki
My track day video at Willow Springs 1-19-13 vs S2000/FR-S/RX8
This event was a blast. It was the first FT86 cup event (results don't count toward championship) and I was happy to place 2nd place in the Under Class
There is some good footage of @robispec behind me as well! My best lap is a 1:27.3, but I know I have room for improvement.
[ame="http://www.youtube.com/watch?v=ecaW8fZvJCM"]Scion FR-S at Streets of Willow Extreme Speed 1-19-2013 track day compilation - YouTube[/ame]
Mark Slide Squad is offline   Reply With Quote
The Following 5 Users Say Thank You to Mark Slide Squad For This Useful Post:
AAI motorsports (02-04-2013), CSG Mike (01-31-2013), philstar (02-04-2013), Touge Monster (02-01-2013), ultra (02-01-2013)
Old 01-31-2013, 06:31 AM   #2
robispec
Drives: Black frs project
nice!
robispec is offline   Reply With Quote
The Following 2 Users Say Thank You to robispec For This Useful Post:
CSG Mike (01-31-2013), Mark Slide Squad (01-31-2013)
Old 01-31-2013, 09:09 AM   #3
ft86Fan
ft86Fan's Avatar
Drives: FR-S, Exige S, Miata
Why is your car so loose? What is your alignment?
'13 Scion FR-S (Whiteout)
'07 Lotus Exige S (Aspen White) Touring, Traction, Starshield
'95 Miata (Montego Blue)
ft86Fan is offline   Reply With Quote
Old 01-31-2013, 01:12 PM   #4
Mark Slide Squad
Alignment is a factor as it it set to zero degrees all the way around, but a big reason for it being very loose that day is because the temps were extremely cold at around 40 degrees. Once the tires got to temp after several laps, it was much, much better. Most of the footage of me getting sideways is because it was the first few laps and the tires were still cold
Old 01-31-2013, 01:46 PM   #5
CSG Mike
CSG Mike's Avatar
Have you ever measured tire temps and pressures mid session? I think the looseness may be a result of your driving style and the spring rates. Based on the video, it seems you use the front tires more than the rears (partially style, possibly as a result of spring rates), causing them to warm up faster.
Just some speculation...
Old 01-31-2013, 01:57 PM   #6
Mark Slide Squad
I think that also plays a factor into it, I didn't measure temps of the tires, but I did check pressure. When cold, all four tires were set to 33 psi. After about 6 laps, I checked and the left side front and rear were about 42 psi, and the right front and rear were 38 psi. That told me that the track is much more abusive of the left side of the car, and while I didn't monitor temps, the left side is getting much hotter than the right side. I dropped the hot pressure down to 37psi on all four and went back out. The definitely felt more stable after that. It's something I've got to keep a closer eye on for sure. The spring rates also attribute to the looseness, being 9kg front and 7kg rear. Coming from years of drifting though, I like it loose (eerr, cars that is!) haha.
The Following User Says Thank You to Mark Slide Squad For This Useful Post:
ShoShin (02-01-2013)
Old 01-31-2013, 02:50 PM   #7
CSG Mike
CSG Mike's Avatar
9k front 7k rear? Did I read that right? That sounds like it would be massively understeery unless you're compensating with damping or sways.
Do you have sways?
We're on 10/12 f/r, and I think its pushy :p
Old 01-31-2013, 02:58 PM   #8
Mark Slide Squad
Do you have sways?
Yup, 9kg front and 7kg rear, which are the stock springs in the Buddy Club Racing Spec Dampers. These dampers are the same as the D1 spec dampers they sell, except the Racing Spec come with camber plates. I think the valving plays into it, as it tends to be a little softer in the front than rear, I'm still not 100% dialed in on the damping settings though, and need to fine-tune more.
I have stock sway bars, just have the Perrin adjustable end links on the rear bar to compensate for the binding issue with the stock rear end links.
I'm going to try different spring rates eventually, just want to see what I can get out of the factory Buddy Club set up
Old 01-31-2013, 03:21 PM   #9
Xdragonxb0i
Drives: ex500r
nice video. Wish i had a track to play on!
Xdragonxb0i is offline   Reply With Quote
The Following User Says Thank You to Xdragonxb0i For This Useful Post:
Old 01-31-2013, 03:30 PM   #10
RYU
RYU's Avatar
Drives: really slow...
1:27 is pretty quick. What tires were you on?
btw... saw you waived by Willem in his NSX. He did a 1:23 that day.
here's a vid you might enjoy (different perspective, same day)
<iframe width="560" height="315" src="http://www.youtube.com/embed/Fnro2kQnb3Q" frameborder="0" allowfullscreen></iframe>
RYU is offline   Reply With Quote
The Following User Says Thank You to RYU For This Useful Post:
Mark Slide Squad (02-01-2013)
Old 01-31-2013, 03:38 PM   #11
Mark Slide Squad
I was on Hankook RS3 245/40/17.
You know Will? He's one of my best friends for the past 10 years. His NSX is so awesome, I'm very envious! It's a quick car, very well balanced/tuned
Old 02-01-2013, 01:23 AM   #12
sw20kosh
Drives: 2013 Black FR-S
Nice video! Good driving, fun to see tail end get loose!
Can you elaborate more on this binding issue? Does this happen in stock config too?
The Following User Says Thank You to sw20kosh For This Useful Post:
Old 02-01-2013, 02:57 AM   #13
AlvinT@Borla
Drives: vw mk4 r32
Originally Posted by robispec View Post
nice!
Enjoyed video @3:40 with Robi... Thanks for posting!
AlvinT@Borla is offline   Reply With Quote
The Following User Says Thank You to AlvinT@Borla For This Useful Post:
Old 02-01-2013, 09:22 AM   #14
ft86Fan
ft86Fan's Avatar
Loose or not, it looked like you had fun and always in control. Good job.
The Following User Says Thank You to ft86Fan For This Useful Post:
$110 Track day at Willow Springs- Streets of Willow- Nov24-25 Socal Louie Southern California 7 11-18-2012 09:30 PM
$90 Track day at Willow Springs- Streets of Willow- August 12th Socal Louie Southern California 2 08-10-2012 02:13 AM
$85 Track Day@Willow Springs-Street of Willow- July28-29 SoCal Louie Southern California 15 07-23-2012 01:02 AM
$95 Track Day@Willow Springs-Street of Willow- Dec31 SoCal Louie Southern California 0 12-25-2011 05:45 PM
$125 track day at Willow Springs-Big Willow Track-February 5th in SoCal Louie Southern California 3 01-07-2011 11:26 AM
