Old 01-31-2013, 02:07 AM   #71
Racecomp Engineering
Originally Posted by 03Z33 View Post
Cusco Retail on the 4.556 is $937 but discount structure is different than other Cusco products since it's a rebranded OEM Toyota part.
The 4.556 was previously a TRD Japan part # 41201-SE100 (now discontinued) which used to retail for $700'ish in Japan
The Toyota part numbers originally posted by Jeff Lange are:
3.58:1 - 41201-80125
3.73:1 - 41201-80050 (OEM Base FR-S/86/BRZ)
3.91:1 - 41201-80052
4.10:1 - 41201-19605 (OEM Torsen equipped FR-S/86/BRZ)
4.30:1 - 41201-29606 (OEM MK3 Supra Manual non-turbo w/LSD) (Included pinion seal will not fit) Currently available in USA from Toyota dealer for roughly $700
4.56:1 - 41201-19557 Toyota Japan only, does not come up in USA parts catalog (Included pinion seal will not fit)
Auto Factory sell the OEM Toyota 4.556 in Japan for $500
http://autofactory.jp/product/topv.p...&cate=7&seq=13
Auto Factory also offer 4.8 & 5.1 gears which require a spacer (included) to work, those retail for $825
http://autofactory.jp/product/topv.p...s&cate=7&seq=6
http://autofactory.jp/product/topv.p...s&cate=7&seq=5
Revolution also offer the 4.8 & 5.1 gears for a slight mark-up around $920:
http://revo-tune.jp/catalogue/detail.php?id=287
http://revo-tune.jp/catalogue/detail.php?id=286
Revolution also offer the 1'st & 2'nd gear same as Cusco but for less at $1840
http://revo-tune.jp/catalogue/detail.php?id=288
MFactory also offer 4.44 & 4.67 final drive for $749 retail, these are not OEM Toyota parts but aftermarket made overseas (Australia or Hong Kong I believe)
http://www.teammfactory.com/final-drive-gear_Subaru
I purchased my 4.556 from Cusco because of the convenience and because I didn't want to wait since I have the diff cover and GT LSD all here ready to go in the car this week.
Just figured I'd share my research leading up to this $$ purchase in case it helps anyone else in future.
I would like to see a STOCK BRZ run a STOCK BRZ with 4.55.
THAT would be nice to see.
Mw
NWFRS (07-16-2015), Ris (12-25-2014)
Old 01-31-2013, 02:56 AM   #72
WolfsFang
Scrape Master
WolfsFang's Avatar
Drives: Goal: Oldest FRS State Side
I'm 250lbs but this spring I will get a friend of mine who is a serious drag racer AND weighs 145 (constipated) to run my car in the quarter. Kind of curious what it does with 190whp and 2550 lbs and 4.55 Final.
stick me in the car im only 125
You do realize comparing the BRZ to the FR-S is like comparing which hand you love masterbating too right?
WolfsFang is offline   Reply With Quote
Old 01-31-2013, 03:40 AM   #73
ft_sjo
Drives: GT86
Is the pinion seal an issue? Are they readily available to work with an OEM 4.55 or whatever?
Old 01-31-2013, 08:01 AM   #74
Captain Insano
correct some IS300's and IS250's came with LSD ANDthe 4.55 FD. Some guys on the Lexus forum found those in salvage yards. Not a easy find but normally cheap.
Yes this is VERY much a drivers mod making better use of our limited power and light weight.
One of my employees says all it needs now is a sequential box !
Myles
Can't tell if you were serious or joking about the sequential. Regardless, when I drive my AT (I drive it in manual most of the time) it feels very much like I'm driving sequential box performance car. The final drive modificaiton has me very intrigued after your review - even moreso than I already was. I really want to do this at some point on my car along with software tuning for more aggressive shifts....
Thanks again for the review and info.
Captain Insano is offline   Reply With Quote
Old 01-31-2013, 02:21 PM   #75
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
looks like i'm going back to trolling lexus forums any idea on year that the 250/300 came with a 4.55? on lexus's website the 2012 250's come with a 4.1..found a few local wrecked ones but all have the 4.1.
trying to figure out a way to keep this mod on the more affordable side before i give up and shell out for a cusco any aftermarket lsd's that already have an upgraded drive so we can i can just swap in my driveway?
Jive Turkey is offline   Reply With Quote
Old 01-31-2013, 02:44 PM   #76
Calum
That Guy
Drives: 2013 asphalt FRS MT
I just can't stop thinking about this FD change with this power curve.
Old 01-31-2013, 03:15 PM   #77
wootwoot
Drives: FRS
UPDATE:
I have been looking for a Lexus IS300 or 250 differential to swap in as a way of getting the 4.55 final drive. THEY WILL NOT BOTH WORK. They differ in the way they bolt up. The axles are also different. At this point I am stuck.... Even if I get a unit that bolts up I cannot be sure the axles will fit. Any advice would be appreciated. I don't mind doing the leg work so the community can find a source of parts and even a DIY... But I can't buy both of them on a gamble.
Old 01-31-2013, 03:28 PM   #78
I'll drop your azz off at Wendys dude ! hahaha JK.
Mw
Old 01-31-2013, 03:43 PM   #79
a GOOD seq box is about 30k. If I had that laying around it would be a DP on a GT3. Either way my wife would divorce me and I'd be living in the shop but have an AWESOME shifting BRZ !
Mw
Old 01-31-2013, 03:49 PM   #80
kanundrum
Drives: 2013 Whiteout FR-S
I'll PM you.
...I could buy a crappy mechanical LSD for that kind of money. I'll definitely look for this in a yard or Lexus forum.
Oh yea so why no LSD? Is the torsen unit good enough?
Old 01-31-2013, 04:25 PM   #81
OrbitalEllipses
Drives: Attitude
Good enough for street. If I was serious about competition I'd have a Guard Transmissions unit with custom ramp rates, etc. but that's over $2K. If I can get the FD for $500ish parts and good labor I'll be happy. That's not happening for a while though.
LenA (03-24-2016)
Old 01-31-2013, 06:11 PM   #82
wootwoot
Drives: FRS
UPDATE:
It was just confirmed that the IS250 DOES NOT come in a 4.55 final drive. I just got off the line with a parts distributor from Lexus and this was the information he gave me. I am still waiting to hear back on if the IS300 has it, but considering I haven't been able to find one anywhere I think we are chasing unicorns here. My guess is that there won't be an easy swap available. I will post back when I here from him again.
Old 01-31-2013, 07:30 PM   #83
Captain Insano
Mw
Ha... Well I know a good one is way out of range for my budget... Just sayin, that's what my AT reminds me of in manual mode... I know it is definitely not in the same ballpark as a real race sequential transmission.
Old 01-31-2013, 07:37 PM   #84
TouchMyHonda
Vtec Jesus
TouchMyHonda's Avatar
Sick tits. I have a 4.785 fd in my 5 speed trans. I sit 5k exact at 80 mph in top gear. With 240whp I never down shift on the highway ever haha.
TouchMyHonda is offline   Reply With Quote
cusco final drive
PST Carbon Fiber Drive Shaft Installed msile Engine, Exhaust, Transmission 155 08-28-2018 07:53 PM
Mfactory Final Drive Ring and Pinion Crossover Auto Engine, Exhaust, Transmission 87 05-26-2017 02:21 AM
FT86 Suspension- D2/BC/Cusco/Megan/Tanabe/Tein/KW/Cusco/Ksport/Eibach/Perrin JM Auto Racing Brakes, Suspension, Chassis 271 03-22-2014 12:17 PM
Is my Cusco catch can correctly installed? wbradley Engine, Exhaust, Transmission 9 02-24-2014 09:49 PM
Has anyone actually seen any of the Cusco roll bar / roll cages installed? xenocharger Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 06-03-2013 06:54 PM
