Old 01-30-2013, 02:05 PM   #295
bakerr6
Drives: 2013 raven black fr-s
Originally Posted by Unichip Jack View Post
The Fuel In and Fuel Out maps are similar to the Timing In and Timing Out maps in that they will run about 0.5 AFR lower (Fuel In) and about 0.5 AFR higher (Fuel Out) for cars that are either a bit high or low with the Fuel Standard map.
For any given bolt-on configuration, you’ll have 27 different maps to optimize your specific vehicle and for the fuel you’re using. For detail, check the maps thread, post #4… http://www.ft86club.com/forums/showthread.php?t=26134
We’re working the e85 and will release the maps as soon as we’re happy with them.
Cheers
jack,
have you completed the required add-on for the flux 2 in order to run flex fuel? If so, please send me in the right direction to order the parts, so that I can at least have them ready for when the e85 maps are available.
Thanks
bakerr6 is offline   Reply With Quote
Old 01-30-2013, 02:12 PM   #296
ScionFrsFan
What are your impressions with the current e85 set up...I know you guys are messing with it, but you might have some idea on how you like it .
ScionFrsFan
ScionFrsFan is offline   Reply With Quote
Old 01-30-2013, 09:23 PM   #297
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
Do you guys plan to offer anything specific for the borla uel headers? Would that even be necessary or would the "all headers" catch it?
industrial is offline   Reply With Quote
Old 01-31-2013, 11:28 AM   #298
Unichip Jack
Unichip Jack's Avatar
Drives: E36 M3, Whiteout FR-S
Industrial – while headers can certainly make a power difference, they don’t normally affect the calibration… the normal “All CatB” maps should correctly compensate for them.
Bakerr6… not yet… the plan right now is to offer a complete kit with all required parts. We’re evaluating several different options to find the best set up.
Last day for the member’s special… just sayin’…
Cheers
Unichip Jack is offline   Reply With Quote
Old 01-31-2013, 11:45 AM   #299
bakerr6
Cheers
Thanks Jack! Let me know if you guys have an ETA as to when you think it'll be done (I wont hold you to it haha).
Robert
Old 02-02-2013, 12:35 AM   #300
ScionFrsFan
Jack, will it be safe to run e85 in the winter? Even in the single digits ?
ScionFrsFan
Old 02-02-2013, 01:06 AM   #301
mact
Drives: 13 GTI
I like the idea of this tuning solution.
mact is offline   Reply With Quote
Old 02-02-2013, 08:35 AM   #302
bakerr6
Depends. E85 breaks down if not in the right conditions and synthesizers into water. However, it would take a while before this would happen. I'll be running it with the flex kit
The Following User Says Thank You to bakerr6 For This Useful Post:
ScionFrsFan (02-02-2013)
Old 02-02-2013, 07:14 PM   #303
xcelir8brz
Drives: 2013 BRZ Limited
What is this flex fuel kit everyone is talking about (i.e. E85)?
xcelir8brz is offline   Reply With Quote
Old 02-02-2013, 11:22 PM   #304
swift996
swift996's Avatar
I might jump in, very interested.
One recommendation - please offer the wiring with a black cover/wrap. I don't want red blaring out when I open my hood. It just looks tacky to me.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 02-03-2013, 12:05 AM   #305
swift996
swift996's Avatar
Also - will there be an option for bluetooth access via a smartphone app? I already have a bluetooth OBDII reader paired with the Torque app. So the display unit isn't too important to me. I'd love to be able to switch maps via my phone.
Old 02-03-2013, 11:08 PM   #306
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
I plan to fix mine with a roll of electrical tape.
Old 02-03-2013, 11:16 PM   #307
Blue86
Drives: Sonic Blue 86GT Manual
I'd go split conduit instead. Looks more factory and won't leave sticky shit
Blue86 is offline   Reply With Quote
Old 02-03-2013, 11:34 PM   #308
swift996
swift996's Avatar
I ordered my kit. I'll probably run down to Home Depot and pick up some black conduit. Either swap it or get some slightly over-sized and wrap it. My car is black and my PasswordJDM strut brace in black comes in tomorrow. I just don't want anything loud showing when I pop my hood. I like clean/subtle and simple.
Also, is there any issue in mounting the Unichip unit to the injector driver unit instead of the fuse box? It would keep it a little more hidden.
Let's get tuning! EcuTek tuning now available! carbonBLUE Southwest 6 06-29-2015 03:37 PM
Unichip EMS Unichip Jack Engine, Exhaust, Bolt-Ons 300 11-22-2014 04:13 AM
unichip 13 FR-S Veteran Engine, Exhaust, Transmission 9 02-04-2013 12:05 AM
unichip 13 FR-S Veteran CANADA 0 12-03-2012 06:31 PM
