Old 01-26-2013, 03:14 AM   #1
beesmiff07
beesmiff07's Avatar
Drives: Trailblazer
Does Turbo effect gas milage??
Now since there is no doubt that I will get the FRS...the next question is should I get a turbo kit installed....But I dont want to get one if its going to bring down the gas milage to what my truck is sitting at now...kinda defeating the purpose of making the switch.
beesmiff07 is offline   Reply With Quote
Old 01-26-2013, 03:18 AM   #2
ziggz501
ziggz501's Avatar
you will lose gas mileage, but you shouldn't be getting what a truck gets. your mpgs should only take a hit if your turbo is spooling. So as long as you don't have it spooling at 2000rpms, or as long as you're not just flat out all the time, then your mpgs shouldn't suffer much.
ziggz501 is offline   Reply With Quote
Old 01-26-2013, 03:18 AM   #3
Bristecom
Bristecom's Avatar
Drives: 2017 Subaru BRZ PP
Depends on how you tune it. At partial throttle you may even get better fuel economy but at full throttle, you will always get less fuel economy because you are using more fuel to compensate for the extra air. But keep in mind a turbo kit will be expensive, lower reliability, void the warranty, add weight, make the throttle less responsive, etc. It's not worth it IMO.
Toyota + Subaru =
Bristecom is offline   Reply With Quote
The Following 2 Users Say Thank You to Bristecom For This Useful Post:
Synack (01-26-2013), YourFearlessLeader (01-26-2013)
Old 01-26-2013, 03:37 AM   #4
beesmiff07
beesmiff07's Avatar
Drives: Trailblazer
Never took that in consideration...hmmmm
Old 01-26-2013, 04:00 AM   #5
GNS
Drives: .
Into consideration
GNS is offline   Reply With Quote
Old 01-26-2013, 04:03 AM   #6
beesmiff07
beesmiff07's Avatar
Drives: Trailblazer
Originally Posted by GNS View Post
Into consideration
good lookin out lol
Old 01-26-2013, 11:26 AM   #7
Turbowned
Turbowned's Avatar
Not much to say that hasn't been said already, lol. You could try asking the guys in the turbo subforum what they're getting for mileage. If you're spooling the turbo all day long your mileage is gonna suck, but if you can stay out of it during your commute or whatever, it shouldn't go down too bad so long as it's tuned well.
Old 01-26-2013, 11:40 AM   #8
ashtray
As Seen On The Internet
Drives: 2003 WRX, 2013 BRZ, 442
I'd say you might drop from 29 to 24mpg, depending how you drive it, turbo size, tune, etc.
ashtray is offline   Reply With Quote
Old 01-26-2013, 12:08 PM   #9
JDMenrique
DEEEERP
JDMenrique's Avatar
Im only going to tell you from experience. My last car came from the factory NA and I boosted it after a year. I actually gained a good 3-5mpg when driving slow and normal. WOT and it was a guzzler
JDMenrique is offline   Reply With Quote
The Following User Says Thank You to JDMenrique For This Useful Post:
surfuxalot (06-27-2015)
Old 01-26-2013, 12:12 PM   #10
Saab2Frs
Drives: 2013 Hot Lava Scion FRS
I've driven Saab turbos for most of my driving life. They got solid fuel economyl; however, when you're using a lot of boost you are going to use a lot of gas. At slow speeds and low boost, a turbo will improve gas mileage, BUT who gets turbo to use low boost?
Saab2Frs is offline   Reply With Quote
Old 01-26-2013, 12:12 PM   #11
Asphalt~86
Drives: Asphalt AT
Asphalt~86 is offline   Reply With Quote
Old 01-26-2013, 12:25 PM   #12
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
Financially this question is very ironic. Don't worry about it.
Rayme is offline   Reply With Quote
Old 01-26-2013, 12:30 PM   #13
2013GTRNate
2013GTRNate's Avatar
If you are worried about gas mileage… then a turbo upgrade is probably not ideal for you. I would suggest leaving it stock for best gas mileage…
-Nate
2013 Nissan GT-R Premium
2014 Subaru BRZ Limited
2014 Forester XT Touring
My BRZ's thread: http://www.ft86club.com/forums/showthread.php?t=47467
2013GTRNate is offline   Reply With Quote
Old 01-26-2013, 12:44 PM   #14
SkitterSkotter
SkitterSkotter's Avatar
Drives: 2013 Scion FR-S (Hot Lava)
that's a pretty valid point. One reasons engines make more power when they are tuned or modified is because they are more efficient and have a greater power density. Certainly with a turbo, while on boost, will be using quite a bit of gas, but if you say out of the boost for easy drives it should return the same mileage. There was a test done in Super Street a number of years ago for their ultimate modified car...in one of the tests they had to do a mileage loop. I believe the winner was a turbo MR-2 that got around 44 to the gallon. Although that number is pretty damn high, I would expect an FR-S to be able to say in the 30's with a good set up.
SkitterSkotter is offline   Reply With Quote
At what milage did your OEM tires start to lose grip? Liquidsnake Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 01-18-2013 06:38 PM
Milage App. execoll Scion FR-S / Toyota 86 GT86 General Forum 11 09-14-2012 01:23 PM
Carbon Effect Wing Mirrors faz1 Cosmetic Modification (Interior/Exterior/Lighting) 11 08-25-2012 10:12 PM
C&D: Japanese delays should not effect US allotments. Draco-REX BRZ First-Gen (2012+) — General Topics 11 04-21-2012 02:22 PM
MR-S Effect... Dimman CANADA 11 09-06-2011 12:49 PM
