Old 01-26-2013, 01:46 AM   #15
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
Always look for area under the curve first and foremost before looking at peak HP.
Yeah I understand that is far more valuable
Tansey86 is offline   Reply With Quote
The Following User Says Thank You to Tansey86 For This Useful Post:
Sportsguy83 (01-26-2013)
Old 01-26-2013, 01:48 AM   #16
Drift-Office
Drift-Office's Avatar
Drives: AE86 / FRS / FC3S / GC8 / S14 / R32
No need for apologies. Fact is, you can read and quote compressor maps all you'd like but that's just one side of the equation in regards to turbo efficiency. What ultimately matters is what that turbo and setup can do for your application : in this case a HC DI motor like the FA20.
You could spool a bigger turbo up to 9k rpm to get your peak numbers at a lower boost at say, 8.5PSI - but everything else in between isn't going to be remotely interesting, much less usable. In this case, if you'd note the range between 3500 to 6700 RPM - it maintains well over 200#s of (usable) torque before hitting peak power.
If the turbo wasn't well matched or as efficient, we would have seen that torque line drop off much earlier and faster. Just my 2 cents!
Bob @ Drift-Office, LLC
Drift-Office is offline   Reply With Quote
The Following 6 Users Say Thank You to Drift-Office For This Useful Post:
Alienate (03-01-2013), CxG (01-31-2017), itdansharpe (02-05-2013), QFry (01-27-2013), ultra (01-26-2013), usptwins (01-27-2013)
Old 01-26-2013, 01:50 AM   #17
Tansey86
Tansey86's Avatar
I completely agree. One of the reasons this great is so desired. Is the turbo placement a big factor in the curve?
Old 01-26-2013, 01:55 AM   #18
Gixxersixxerman
Gixxersixxerman's Avatar
Drives: Toyota GT86, 66 beetle, 11 GSXR 750
I got to ask.. It is just me, but this is annoying the hell out of me.. Why the top secret hush hush on the psi.. I just don't get it.. I always see somebody post something yet leave out info for what ever reason.. But I'm baffled as to why.. I guess I might be able to understand why a company would elect not to let someone know about the compressor, not really, but I guess it's so no one else sticks the same one on their kit first??? Idk.. Not saying its shady, but that's the first thing that pops in my mind.. Is it not the power your expecting and want to finish the tune first.. If so why not wait till its finished.. Or just let future customers know this is still being tuned better numbers to follow
I'm by no means knocking the companies, I just don't understand this part of business I guess.. I know it's probably a ignorant question..
Gixxersixxerman is offline   Reply With Quote
Old 01-26-2013, 02:06 AM   #19
Drift-Office
Originally Posted by Gixxersixxerman View Post
Why the top secret hush hush on the psi.. I just don't get it.. I always see somebody post something yet leave out info for what ever reason.. But I'm baffled as to why.. I know it's probably a ignorant question..
I can't speak for anyone else less me, myself and I - but the reason is very simple, since it's still work in progress. But I digress.
Say I quote a number, then all of a sudden, I'm held to that number. Since this is preliminary, and after I get done with what I deem as final, I might get more power with LESS boost than initially quoted. All of a sudden, someone here is going to "suspect" foul play, even though I've stated that it's under 10PSI. I will hold myself to that number (<10PSI) and we'll see what happens thereafter.
Only reason why this is here now (as a peek) is that AVO wanted to demonstrate what a tuned calibration would do for their kit, and we are confident that the end result would make cleaner runs, possibly higher numbers as well.
Regards,
The Following 8 Users Say Thank You to Drift-Office For This Useful Post:
20valvewynn83 (03-01-2013), Alienate (03-01-2013), AVOturboworld (01-26-2013), Batman (02-19-2013), BRZranger (01-26-2013), CxG (01-31-2017), Gixxersixxerman (01-26-2013), Sportsguy83 (01-26-2013)
Old 01-26-2013, 02:41 AM   #20
Gixxersixxerman
Regards,
Thank you
Old 01-26-2013, 03:16 AM   #21
mechaghost
mechaghost's Avatar
Drives: Silver AT Limited
Bob at it again!
mechaghost is offline   Reply With Quote
The Following User Says Thank You to mechaghost For This Useful Post:
Drift-Office (01-26-2013)
Old 01-26-2013, 04:24 AM   #22
BRZranger
Awesome results, thanks for sharing this! When are we going to see hand-drawn dyno comparing other FI options? :-P
BRZranger is offline   Reply With Quote
The Following User Says Thank You to BRZranger For This Useful Post:
Old 01-26-2013, 04:46 AM   #23
Drift-Office
I suppose that will happen when I elect to do a hypothetical assumption of power delivery on a yet unfinished product with modded components, comparing them to results from a competing product with less boost... clearly the norm isn't to use my own dyno chart either.
I'm anxious to see your results... and SOON. Might be all the justification to get an AT setup for that mythical FRS convertible when it comes out!
Regards!
The Following 3 Users Say Thank You to Drift-Office For This Useful Post:
BRZranger (01-26-2013), deucethemoose (01-26-2013), Sportsguy83 (01-26-2013)
Old 01-26-2013, 06:50 AM   #24
GC GTS Aero Kit
Australian and Proud !!!!
GC GTS Aero Kit's Avatar
Drives: 2012 Toyota 86 GTS Aero Kit
Bob if we have ordered the Stg1 kit from AVO how hard is it to get this tune to flash for our cars?
BONKRS for life
GC GTS Aero Kit is offline   Reply With Quote
Old 01-26-2013, 10:19 AM   #25
nonicname
Drives: it has 4 wheels and a motor
do you guys have an overlay compared to the stage 1?
nonicname is offline   Reply With Quote
Old 01-26-2013, 10:27 AM   #26
buditjoenawan
Drives: Very very slowly
Stirring the pot juuuuust a tad:
- budi
buditjoenawan is offline   Reply With Quote
The Following 8 Users Say Thank You to buditjoenawan For This Useful Post:
Bonburner (01-31-2013), BRZranger (01-26-2013), Craig (02-06-2013), CxG (01-31-2017), Drift-Office (01-26-2013), DriftEightSix (01-27-2013), FIREISFUN135 (01-27-2013), sandman126 (01-26-2013)
Old 01-26-2013, 10:35 AM   #27
buditjoenawan
Here you go:
I'm not affiliated with either AVO or Drift Office btw, I was just tickled pink by some company's dyno chart comparison and I thought some reciprocity is in order. And since I was already in Photoshop, I might as well do this overlay also.
- budi
The Following 4 Users Say Thank You to buditjoenawan For This Useful Post:
BRZranger (01-26-2013), CxG (01-31-2017), Drift-Office (01-26-2013), nonicname (01-26-2013)
Old 01-26-2013, 11:46 AM   #28
Drift-Office
- budi
That was totally awesome! Made my morning and had me burst out laughing.
Cheers!
The Following User Says Thank You to Drift-Office For This Useful Post:
My Beltronics STi-R Plus Installation - Work in progress xjohnx Electronics | Audio | NAV | Infotainment 27 07-20-2013 11:10 AM
First Full Blown Turbo Kit Install @Pure Automotive Performance is In Progress!! Pure Automotive Forced Induction 68 02-25-2013 12:06 PM
P&L Motorsports Stage 1 Turbo Kit Review (In Progress) Supermassive Forced Induction 66 02-07-2013 01:30 PM
First Full Blown Turbo Kit Install @Pure Automotive Performance is In Progress!! Pure Automotive Mid-Atlantic 61 01-30-2013 08:38 PM
Our FRS work in progress! detainu FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 14 06-24-2012 10:36 PM
