Old 01-24-2013, 01:42 AM   #113
Messerschmitt
Drives: Honda Civic 07
It is evident, but yes, quite barely I could say.
But my question still is. Is there a way to remove it for reposition without destroying the tape that holds the camera? or if I remove it, I need extra double sided tape (and where do you buy it anyway?)
Messerschmitt is offline   Reply With Quote
Old 01-24-2013, 05:00 AM   #114
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
Not sure about repositioning, but the adhesive is 3M double sixed tape. I think they refer to it by gorilla tape.
You can buy it at auto zone. Loom for 3M tape with the red backing.
F1point4 is offline   Reply With Quote
Old 01-25-2013, 09:07 AM   #115
atledreier
Drives: GT86 DGM
Ok, I am trying to get mine to cooperate here....
Bought it from ebay, the listing said english firmware. But when I plug the thing in it starts jabbering in korean. Downloaded the latest english firmware 1.040-400-E. THe software says version 1.038-400-E.
Install the 1.040 to the card and let that finish. No errors. Insert the card in the camera and switch the power on. LEDs flash in an assortment of colours for approximately 20 seconds, then the LED flashes blue and some korean chick starts going on...
Pull the power and after a few seconds she says something else and the light goes read, and the camera switches off.
What do I do wrong?
atledreier is offline   Reply With Quote
Old 01-25-2013, 12:52 PM   #116
Messerschmitt
What do I do wrong?
That's the normal start-up, shutdown. Did you even checked your SD card to see what it recorded?
@F1point4 unfortunately I live in Canada, so I'm guessing if this Auto zone is a shop, it's not available here.
Old 01-25-2013, 03:10 PM   #117
atledreier
Drives: GT86 DGM
Apparently all the firmwares I found was for the original HD, not the HDII. The firmware installed was 2.01K or something.
Old 01-26-2013, 05:24 AM   #118
atledreier
Drives: GT86 DGM
Found an English firmware, all is well! :-)
Old 01-30-2013, 02:39 AM   #119
mrlewistan
Driver of FR-S 1467
mrlewistan's Avatar
Drives: 2013 scion frs 001467
mine just came in today. i ordered it off massdrop.com along with a power magic pro for just under $250 ($227 i think). Thanks for the DIY. i guess im gonna buy some fuses and a tapper tomorrow and get to work on it thursday.
mrlewistan is offline   Reply With Quote
Old 01-31-2013, 02:29 PM   #120
mrlewistan
Driver of FR-S 1467
mrlewistan's Avatar
My power pro sometimes has issues when I use the switch to turn it off, then try turning on, it won't turn on. Is it possible I have a short or a bad box?
Old 02-10-2013, 03:00 PM   #121
Messerschmitt
Can the BlackVue with power magic kill my battery?
Today, my car won't start and it looks like the battery is kinda dead. When I opened my automatic door (and the stop lights are blinking) to get into the car, the blackvue started to shutdown. I found that peculiar.
I turned the key in 2nd position, everything is fine. I turn the key, and my dashboard starts to flicker, and the engine cranks a few times but it won't start. Once I release the ignition position, the dashboard lights return to normal.
So, I'm guessing my battery is near dead? I have set my power magic to stop at 11.8V (the maximum). I'm guessing that Blackvue shut down when I opened my doors because that triggered the battery to drop below the 11.8V? But then shouldn't the battery be able to start at that voltage?
I find it so hard to believe that the dashcam drained all my battery. And even so, if power magic works correctly, it shutdown when it reached 11.8V.
Old 02-10-2013, 04:04 PM   #122
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
Mine st up @ 12v and 48 hours after shut down engine. Didnt have any problem mine and didnt drive mine for 4 days
Sent from my Galaxy Nexus using Tapatalk 2
Old 02-12-2013, 01:59 PM   #123
xjohnx
Grip>Slip
xjohnx's Avatar
[ame="http://www.youtube.com/watch?v=5TRfd-RUQ60"]Another Idiot Driver - YouTube[/ame]
Old 02-14-2013, 11:51 PM   #124
F1point4
Photo Specialist
F1point4's Avatar
Whew. Close one
[ame="http://www.youtube.com/watch?v=oP79tvOUqzg"]Almost T-Boned in Chinatown.mp4 - YouTube[/ame]
Old 02-15-2013, 12:13 AM   #125
F1point4
Photo Specialist
F1point4's Avatar
Another one.
[ame="http://www.youtube.com/watch?v=LczTDk-tZGs"]Truck and Trailer loses control.mp4 - YouTube[/ame]
Old 02-15-2013, 12:18 AM   #126
JonnyRocket
"New hotness"
JonnyRocket's Avatar
Drives: WRB Limited MT BRZ
Originally Posted by F1point4 View Post
Another one.
Nobody pulled over to check on that guy? At least it looked like he was climbing out.
...SOLD my WRB BRZ...
Replaced with a 2013 Mazdaspeed3!
JonnyRocket is offline   Reply With Quote
blackvue, dashcam, diy, dr400g-hd, power magic pro
Dash Cam Installation (BlackVue DR400G-HD) DarrenDriven DIY (Do-It-Yourself) Guides 93 05-01-2018 09:54 PM
R-Magic & Rasty build 86 toxicdrift FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 23 08-10-2012 12:24 AM
R Magic Parts List quik1987 Engine, Exhaust, Transmission 9 07-30-2012 01:55 PM
R-Magic Demo Car (Exhaust video too!) ttknf Engine, Exhaust, Transmission 5 06-06-2012 02:20 AM
