Old 01-23-2013, 04:46 PM   #1
Mike86
Drives: Scion frs
Will a resonated front pipe make alot less noise than test pipe?
I have the invidia n1 and want to buy a front pipe i was just wondering if the difference in sound from (both catless by the way) resonated and non resonated was a big difference cause i dont mind loud i just dont want it extremly loud!
Thanks mike!!
Mike86 is offline   Reply With Quote
Old 01-23-2013, 07:09 PM   #2
FR-S Matt
Catless can sound like total crap unless you have it resonated and a good muffler. Otherwise, catted front pipes always sound amazing. I'd recommend staying catted with the N1.
The Following User Says Thank You to FR-S Matt For This Useful Post:
Mike86 (01-23-2013)
Old 01-23-2013, 09:54 PM   #3
FR-S Matt
Also, if you have plans for a header at any point later on, you will be very glad you have a catted front pipe because you'll most likely want a catless header if you're able to depending on your state. Headers can cause an ungodly amount of rasp as I found out with my '02 Camaro SS, both low range, and high. Cats seem to tame a lot of it down, but doesn't make it a lot quieter by any means, just slightly.
Old 01-23-2013, 10:03 PM   #4
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
If on a DD, do a catted or a resonated.
FT-86 SpeedFactory is offline   Reply With Quote
Old 01-23-2013, 11:18 PM   #5
Mike86
Drives: Scion frs
Yeah i live in canada so theres no emission problems i can have zero cats and still be legal so!! Thanks for the info i dont want rasp or an overly loud exhaust either ill probly go resonated then and hope its not too loud or too much drone!!
Old 01-24-2013, 12:11 AM   #6
Captain Insano
That's what I have. An invidia N1 and a catless resonated front pipe also by invidia. I plan to put it on in the next week or so when I have time. We can compare notes!!
Captain Insano is offline   Reply With Quote
The Following User Says Thank You to Captain Insano For This Useful Post:
Mike86 (01-24-2013)
Old 01-24-2013, 10:26 AM   #7
Mike86
Drives: Scion frs
Yeah let me know when you get it installed!! Have you had your n1 for a while cause when its broken in it makes alot less noise!
Old 01-24-2013, 11:25 PM   #8
Captain Insano
I havd had it for a month but it is still not installed. Lol... I have read many reviews that say same thing - it quieted down little after couple hundred miles or so.
Old 01-26-2013, 08:24 PM   #9
Captain Insano
So I installed the Invidia N1 catback today (not the catless resonated frontpipe yet). I am loving it. Very aggressive. I plan to drive it at least a couple hundred more miles before putting the frontpipe on to see how much quieter it gets with the carbon buildup. Might do overpipe too with the frontpipe in the next install session.
I really like the N1 so far.
FA20CLUB Over Pipe Front Pipe & Cold Air Intake Now Ready FA20Club.com Engine, Exhaust, Transmission 171 02-27-2013 10:44 AM
New Invidia Resonated Catless Front Pipe RallySport Direct Announcements, Contests, Giveaways 8 02-04-2013 06:06 PM
Agency Power over-pipe/front pipe combo question... seven Engine, Exhaust, Transmission 11 01-13-2013 01:14 PM
Resonated test pipe? track_warrior Engine, Exhaust, Transmission 3 07-30-2012 12:22 PM
