Old 01-22-2013, 02:48 AM   #15
stockysnail
Just the tip
stockysnail's Avatar
When DarrenDriven put them on my car it only took him 45mins, which includes everything from jacking the car and taking wheels off. He's done quite a few however so he knew exactly what to do and everything went smoothly.
Originally Posted by fistpoint View Post
All those people posting sub $400 install rates live in areas that have "honest" mechanics apparently. I called literally dozens of shops around Houston a few years ago for my RSX strut replacement and they all quoted between 6-8 hours labor at $90 per hour.
The RSX forum also had dozens of claims of sub $400 rates, but never in my city. Gun stores around here also suck ass with pricing. Maybe it's just a Houston thing?
Anyway, the job actually takes as much as 2 hours to do all 4...yes, 2 hours versus the 6-8 they'll want you to pay. In the end I found a local shop to accept 4 hours labor with me specifically pointing out that I'm willingly paying double the hourly rate they are actually going to spend. 2 hours later my car was ready and those struts now have 85k miles on them(for those who will say they rushed the job).
It's a 2 hour job plain and simple, especially for an actual shop with a lift and all the proper tools.
Old 01-22-2013, 09:38 AM   #16
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
I live in Houston and my $300 spring install was done around Katy.
post_break is offline   Reply With Quote
Old 01-22-2013, 09:40 AM   #17
f0rge
head of infinite swagger
Drives: 2013 FR-S 6MT
definitely don't pay more than $300.
2019 Golf R 6MT - current daily...I need another coupe
2008 Civic Si - winter beater
2000 Silverstone M5 6MT - SOLD
2013 Ultramarine FR-S 6MT - Car Journal - SOLD
2004 AlpineWhite M3 6MT - SOLD
f0rge is offline   Reply With Quote
Old 01-22-2013, 10:04 AM   #18
No Limit Motorsport
No Limit Motorsport's Avatar
Drives: 2013 DGM BRZ
Send a message via AIM to No Limit Motorsport
Originally Posted by JoeBoxer View Post
Evasive only charges like 120 according to one of their threads I couldn't believe it.
No way would a shop waste there time doing springs for $120. That had to be a mistype. Especially a good shop in an expensive area (So-cal)
We charge $250-$300. We charge $95 an hour for labor.
In all reality by the time you are done setting up the appointment, taking car in, setting car up, install, test drive, completing bill with customer you are into the car almost 4 hours total, 3 hours labor, 1 hour misc. If you run into issues such as cross threaded bolts, rust etc even longer.
No Limit Motorsport is offline   Reply With Quote
Old 01-22-2013, 10:12 AM   #19
#87
I usually post drunk
#87's Avatar
This. I installed my coilover on my last car. I tried to take them off but everything was rusted to shit. Ended up needing to cut some bolts and replace a bushing. Spent more time waiting for the replacement parts to arrive then they did working on the car. All this time it's stuck on their lift which = $.
Granted this is a new car and won't have that type of problem but be reasonable when looking for prices. If they are giving you a cut rate price chances are they are cutting corners.
#87 is offline   Reply With Quote
Old 01-22-2013, 10:15 AM   #20
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
I thought it was crazy too, i paid less but it was direct to a tech on the side not to a shop.
Post #11
http://www.ft86club.com/forums/showt...ighlight=SWIFT
The Following User Says Thank You to JoeBoxer For This Useful Post:
No Limit Motorsport (01-22-2013)
Old 01-22-2013, 10:42 AM   #21
Turn in Concepts
Turn in Concepts's Avatar
On a new RUST FREE car you're looking at about 2 hours plus alignment. Here that would put you right at about $300.
This is springs ONLY. 9 times out of 10 while we're in there the customer creeps the scope of the project with things like "while you're in there can you change the brake pads." Ten minutes later "I could use an oil change too." Ten minutes after that "if you're doing pads can you put a good brake fluid in it as well?"
Then about half the time I'm a bad guy because his $300 quote has jumped to $1k.
So, what I'm trying to tell you is this - springs and springs ONLY with an alignment should be about $300 IF you stick to just that.
Turn in Concepts is offline   Reply With Quote
Old 01-22-2013, 10:47 AM   #22
swift996
swift996's Avatar
I'm installing coilovers (when I order them). Do you need an impact gun? I don't have one, just a socket set.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 01-22-2013, 10:48 AM   #23
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
No. It's easier to get the lower strut bolts off with one but you don't need one.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
swift996 (01-22-2013)
Old 01-22-2013, 11:13 AM   #24
Tylub
Tylub's Avatar
Drives: Raven Black FR-S
ouch... those prices are outrageous! i paid $210 for my CG spring install with custom alignment.
instagram @Tylub
Mods: Tomei UELs, Tomei OP, Perrin Catted FP, ARK DT-S, Perrin LW Crank Pulley, Enkei RPF1, RSR Sporti, Supertek Intake Tube, Perrin CAI, Stoptech SS lines/brakes/slotted rotors, Cusco MCB brace/Strut Bar
Tylub is offline   Reply With Quote
Old 01-22-2013, 11:51 AM   #25
kickz
Drives: subaru sti
i got mines done at igarage only charged 160
kickz is offline   Reply With Quote
Old 01-22-2013, 12:04 PM   #26
JesseE
JesseE's Avatar
Drives: LS Swapped BRZ
Originally Posted by tbwoodlee View Post
The Toyota dealership wanted damn near a grand to install my new springs so I laughed in their face and walked away. A local tire shop wanted about 750 to do it. What is reasonable for this type of installation?
I know I will need an alignment, but man, for that much I will just put the springs on myself and get an alignment after they sit for a day.
What is a reasonable asking price to install some lowering springs?
My Shop charges around 400+ 70 for alignment
JesseE is offline   Reply With Quote
Old 01-22-2013, 12:14 PM   #27
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Your install is actually easier than replacement springs. In your case you are swapping the entire unit, there is no disassembly of the OEM unit and then reassembly.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Tylub (01-22-2013)
Old 01-22-2013, 12:35 PM   #28
wparsons
wparsons's Avatar
The last car I lowered myself was a MKII GTI and it took me about 2 hours start to finish doing it in my driveway, and that was putting the new springs on the existing struts.
If you have a hoist and work FAST you can definitely get it done faster.
flickr
Improper spring installation warning Memphis Suspension | Chassis | Brakes -- Sponsored by 949 Racing 77 03-17-2014 12:34 PM
Gazoo 86 spring rate ayau Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 01-19-2013 09:47 AM
======FRS===4X18 inch Black Racing Rims and tires!=====MESSAGE ME A REASONABLE OFFER! FRS-Jay Wheels and Tires 0 01-18-2013 07:59 PM
Best Spring Rate please help whitefrs Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 09-30-2012 09:02 PM
Lowest quality spring? Synack Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 07-26-2012 12:00 PM
