Old 01-21-2013, 09:46 PM   #1
NemeGuero
strange coilover install noises/ tried everything
my new coilovers are clunking really bad in the rear. I have gone through every trouble shooting step I can think of but nothing helps.
- ensured preload was set properly at 4mm
- torqued everything to proper spec
- made sure collars were tight and locked
- removed and inspected pillow mounts
- tightened pillow mounts to 50 ftlbs
- loosened and re torqued end links
- checked shock rebound with top hats removed on different damping settings
sounds exactly like this guy's problem:
http://www.ft86club.com/forums/showthread.php?t=13516
http://www.ft86club.com/forums/showthread.php?t=14343
NemeGuero is offline   Reply With Quote
Old 01-21-2013, 10:19 PM   #2
SMOKETREES
Lowered Lifestyle
SMOKETREES's Avatar
Drives: Scion Fr-S
Might have a bad coilover? Send back and get new one and see if it does it? Do all the others have same noise or just rear passenger side?
SMOKETREES is offline   Reply With Quote
Old 01-21-2013, 10:45 PM   #3
Bmore_Raven86
Drives: Scion FRS Raven
what brand? so will know not to get them..
Bmore_Raven86 is offline   Reply With Quote
Old 01-21-2013, 10:52 PM   #4
Asphaltfrs1
Asphaltfrs1's Avatar
Drives: 2013 asphalt fr-s
I had BC Coilovers in my last car. Had the same issue, annoying clanking if I remember correctly it was coming from the passenger rear. Tried everything, it went away for a few hundred miles, then it came back with a vengeance. Some people had said that it might have to do with the pillow balls being metal. Idk, I'll probably do KWs with this car, or koni with springs.
Asphaltfrs1 is offline   Reply With Quote
Old 01-21-2013, 10:55 PM   #5
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
how well calibrated is your torque wrench?
sometimes 50 is not really 50 and sometimes 50 is not enough
Old 01-21-2013, 11:20 PM   #6
SMOKETREES
Lowered Lifestyle
SMOKETREES's Avatar
Drives: Scion Fr-S
I hope belstien comes out with shocks!
Old 01-21-2013, 11:49 PM   #7
NemeGuero
it's both rears. I tried hitting the top nuts lightly with an impact on LOW and they didn't really tighten any more.
Old 01-21-2013, 11:53 PM   #8
SMOKETREES
Lowered Lifestyle
SMOKETREES's Avatar
Drives: Scion Fr-S
I would contact vendor and see what they say and possibly have them sent out new ones due to the clanky noise? I know i blew a stock strut and the actual valve was getting stuck in mid stroke which caused a clanky noise... Not familiar with coilovers that much but could that be the situation?
Old 01-21-2013, 11:55 PM   #9
Sithspawn
Drives: '14 Hot Lava FR-S w/Flappy Paddles
Have you tried spraying lithium grease into the spherical bearing? If not, give it a try and a day or two to work into the bearing.
Sithspawn is offline   Reply With Quote
Old 01-22-2013, 11:44 AM   #10
NemeGuero
I did contact the manufacturer. They're the ones who had me test the dampers and told me to torque down the top nut with an impact on low. They've basically told me that they think its something other than their coilovers making the noise.
Old 01-22-2013, 11:51 AM   #11
ultra
Curious cat.
ultra's Avatar
Drives: 86 GT base M/T - Red
It could possibly be that the top hats weren't properly bolted to the coilovers. I had that issue with a set of Stance units on my Miata.
Besides that, I'd check the top nut and the spherical bearings themselves, then everything else you mentioned plus stuff such as the swaybar brackets etc.
Good luck!
2013 Toyota 86 GT M/T
2009 Renault Clio Sport R27 Team F1 Edition (sold)
1991 Mazda MX5 Miata (sold)
2007 Mitsubishi Evo 9 RS (sold)
2006 VW Golf R32 (sold)
ultra is offline   Reply With Quote
Old 01-22-2013, 12:43 PM   #12
NemeGuero
That list is all the things I've already tested, including removing the top hats and inspecting them and reinstalling properly.
Old 02-11-2013, 05:55 PM   #13
Paragon
Guest
Posts: n/a
did you resolve this in the end? Im having the same issues with my BC fronts, very frustrating on brand new coilovers
Old 02-26-2013, 04:36 PM   #14
NemeGuero
BC said the noise is normal. I am still experiencing the noise with my new coilovers so I'm not entirely sure the problem was with the coilovers or with something I just overlooked.
I'm taking it in for alignment and I will have the shop take a look and see if they can source the noise.
Stance Super Sport coilover install/review ill roller Suspension | Chassis | Brakes -- Sponsored by 949 Racing 79 11-19-2016 06:31 PM
HKS Coilover install gtauto AUSTRALIA 16 04-21-2013 07:37 AM
Newbie question on rear of car swishing noises skyre Issues | Warranty | Recalls / TSB 4 01-03-2013 01:16 PM
Coilover install cost? BRZranger Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 08-14-2012 10:16 AM
