Old 06-23-2012, 06:09 AM   #57
serialk11r
Drives: '06 AM V8V Coupe
Originally Posted by JC View Post
That's assuming you drive all highway and doesn't include installation......
If you all you want is a quieter car take off the sound tube and add some sound insulation. It will save you $500+ and actually make your car noticeably quieter.
Several people have said this, but remember there are a few different variables here. One of which is the cost, I imagine it's possible to find diffs for less than 500 from crashed donor cars. Another is the amount you're changing the ratio, changing the ratio more doesn't cost more money, but it yields more fuel economy returns.
Say some company made some custom gearsets to replace the stock 6th gear, with a 0.62ish ratio for ~20% less revs. At lower highway speeds you would see almost 10% more fuel economy rather than ~5%. For some people the AT FRS/BRZ gearing is enough to pay off the 1000 dollar cost difference in just a few years of highway commuting. Of course, since there are no lower OEM 6th gears that we know of, this will end up being a more expensive mod than say, putting a 0.730 gear on a Celica C56 transmission.
Old 06-23-2012, 07:58 PM   #58
FT_Monk
Drives: Over the hill WRX
OP, You can install taller tires. It is cheaper, quickly reversible and no thing can go wrong like removing trans to replace gear.
FT_Monk is offline   Reply With Quote
Old 06-23-2012, 09:13 PM   #59
serialk11r
To get 10% greater rolling diameter you'd be raising the car 1.2 inches or so...
Old 06-23-2012, 11:59 PM   #60
FT_Monk
^^^ Only .6 inch taller measured from the center of the wheel. You can also lower the car to compensate for the taller tire. Even with the cost of lowering car, it is still much less risky and less costly then remove and replace trans gears.
Old 06-24-2012, 12:45 AM   #61
serialk11r
No, the tire diameter is about 24" so you'd be raising it 1.2". To drop the car 1.2" properly is going to cost some money.
Old 06-24-2012, 02:49 PM   #62
FT_Monk
Actually you are right! Your math is spot on and replacing transmission gear and diff is more effective and cheaper.
Good luck.
Old 06-24-2012, 03:32 PM   #63
Laurie
Drives: Toyota86, MX5, Jeep, FJ45, 59 Caddy
I'm struggling to find info on what the stock ratio is on the Automatic Transmission Toyota 86? There's quite a few times I'd like the power to kick the tail out and in 1st gear I'm on the limiter, 2nd gear I'm too low down. Also 5th and 6th are definitely low RPM cruising gears... I'd happily go numerically higher on the final ratio to get better acceleration and better torque...
2013 Toyota 86 - 2008 Mazda MX5
2001 Jeep Wrangler - 1982 FJ-45 Land Cruiser Pick-Up
1959 Cadillac Sedan DeVille
Laurie is offline   Reply With Quote
The Following User Says Thank You to Laurie For This Useful Post:
zohare (01-23-2013)
Old 06-24-2012, 03:49 PM   #64
Swift
I just Drive.
Swift's Avatar
Drives: in the womb still
Great thread and love how manufacturers use 10yr old parts, makes our jobs easier. Glad to know the different R/P sets available!
Swift is offline   Reply With Quote
Old 01-21-2013, 09:55 PM   #65
Racecomp Engineering
Bringin this one back...........
I want a different final drive for better acceleration while being NA.
Cusco 4.55 gets installed in the morning. Will report back on how it feels.
Current top speed if you had a lot of power is 168mph. New top speed with 4.55 ratio is 147mph at 7400 RPM. Around my home track ,Summit Point...this ratio will for sure drop lap times.
One thing is for CERTAIN........the final drive in the box is for sure a TOYOYA MOTOR COMPANY part.
Full review shortly.
Myles
The Following 4 Users Say Thank You to Racecomp Engineering For This Useful Post:
CircuitJerk (01-21-2013), SkAsphalt (01-29-2013), thejevans (01-22-2013), WRXGuy1 (01-23-2013)
Old 01-21-2013, 10:03 PM   #66
Captain Insano
Yes please report back ASAP!
Captain Insano is offline   Reply With Quote
Old 01-22-2013, 12:28 PM   #67
wparsons
wparsons's Avatar
You're only raising the car by the difference in radius, not diameter. Unless the new tire is 2.4" taller, you're not raising the car by 1.2"
The car is supported by the hub of the wheel, not sitting on top of the tire.
You will decrease gap to the fender by 0.6" as well though, so even though the car is higher from the ground the gap is smaller and it'll look lower. With that a 0.6" drop will get the car back to the original ride height, but you will have reduced fender gap by 1.2".
flickr
FreshFRS (01-22-2013)
Old 01-22-2013, 12:48 PM   #68
mike2100
mike2100's Avatar
Drives: 23 BRZ
haha exciting!
mike2100 is offline   Reply With Quote
Old 01-22-2013, 03:07 PM   #69
ShoNUFF
Who's the BADDEST?
ShoNUFF's Avatar
Drives: 2013 BRZ Limited - Crystal Black
Not sure everyone realizes that OP is trying to nueter the performance to increase MPG?
No disrespect to OP but I'm just..
On a sports car forum? REALLY?
I guess it's the 21st century.. might as well go green?
AM I THE MEANEST?
AM I THE PRETTIEST?
AM I THE BADDEST LOW DOWN MOFO AROUND TOWN?
SHO-NUFF!
ShoNUFF is offline   Reply With Quote
Old 01-22-2013, 03:15 PM   #70
FreshFRS
KCCO From Canada
Drives: Asphalt FRS
If i end up going with a PD supercharger this might be a viable option as performance would not be affected. plus 0-60 would be had in second about 6800 vs limiter 2nd/really early 3rd stock and would allow the supercharger to work more. but as an N/A car i would not do it.
FreshFRS is offline   Reply With Quote
GT86 GEAR BOX FIRECAR Engine, Exhaust, Transmission 10 11-24-2013 01:25 PM
Reverse gear on the first and second gear side randytindoggy Scion FR-S / Toyota 86 GT86 General Forum 50 01-29-2012 01:21 PM
86,BRZ MT gear ratio Yobiwan Engine, Exhaust, Transmission 1 01-26-2012 02:40 AM
Top gear USA 4agze Off-Topic Lounge [WARNING: NO POLITICS] 25 12-08-2010 11:01 PM
