Old 01-09-2013, 08:30 AM   #29
itdansharpe
itdansharpe's Avatar
Originally Posted by jeebus View Post
Yay I win at math today. :P
I have corrected for this calculation.
New: 2014 6MT Asphalt Rota Titan 17x9, RS-3 V2, Skunk2 Pro-C, Eibach Sway Bars, Password:JDM Strut Tower Bar, Perrin MCB, StopTech Stainless Lines, Hawk HP+, Nameless 3" Exhaust, VG Sharkfin, FIVE:AD Spoiler, DDM Tuning HID's 5k, HID
Old: 2013 6AT Boosted Firestorm..
itdansharpe is offline   Reply With Quote
Old 01-19-2013, 09:49 AM   #30
JDMenrique
DEEEERP
JDMenrique's Avatar
this should seriously be stickied
JDMenrique is offline   Reply With Quote
Old 01-19-2013, 10:08 AM   #31
etherealfall
Drives: Toyota 86 GTS Storm Black
This is awesome.
etherealfall is offline   Reply With Quote
Old 01-19-2013, 12:45 PM   #32
raul
Lap time enthusiast
raul's Avatar
Drives: Asphalt '13 FR-S 6MT
Originally Posted by Foobar View Post
So this tool assumes that the wheel width is equal to the tire width?
Yes, otherwise he would have to model shapes for tire stretch, which I'm sure is a lot more work.
raul is offline   Reply With Quote
Old 01-19-2013, 02:41 PM   #33
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
How accurate is this?
Also can you put in how close it would be to the shock/struts on the inside?
Tansey86 is offline   Reply With Quote
Old 01-19-2013, 02:51 PM   #34
Pure Automotive
Pure Automotive's Avatar
Drives: 2013 FRS Whiteout
Nice, I wish my math skills were that useful, you should go to MIT....
Pure Automotive is offline   Reply With Quote
Old 01-21-2013, 05:27 PM   #35
itdansharpe
Thanks guys. The script assumes an 'appropriate' wheel width, because drawing tire stretch is tricky to do. If there was enough demand, I'd take that challenge on.
As for inside clearance, if someone wants to provide some kind of diagram, or something to work with, I'd be happy to add it in.
Old 01-21-2013, 10:07 PM   #36
coyote
coyote's Avatar
Drives: Slowly
Originally Posted by itdansharpe View Post
I'd be happy to try and calculate camber, but would need a good technical source on how to calculate it.
Mate I'm not a technical source, but if you know the camber you are targeting it's pretty simple to work out the resultant change of position of the tyre.
x = sin(c) * (D - SH) / 2
Where:
x is change in tyre position
c is camber in degrees
D is diameter of tyre
SH is sidewall height
You could leave the sidewall height out, but it just approximates halfway up the sidewall as the widest point of the tyre.
coyote is offline   Reply With Quote
Old 01-29-2013, 04:26 AM   #37
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
bumpity..
Old 01-29-2013, 12:04 PM   #38
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
IMO it's incomplete without wheel width. These numbers arn't the same for a 8" wheel than a 9.5" wheel.
Old 01-29-2013, 08:02 PM   #39
itdansharpe
Hi all! I had some time to redesign and add in some key features people have been asking for:
- Camber
- Wheel Width
Enjoy! Maybe this will earn me a sticky now? ha!
The Following 3 Users Say Thank You to itdansharpe For This Useful Post:
BlaineWasHere (01-29-2013), coyote (01-30-2013), tintumz22 (01-31-2013)
Old 01-29-2013, 08:12 PM   #40
Tansey86
Tansey86's Avatar
I'd still love a way to see how close the wheel would be to hitting the shock/struts or a coilover for those of us who want to run a wide tire out back.
Old 01-30-2013, 11:41 PM   #41
coyote
coyote's Avatar
Drives: Slowly
Where do I vote?
Agree that the next step should be inboard clearance, both the stock struts and guard liner (for those with coilovers).
Old 01-31-2013, 07:48 PM   #42
itdansharpe
Bump! Added a few design touches, for fun. I was in the process of adding inside clearance, and quickly realized there are several suspension / driveline components that will need to be added in to accomplish this. I'm still not sure if it will be possible. For now, I've added a hub, and rotor, with the ability to toggle a particular components visibility. It also reassures me that as complex as some calculations are, the numbers are adding up correctly. (For example, offset is bang on)
Cheers.
BBK Fitment Database? F1point4 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 164 02-09-2026 12:48 AM
Auto Fitment Calculator itdansharpe Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 12-28-2012 01:09 PM
FR-S Speed/RPM Calculator FR-S #2637 Engine, Exhaust, Transmission 8 09-19-2012 11:41 AM
Spring Rate Calculator yomny Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 08-28-2012 11:31 AM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
