go_a_way1, KR-S, Tcoat
Old 01-16-2013, 04:51 PM   #71
OrbitalEllipses
Drives: Attitude
Originally Posted by chanomatik View Post
I'm surprised you didn't realize what the skirt was for, OE. I don't like it because it makes the front lip look awkward, but it serves a purpose. I'd rather have a cheap front lip to protect my bumper, but a "cheap" skirt to protect my expensive front lip to protect my front bumper is also okay.
Must consider. Unless shipping is stupid. Which it probably is.
Old 01-16-2013, 04:56 PM   #72
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
Technically the rubber flap is marketed to be an aerodynamic enhancement (air flow management). I only got it to protect the lip... I knew I'd scrape regardless lol
The Following User Says Thank You to switchlanez For This Useful Post:
chanomatik (01-16-2013)
Old 01-16-2013, 07:11 PM   #73
cslntuee
Drives: Subaru BRZ Limited
Your car look so nice.
Do you have any plan for the light( front, rear, fog…etc)?
I remember that you put the overlay on your fog light in one post.
Did you remove that? What’s reason for that? Any new plan?
I still very hesitate to put the overlay on my car or not including front, rear, side and fog. How do you think?
Thanks a lot.
cslntuee is offline   Reply With Quote
Old 01-21-2013, 03:15 AM   #74
switchlanez
New pics added to 1st page. Teaser:
The Following 2 Users Say Thank You to switchlanez For This Useful Post:
cslntuee (01-21-2013), JoeBoxer (01-21-2013)
Old 01-21-2013, 03:21 AM   #75
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
The pics are amazing, they look better than any magazine or manufacturer sends out.
The Following User Says Thank You to JoeBoxer For This Useful Post:
switchlanez (01-21-2013)
Old 01-21-2013, 07:43 AM   #76
Rampage
Senior Member/Old Fanboi
Rampage's Avatar
Drives: 2000 2ZZ-GE MR2 Spyder HT
This is without a doubt one of the classiest modded FR-S/BRZ on this forum. If I were to do one, it would be very close to what you have done. Congratulations on a beautifully thought out car and a gorgeous friend.
So many modders have more cents than sense!
Rampage is offline   Reply With Quote
The Following User Says Thank You to Rampage For This Useful Post:
Old 01-21-2013, 09:47 AM   #77
switchlanez
I just got a PM asking about my suspension setup. I've gotten these questions before so I'll post my answer here for others to see.
...what kind of suspension are you running on your car? ...was wondering how you like them ...are you on stock suspension still?
My only suspension mod listed is STI springs so I'm on stock struts (which the springs were designed for). I think they are very nice, a little firmer than stock but not jarring. The car stays planted over sweeping undulations in the road. It also helps that I am on wider/taller 225/45/17 rubber all around. It feels lower than stock when I sit inside. But not so low that I scrape everywhere. I do scrape occasionally but that's because my STI front lip+rubber flap take away 2" of clearance and the rubber flap absorbs all the impact.
Sargy (01-21-2013)
Old 01-21-2013, 10:02 AM   #78
switchlanez
Thanks a lot.
Sorry, I just noticed your post. Thanks for the question. I had yellow overlays on my fog lights but after researching it a bit I found any overlay will increase the potential for cracks to form in the lens. So I took them off. When temperature changes, the lens expands/contracts at a different rate than the overlay because they are different materials. Since they are mated together, one has to give way. The overlay usually has some flexibility and gives way. But when it's not flexible enough, the lens will form cracks.
I don't plan to put overlays on any lights unless there is a brand proven to not cause cracks. Cracks don't happen 100% to everyone, but the risk is there and it's up to you if you want to live with that risk. I'd say the side markers are the lowest risk and bigger pieces higher risk.
chanomatik (01-21-2013), cslntuee (01-21-2013)
Old 01-21-2013, 11:20 AM   #79
cslntuee
HI,
Thanks a lot for your information.
Will the spray paint also cause the same risk?
Thanks again.
Old 01-21-2013, 11:41 AM   #80
switchlanez
HI,
Thanks again.
Several people in my area have sprayed their FR-S/BRZ tail lights and sidemarkers with no problem. They used a brand named VHT. They are also able to completely remove the spray whenever they want (using Goof Off I think). I don't think spray tint causes cracks but you should research to double check.
Old 01-21-2013, 11:47 AM   #81
ZC6BRZ
Wannabe JDM Type S
ZC6BRZ's Avatar
Drives: 2013 BRZ Limited
switchlanez,
your BRZ is one of my favorites. I think we have similar tuning philosophies.
ZC6BRZ is offline   Reply With Quote
The Following User Says Thank You to ZC6BRZ For This Useful Post:
Old 01-21-2013, 11:53 AM   #82
Pascal_TTH
Pascal_TTH's Avatar
Drives: Subaru BRZ soon
I got the same Verbatim USB device. My wife also got the same. Nice small one !
Pascal_TTH is offline   Reply With Quote
The Following User Says Thank You to Pascal_TTH For This Useful Post:
Old 01-21-2013, 03:57 PM   #83
M-17
Ninja Cat Mod
M-17's Avatar
I'd say that's my favorite picture overall.
The Following 2 Users Say Thank You to M-17 For This Useful Post:
chanomatik (01-21-2013), switchlanez (01-21-2013)
Old 01-21-2013, 04:07 PM   #84
Clint520
Clint520's Avatar
Drives: GBS BRZ AT
Amazing. I need this kit lol.
Clint520 is offline   Reply With Quote
The Following User Says Thank You to Clint520 For This Useful Post:
Nurburgring Video of Subaru BRZ Coupe / Subaru FR-S / Toyota FT-86 Shows off Handling Hachiroku BRZ Photos, Videos, Wallpapers, Gallery Forum 113 11-21-2020 01:02 PM
August 1st Charity Lapping Day - Subaru Canada - Davenport Subaru - SPDA - TSC wparsons CANADA 10 07-22-2015 01:24 PM
Subaru Cross Sport Design Concept = Subaru BRZ Shooting Brake Hachiroku BRZ First-Gen (2012+) — General Topics 91 04-01-2014 06:53 PM
Subaru LIBIRD Supercar Concept & BRZ (April Fools) switchlanez BRZ First-Gen (2012+) — General Topics 18 04-15-2013 02:20 PM
Subaru BRZ - RAW Subaru | Official Subaru Australia Ad Hachiroku BRZ Photos, Videos, Wallpapers, Gallery Forum 15 07-20-2012 08:20 AM
