Old 01-20-2013, 02:34 PM   #127
cslntuee
Drives: Subaru BRZ Limited
Originally Posted by Hanakuso View Post
I noticed this a couple weeks ago. Not sure what's going on tho.
http://www.ft86club.com/forums/showthread.php?t=25362
I'm thinking of adding on the center sections like how the TRD Griffon. Shouldn't cost too much to make it myself.
What’s the advantage and disadvantage to add additional center part?
I might interested to join (Please keep update your plan), but I am not yet find the people to group buy OEM
under panel. ><
cslntuee is offline   Reply With Quote
Old 01-20-2013, 02:40 PM   #128
Hanakuso
under panel. ><
I'm no engineer, but i'm guessing it would result in less drag and hopefully smooth out the turbulence. Only downside I see is it would cool off the cat/exhaust piping less then it doesnt have direct airflow but I don't think it's that important.There's a small discussion on the under aero here,
http://www.ft86club.com/forums/showthread.php?t=26805
My goal/budget is around $100-150 for the mid section. I was only planning on doing it for myself but if you want I can get both of them done for us. If I have to resort to using a professional to cut/drill it would save some cost for both of us. I'm about to post a thread for advice on what material is best.
Hanakuso is offline   Reply With Quote
The Following 2 Users Say Thank You to Hanakuso For This Useful Post:
chanomatik (01-21-2013), Lawnik (01-20-2013)
Old 01-20-2013, 03:01 PM   #129
White64Goat
A. Why would they make different underpanels for JDM/USDM? Doesn't make a lot of sense...........
B. Salt spray is going to get under these panels just like sand at the beach in your swim trunks, it's gonna happen.
Old 01-20-2013, 03:13 PM   #130
ayau
Drives: Some rust bucket
Only the high trim JDM 86/BRZ gets the full underpanels. The low trim JDM models only get a small plastic panel to cover the brake lines, similar to the USDM models.
Old 01-20-2013, 03:15 PM   #131
Hanakuso
I doubt much stuff will get under these panels. The fronts are connected to the pre-existing panels so it would most likely have to get under from the sides, which is still minimal. It only takes 10-15 minutes to take them off and get cleaned anways so it's not that bad.
Old 01-20-2013, 05:13 PM   #132
Beyer Subaru
Drives: 2013 BRZ SWP 6AT Ltd
A. Every market gets minor tweaks and changes be them good or in our case bad. In Europe one of our members let us know that they only get fix-a-flat and an air compressor in place of a spare tire.
B. Yep, salt/sand will follow the path of least resistance.
Beyer Subaru is offline   Reply With Quote
Old 01-20-2013, 06:16 PM   #133
ZC6BRZ
Wannabe JDM Type S
ZC6BRZ's Avatar
Drives: 2013 BRZ Limited
Actually the high trim BRZ doesn't even get it. It's part of the aero package with rear spoiler.
ZC6BRZ is offline   Reply With Quote
Old 01-20-2013, 08:30 PM   #134
twincamRob
twincamRob's Avatar
Drives: 2013 FS FR-S
Originally Posted by Beyer Subaru View Post
Yep, got mine on last night. All went well except for the clips closest to the front. The lift was blocking these. I still gotta get these on.
Originally Posted by DSOmegaX View Post
Was part of the group buy but only just now installed them. Fast and easy!
Were all the extra clips, screws and/or nuts included with the panels?
Robbie S.
-13 FR-S
-12 H-D 48
Instagram: @twincamrob
twincamRob is offline   Reply With Quote
Old 01-20-2013, 08:45 PM   #135
SubaSteve
Captain Cocoa
Drives: CBS BRZ MT
Everything is included and I reused some of the bolts so I would have spares left over for other things.
SubaSteve is offline   Reply With Quote
Old 01-20-2013, 10:41 PM   #136
rhood168
rhood168's Avatar
Drives: Black Subaru Brz Limited
Little confused here...
So we are missing 4 panels and only have 2 or the other way around also whats the difference between these two orders look the same to me except one is 700 bucks while the other is 180
DA FAQ
http://www.japanparts.com/db/partsli...EY=484-001-007
rhood168 is offline   Reply With Quote
Old 01-20-2013, 10:46 PM   #137
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
The 700 price one is for a set of 4, for a group buy or if you own 4 of the same car. It ends up saving around $60/set.
industrial is offline   Reply With Quote
Old 01-20-2013, 10:51 PM   #138
ayau
DA FAQ
JDM models have 4 panels, 2 in the front, 2 in the back.
USDM models have 1 small panel to cover the brake lines.
The Following User Says Thank You to ayau For This Useful Post:
Bonburner (02-01-2013)
Old 01-21-2013, 09:16 AM   #139
Beyer Subaru
Yerp. This is as complete a kit as possible. It comes with all the new clips, screws, etc.. I reused some of the screws as they were the same length.
I even sheared one of the screws at time of install. These screws are like the strut bar studs as far as torque is concerned. Just past snug/hand tight gets it done. I used a left hand bit to get the sheared screw out.
Old 01-21-2013, 09:04 PM   #140
twincamRob
twincamRob's Avatar
Awesome thanks!
Robbie S.
-13 FR-S
-12 H-D 48
Brz Limited Avalable (currently wait listed, but soon. This is not an add.) Floggin Tires Great Lakes 2 09-25-2012 01:13 AM
Japanparts.com Review Sportsguy83 User/Vendor/Sponsor Reviews, Feedback, Comments 7 08-03-2012 09:23 AM
Cars.com has BRZ's listed??? Rick Boxx BRZ First-Gen (2012+) — General Topics 0 05-13-2012 02:36 PM
Listed on Autotrader (US) cassidy0998 Scion FR-S / Toyota 86 GT86 General Forum 3 02-02-2012 11:16 AM
FR-S Officially Listed on the Scion Site goshamrocks13 Scion FR-S / Toyota 86 GT86 General Forum 32 10-07-2011 11:52 AM
