Old 01-17-2013, 06:32 PM   #15
joop1987
Drives: 2013 FRS, Raven, Auto
It's difficult to package a DOHC in a VR6. Too much stuff in a small space. My co worker had a head gasket leak in his and traded it in.
joop1987 is offline   Reply With Quote
Old 01-17-2013, 07:39 PM   #16
fly2low
fly2low's Avatar
Drives: Yes, I drive
VR6 allows for a more compact packaging and cheaper cost. It is a narrow angle V6 with one instead of two cylinder head.
In my car, I feel that it behaves more like I6 than V6, happy to be revved.
Having said that, if I might do a related question to OP's: I never understand why some people like to have V6 in their FWD cars. Sure, the powerband is smoother but the dynamics of the car is ruined. Nose heavy and plowing at turns.
If I have to get a fwd car, I will go with the I4 offering.
2013 Lexus GS350, 2013 VW Touareg, 2003 Mitsubishi Evolution, 2007 Triumph Daytona 675
fly2low is offline   Reply With Quote
Old 01-17-2013, 07:42 PM   #17
fly2low
fly2low's Avatar
VW's VR6 is DOHC. "Dual overhead camshaft, chain driven, four valves per cylinder, maintenance free hydraulic lifters, variable intake timing"
Old 01-17-2013, 10:48 PM   #18
JesseE
JesseE's Avatar
Drives: LS Swapped BRZ
Originally Posted by jaynutter2 View Post
Isn't the VR6 notorious for being unreliable and breaking down?
every single vw/audi has that same problem... its due to design not so much the "vr6" part... its just anything vw touches, it fucks up.... bad
JesseE is offline   Reply With Quote
Old 01-17-2013, 11:06 PM   #19
Flat Black VW
Flat Black VW's Avatar
Drives: 2013 Subaru BRZ
not all, there is a 12v and a 24v. 12v was in the MKIII and MKIV until 2002 or 2003 iirc, then the MKIV had a 24v. Rs are 24v.
From my experience with far too many VWs is that engines are generally fine, electrical systems are where they screw up. Ive had a couple VRs that treated me VERY well, I still have one of them that has become a long term project.
To the OP, the VR is a great engine IMO, I have an OBDII MKIV 12v in a jetta that has become my long term project and will be converted to AWD. In the US we only received the VR as FWD (exception for the R32s) but in europe they were available as 4motion jettas. There are a few people who have done AWD conversions but it is very labor intensive. Ive always wanted to buy a rabbit truck and put a VR in the back, but whenever I think about it I realize if I were to truly put that much time and energy into a caddy there are many other engines I would choose first.
Flat Black VW is offline   Reply With Quote
Old 01-17-2013, 11:09 PM   #20
Flat Black VW
Originally Posted by dorifuto View Post
The Bugatti veyron uses this type of witchcraft in the w16
In a way, for the W16 they basically took what would be the equivalent of two VR8s and put them in a regular V layout. Pictures explain better:
Old 01-18-2013, 12:09 AM   #21
fly2low
fly2low's Avatar
Thanks for the correction. I meant current VW VR6. You ve been a vw enthusiast longer than i do. This is only my 2nd veedub.
Btw there are current awd vr6 offerings. I m not sure why you said fwd only?
Touareg, passat, cc
Old 01-18-2013, 12:19 AM   #22
fly2low
fly2low's Avatar
Here is a pic of vr6 of my car, just for fun
Old 01-23-2013, 04:06 PM   #23
ianz28
Drives: 09' VW GTI
Pretty sure that is just a normal V6
ianz28 is offline   Reply With Quote
The Following User Says Thank You to ianz28 For This Useful Post:
onthemove (01-24-2013)
Old 01-23-2013, 04:12 PM   #24
HunterGreene
Hail Magnet
HunterGreene's Avatar
To ask why these aren't more widespread, there was an issue that I recall with the cylinder walls being too thin and failing earlier than expected.
Old 01-23-2013, 05:29 PM   #25
funbeatsfast
funbeatsfast's Avatar
Drives: '13 FR-S
The concept behind the VR6 is almost the opposite of a flat engine. Taller, higher center of gravity compared to a 60 degree V6 for packaging purposes. Likely a little longer than a comparable V configuration (though I'd have to verify), which makes it even less ideal for a RWD application. So, all around less than ideal. And yet... replacing the audi I4 in a porshe 944 with a VR6 could be a fun LeMons car
funbeatsfast is offline   Reply With Quote
Old 01-24-2013, 03:25 PM   #26
fly2low
fly2low's Avatar
It is a VR6. VW decided to label the same engine VR6 in some cars and V6 in the others. VW only has one 6-cyl non-hybrid gas engine offering for U.S. market.
Old 01-24-2013, 03:32 PM   #27
JDLAutoDesign
JDLAutoDesign's Avatar
Drives: 13 FRS
Its pretty common to swap VRs into B5 Quattros and turbo the piss out of it. Its what I would do it I was to own another VW
JDLAutoDesign is offline   Reply With Quote
Old 01-24-2013, 03:48 PM   #28
SkullWorks
Drives: SSM LT MT BRZ
as far as AUDI products go smart money sticks with the standard 2.7l V6 (not VR) for real HP. I have one of these blocks next door and while very compact in size, weighs the same or maybe more (bare block) than a SBC 350 block (bare block)
VR is a cool motor no doubt, just no real benefit for a RWD car, (as mentioned numerous times already)
it would be cool for MR cars because it leaves more room on both sides for Turbos due to 15 degree V instead of 60 or 90,
As far as FWD applications go, I couldn't possibly care any less.
Push Rod vs. DOHC engines brillo Other Vehicles & General Automotive Discussions 92 03-22-2015 08:58 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 07:47 PM
100 hp/l NA engines einzlr Other Vehicles & General Automotive Discussions 95 11-15-2012 07:55 PM
What other engines fit our transmissions 1strwdcar Engine, Exhaust, Transmission 36 08-02-2012 04:45 PM
So you think you know engines? Ryephile Other Vehicles & General Automotive Discussions 43 02-04-2012 03:49 AM
